Startup Issue with Enshrouded - Cant Run Docker Instances
Application Enshrouded
Current State Installing
Will get this error:
2024-05-28 10:31:45 at Net.Sockets.UdpClient.Send (Byte dgram, Int32 bytes)
2024-05-28 10:31:45 at ModuleShared.MetricsInfoPublisher.UpdateMetrics ()
2024-05-28 10:31:55 [16:31:55] [Core Error/4] : SocketException
2024-05-28 10:31:55 [16:31:55] [Core Error/4] : [0] (SocketException) : Connection refused
2024-05-28 10:31:55 [16:31:55] [Core Error/4] : at Net.Sockets.Socket.Send (Byte buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
2024-05-28 10:31:55 at Net.Sockets.UdpClient.Send (Byte dgram, Int32 bytes)
2024-05-28 10:31:55 at ModuleShared.MetricsInfoPublisher.UpdateMetrics ()
Also while the installation is being performed being alerted by Windows defender for trojans etc.. Thinks its related to Proton GE that is being downloaded and installed as an Update Task
Also this is a Windows 10 Pro Host Machine
  • Install AMP
  • Install Docker
  • Follow Steps for windows:
  • Steps on descriptions
I’m having this exact same issue with my Docker containers. Are there any fixes for this or is it a non-issue?
