Field | Value |
Product | AMP ‘Phobos’ v2.6.0.12 (Mainline) |
Virtualization | Docker |
Application | Enshrouded |
Module | GenericModule |
Running in Container | Yes |
Current State | Failed |
[16:44:22] [Generic:admin Info/21] : Merging config file ./enshrouded/2278520/enshrouded_server.json (JSON format) using Unicode (UTF-8) encoding.
fsync: up and running.
wine: failed to open “/AMP/enshrouded/2278520/enshrouded_server.exe”: c0000135
[16:44:27] [System:admin Warning/20] : The application stopped unexpectedly. Exit code 53
[16:44:27] [System:admin Warning/20] : Application failed to start 2 times, not restarting.
[16:44:45] [System:admin Warning/18] : Slow method invocation: Start took 30478ms to complete.
[16:44:45] [System:admin Warning/18] : Slow response: Core.Start took 30479ms to complete.
[16:45:11] [Core:admin Activity/22] : Starting the application.
[16:45:11] [Generic:admin Info/22] : Merging config file ./enshrouded/2278520/enshrouded_server.json (JSON format) using Unicode (UTF-8) encoding.
[16:45:16] [System:admin Warning/21] : The application stopped unexpectedly. Exit code 53
- Installed AMP on Ubuntu VM
- Configured AMP and created Enshrouded instance
- Set port forwarding for 15637 to Ubuntu VM
- Attempted to start instance
