Startup Issue with DayZ (Experimental) - Constant restarts
Application DayZ (Experimental)
server restarts after a few seconds
My previous ticket seems to have died so I opened this with more info, this is a vanilla server, fresh install. Below is the log with a couple of questions alongside. Any ideas anyone? I know it’s Linux but other people have it working. If I wanted to use AMP on windows I could of used another manager for free.
9:16:47 [46] VehicleTruck01
9:16:47 Primary Spawner: “Vehicle”, active: yes, repeat: 1
9:16:47 [CE][Hive] :: Initializing of spawners done.
9:16:47 [CE][Hive] :: Init sequence finished.
9:16:47 Player connect enabled
9:16:47 Mission read.
9:16:47 Connected to Steam
9:16:47 Steam policy response
9:16:47 BattlEye Server: RCon admin #0 (127.0.0.1:52207) logged in Why so many RCon ???connections?
9:16:47 BattlEye Server: RCon admin #0 (127.0.0.1:52207) logged in ?
9:16:47 Warning: No components in dz\structures\industrial\harbour\pier_crane_rails.p3d:geometry
10:16:48
9:16:48 Bad uvSource None in dz\characters\pants\data\chainmail_leggings.rvmat stage 3 (Super, tex #(argb,8,8,3)color(0,0,0,0,mc))
10:16:49
9:16:49 Used memory: 1723927 KB
10:16:51
9:16:51 [IdleMode] Entering IN - save processed
9:16:51 Used memory: 1727274 KB
9:16:51 !!! No animSource for doors Land_Wreck_hb01_aban1_green :: door 3, check model+config
9:16:51 !!! No animSource for doors Land_Wreck_hb01_aban1_blue :: door 3, check model+config
10:17:37
9:17:37 String “STR_server_shutdown” listed twice in “Global” Where does this come from???
9:17:37 Localization not present: STR_DATE_FORMAT_SHORT
9:17:37 Localization not present: STR_TIME_FORMAT
9:17:37 Localization not present: STR_CONFIG_CONTROLLER_NORMAL_LOOK
9:17:37 Localization not present: STR_CONFIG_CONTROLLER_REVERSED_LOOK
9:17:37 Localization not present: STR_MP_VALIDERROR
9:17:37 Localization not present: STR_MP_CONNECTION_LOOSING
9:17:37 Localization not present: STR_MSG_MP_NO_PASSWORD
9:17:37 Localization not present: STR_MSG_LAUNCH_GAME
9:17:37 Localization not present: STR_LOAD_INIT
9:17:37 Localization not present: STR_LOAD_WORLD
9:17:37 Localization not present: STR_LOAD_GAME
9:17:37 Localization not present: STR_SAVE_GAME
9:17:37 Localization not present: STR_MP_DISCONNECT
9:17:37 Localization not present: STR_MP_CONNECTING
9:17:37 Localization not present: STR_MP_TIMEOUT
9:17:37 Localization not present: STR_DISP_CLIENT_TEXT_EDIT
9:17:37 Localization not present: STR_MP_LOGIN_QUEUE_FULL
  • Install Dayz experimental
  • Leave default settings
  • start server
