Startup Issue with Counter-Strike 2 - CS2 server not downloading - error code 0x202
Application Counter-Strike 2
I am trying to create a Counter Strike 2 server. I create the instance and add my GSLT in the settings. Then I try to start the instance. However, it fails to download the server files. It gives me the error:
Error! App ‘730’ state is 0x202 after update job.
Which from what I understand is that the server doesn’t have enough storage to download. This is confusing because I have 30GB available according to my panel, and the server should only take up ~17GB.
  • Create instance
  • Add GSLT
  • Run server
You need roughly double the download space to actually do the download.
So you are saying that to download a 17GB server I need to have 34GB available?
More or less, that’s correct. Because it needs the temporary storage space as well as the finished result.
