| Virtualization | Docker |
| Application | Euro Truck Simulator 2 |
| Module | GenericModule |
| Current State | Stopped |
The server starts, spits bunch of errors, and then does nothing. If I press “stop” button Euro Truck Simulator 2 server starts for 2 seconds and stops.
I followed the guide, did this instance in container and set the steam token.
When I press the start button line 40 in the log is the last one that is created.
In log: “22:26:22” it is the time when I pressed stop button. Then the [MP] messages started popping out.
Log: *** WARNING *** : [unit] The pointer to 'camera.wander' looks like dangling poin - Pastebin.com
Main Server Port 27015 UDP always shows a red dot.
Also I should add that server after it “started” I could not find it on the convoy list in game.
- Create instance in container
- Update
- Follow guide
- Add steam token and personal settings
- Update once more (just to be sure)
- Start instance
