| Operating System | Windows - Windows Server 2022 on x86_64 |
| Product | AMP ‘Decadeus’ v2.4.8.0 (Mainline) |
| Virtualization | VMware |
| Application | DayZ (Stable) |
| Module | GenericModule |
| Running in Container | No |
| Current State | Failed |
New DayZ server will not start, throwing this error - the application stopped unexpectedly. exit code -1073741515. I am able to update the game and install mods, but the server will not start.
Server Logs:
[14:58:51] [Program Info] : Starting AMP version 2.4.8.0 (Decadeus), built 29/01/2024 18:40
[14:58:51] [Program Info] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[14:58:51] [Core Info] : Purging old audit logs (this may take a moment)…
[14:58:51] [Program Info] : Running in a VMware environment.
[14:58:51] [Core Warning] : Current time zone is set to Eastern Standard Time - It is recommended you switch to UTC+0 to avoid time-zone related issues
[14:58:51] [Program Info] : OS: Windows / x86_64
[14:58:51] [Program Info] : CPU: Intel(R) Xeon(R) CPU E5-2640 v4 @ 2.40GHz (8C/8T)
[14:58:51] [Program Info] : RAM: 24575MB
[14:58:51] [Program Info] : AMP Instance ID: 1809693b-6d14-48f4-a518-0256baf3ef1a
[14:58:52] [Loader Info] : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
[14:58:52] [Core Info] : Metrics publishing is enabled at udp://localhost:12820.
[14:58:53] [Loader Info] : Loaded FileManagerPlugin by CubeCoders Limited
[14:58:53] [Loader Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[14:58:53] [Loader Info] : Loaded WebRequestPlugin by CubeCoders Limited
[14:58:54] [Loader Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[14:58:54] [Loader Info] : Loaded CommonCorePlugin by CubeCoders Limited
[14:58:54] [Loader Info] : GenericModule requests dependency steamcmdplugin…
[14:58:54] [Loader Info] : Loaded steamcmdplugin by CubeCoders Limited
[14:58:54] [Loader Info] : GenericModule requests dependency RCONPlugin…
[14:58:54] [Loader Info] : Loaded RCONPlugin by CubeCoders Limited
[14:58:54] [Core Warning] : Unable to update setting node GenericModule.App.Ports.$GamePort - the target type of (List) is not supported.
[14:58:54] [Core Warning] : Unable to update setting node GenericModule.App.Ports.$ReservedPort - the target type of (List) is not supported.
[14:58:54] [Core Warning] : Unable to update setting node GenericModule.App.Ports.$BattlEyePort - the target type of (List) is not supported.
[14:58:54] [Core Warning] : Unable to update setting node GenericModule.App.Ports.$QueryPort - the target type of (List) is not supported.
[14:58:54] [Core Warning] : Unable to update setting node GenericModule.App.Ports.$RCONPort - the target type of (List) is not supported.
[14:58:54] [Core Info] : Licence Present: AMP Advanced Edition
[14:58:54] [FileManager Notice] : Using keypair with fingerprint removed
[14:58:54] [FileManager Info] : SFTP Server started on 192.168.10.5:2224
[14:58:54] [Webserver Info] : Websockets are enabled.
[14:58:55] [Webserver Info] : Webserver started on http://192.168.10.5:8081
[14:58:55] [Webserver Info] : RouterTimer@10Hz with 2 jobs started
[14:58:55] [Core Info] : Checking for AMP updates…
[14:58:55] [Core Info] : AMP is up to date.
[14:59:00] [Core Activity] : Authentication attempt for user admin from 192.168.10.5
[14:59:02] [Core Activity] : Authentication success
[14:59:02] [Core Warning] : Slow method invocation: Login took 2732ms to complete.
[14:59:02] [Core Warning] : Slow response: Core.Login took 2744ms to complete.
[14:59:04] [API:admin Activity] : Starting the application.
[14:59:04] [Generic:admin Info] : Merging config file ./dayz/223350/./serverDZ.cfg (Template) using Unicode (UTF-8) encoding.
[14:59:04] [Generic:admin Info] : Writing config file ./dayz/223350/./battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
[14:59:05] [Generic:admin Warning] : The application stopped unexpectedly. Exit code -1073741515
[14:59:08] [Generic:admin Info] : Merging config file ./dayz/223350/./serverDZ.cfg (Template) using Unicode (UTF-8) encoding.
[14:59:08] [Generic:admin Info] : Writing config file ./dayz/223350/./battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
[14:59:08] [Generic:admin Warning] : The application stopped unexpectedly. Exit code -1073741515
[14:59:11] [Generic:admin Info] : Merging config file ./dayz/223350/./serverDZ.cfg (Template) using Unicode (UTF-8) encoding.
[14:59:11] [Generic:admin Info] : Writing config file ./dayz/223350/./battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
[14:59:11] [Generic:admin Warning] : The application stopped unexpectedly. Exit code -1073741515
[14:59:14] [Generic:admin Info] : Merging config file ./dayz/223350/./serverDZ.cfg (Template) using Unicode (UTF-8) encoding.
[14:59:14] [Generic:admin Info] : Writing config file ./dayz/223350/./battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
[14:59:14] [Generic:admin Warning] : The application stopped unexpectedly. Exit code -1073741515
[14:59:17] [Generic:admin Info] : Merging config file ./dayz/223350/./serverDZ.cfg (Template) using Unicode (UTF-8) encoding.
[14:59:17] [Generic:admin Info] : Writing config file ./dayz/223350/./battleye/beserver_x64.cfg using Unicode (UTF-8) encoding.
[14:59:17] [Generic:admin Warning] : The application stopped unexpectedly. Exit code -1073741515
[14:59:17] [Generic:admin Warning] : Application failed to start 5 times, not restarting.
[15:09:46] [Core Activity] : Authentication attempt for user admin from 192.168.10.5
[15:09:48] [Core Activity] : Authentication success
[15:09:48] [Core Warning] : Slow method invocation: Login took 2515ms to complete.
[15:09:48] [Core Warning] : Slow response: Core.Login took 2516ms to complete.
- Attempted to reboot amp and VM the server is running on.
- Verified all settings and compared them to a working instance of same game on the server I am upgrading from.
- Deleted and reinstalled instance from scratch. Updated new instance without issue and re-verified all network settings.
