#This file is controlled by AMP, any changes will be overwritten. If you need to add any extra settings, create a file called ‘user.cfg’ and AMP will append its contents after this line.
– user.cfg
sets sv_projectName “Matrix Gaming”
sets sv_projectDesc “Matrix Gaming”
#Lines below this point are controlled by AMP.
– server.cfg
sets PoweredBy “AMP by CubeCoders - CubeCoders”
set udpLogAddress 127.0.0.1:41224
sets tags “default”
sv_scriptHookAllowed 1
endpoint_add_tcp “0.0.0.0:30120”
endpoint_add_udp “0.0.0.0:30120”
rcon_password 1b7da2523b7d485aaa295cbebf666b94
ensure AMPFiveMIntegrationServer
stop webadmin
ensure mapmanager
ensure chat
ensure spawnmanager
ensure sessionmanager
ensure fivem
ensure hardcap
ensure rconlog
ensure scoreboard
sv_endpointprivacy True
sv_maxclients 32
sv_hostname “Matrix Gaming”
sv_licenseKey “cfxk_1CEecT7cV0jjC0yEzFnCN_2BYH68”
set steam_webApiKey “145C40D760508DD52E630C172213418A”
sets banner_connecting “”
sets banner_detail “”
load_server_icon “”
This is the AMP five M CFG and this does not include sets sv_projectName and sets sv_projectDesc but due to AMP managing the server.cfg i am unable to add these to the cfg as it rewrites it.
I have attempted to insert them into the user.cfg that still does not fix the problem either
And no it does not, even after configuring the TX Admin, so the server files are fully set up it still does not load.
I have created a full brand new instance done the update and then inserted the license key and it still does not load up.
