Startup Issue with Eco - Server not starting
Operating System Linux - Ubuntu 24.04 on x86_64
Product AMP ‘Callisto’ v2.5.0.8 (Mainline)
Virtualization QEMU_KVM
Application Eco
Getting a lot of errors starting with this one.
/home/amp/.ampdata/instances/Eco-Neverware01/eco/739590/liblibgdiplus: cannot open shared object file: No such file or directory
at System.Drawing.SafeNativeMethods.Gdip.GdiplusStartup(IntPtr& token, StartupInput& input, StartupOutput& output)
at System.Drawing.SafeNativeMethods.Gdip…cctor()
Outer Exceptions:
One or more errors occurred. (One or more errors occurred. (One or more errors occurred. (The type initializer for ‘Gdip’ threw an exception.) (Object reference not set to an instance of an object.) (Object reference not set to an instance of an object.) (Object reference not set to an instance of an object.) (Object reference not set to an instance of an object.) (Object reference not set to an instance of an object.) (Object reference not set to an instance of an object.) (Object reference not set to an instance of an object.) (Object reference not set to an instance of an object.) (Object reference not set to an instance of an object.) (Object reference not set to an instance of an object.) (Object reference not set to an instance of an object.)))
[03:13:14] Shutdown finished
[03:13:14] Errors report:
Can’t find ecopedia link ‘CourtOfAppealsItem’ (referenced on page ‘Government’): 1
Can’t find ecopedia link ‘HomesteadSupportClaimItem’ (referenced on page ‘Settlements’): 1
Failed to start the server. Exception was Exception: DllNotFoundException
Message:Unable to load shared library ‘libgdiplus’ or one of its dependencies. In order to help diagnose loading problems, consider using a tool like strace. If you’re using glibc, consider setting the LD_DEBUG environment variable:
/home/amp/.net/EcoServer/ZTUE1sI7wMCdGZWBhGjf10Ml_19qr_o=/libgdiplus.so: cannot open shared object file: No such file or directory
/home/amp/.ampdata/instances/Eco-Neverware01/eco/739590/libgdiplus.so: cannot open shared object file: No such file or directory
/home/amp/.net/EcoServer/ZTUE1sI7wMCdGZWBhGjf10Ml_19qr_o=/liblibgdiplus.so: cannot open shared object file: No such file or directory
/home/amp/.ampdata/instances/Eco-Neverware01/eco/739590/liblibgdiplus.so: cannot open shared object file: No such file or directory
/home/amp/.net/EcoServer/ZTUE1sI7wMCdGZWBhGjf10Ml_19qr_o=/libgdiplus: cannot open shared object file: No such file or directory
/home/amp/.ampdata/instances/Eco-Neverware01/eco/739590/libgdiplus: cannot open shared object file: No such file or directory
/home/amp/.net/EcoServer/ZTUE1sI7wMCdGZWBhGjf10Ml_19qr_o=/liblibgdiplus: cannot open shared object file: No such file or directory
Source:System.Drawing.Common
System.DllNotFoundException: Unable to load shared library ‘libgdiplus’ or one of its dependencies. In order to help diagnose loading problems, consider using a tool like strace. If you’re using glibc, consider setting the LD_DEBUG environment variable:
Outer Exceptions:
  • Checked logs and reinstalled
  • Googled the issue
  • Read the server config doc
Install libgdiplus via apt
