| Product | AMP ‘Decadeus’ v2.4.6.8 (Mainline) |
| Virtualization | Docker |
| Application | Counter-Strike 2 |
| Module | GenericModule |
| Current State | Failed |
When I try to start the cs2 server after updating and entering the gameserver token I get the error exit code 132. Every time I try to start the server again, amp shows that the server could not be started twice. In addition, I have not received any requests to log in for steam cmd.
AMP is in version Decadeus on a Debian 12 server
- Installed Amp cube coders
- create cs2 instance
- update the instance
- put the gamerserver login token in the config
- try to start the server
- get error message exit code 132
