Startup Issue with Counter-Strike 2 - counter strike 2 Instance wont run
Virtualization QEMU_KVM
Application Counter-Strike 2
Tried too update, to get it startet. After downloading and trying to update i got this message: This task could not be completed: Starting Counter-Strike 2… - - State: 3.
Please Help
  • Create a instance
  • Update the instance
  • Trying to start the instance
Hi Tom,
Your product version seems up to date, which is good. To diagnose this issue, we’ll need to have a look at the logs for your Counter-Strike 2 instance.
To view the logs for the instance, you can run the following command in your shell:
ampinstmgr lastlog [INSTANCE NAME]
Once you’ve got the output from that command, you can copy+paste the content here.
Secondly, did you get any specific error messages besides ‘This task could not be completed: Starting Counter-Strike 2… - - State: 3.’ when you tried to start the instance? Any additional details will help.
Hi
I found this log. Hope its the right one.
[19:25:20] [Logger Info] : Starting AMP version 2.4.6.6 (Decadeus), built 05/10/2023 11:56
[19:25:20] [Logger Info] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[19:25:20] [Logger Info] : Running in a QEMU KVM environment.
[19:25:20] [Logger Info] : OS: Linux / x86_64
[19:25:20] [Logger Info] : CPU: Common KVM processor (4C/4T)
[19:25:20] [Logger Info] : RAM: 7937MB
[19:25:20] [Logger Info] : AMP Instance ID: 2c7f2a99-ca09-40fa-96d7-84e782d8bb0b
[19:25:21] [Logger Info] : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
[19:25:21] [Logger Info] : Metrics publishing is enabled at udp://localhost:12820.
[19:25:21] [Logger Info] : Loaded FileManagerPlugin by CubeCoders Limited
[19:25:21] [Logger Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[19:25:21] [Logger Info] : Loaded WebRequestPlugin by CubeCoders Limited
[19:25:21] [Logger Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[19:25:21] [Logger Info] : Loaded CommonCorePlugin by CubeCoders Limited
[19:25:21] [Logger Info] : GenericModule requests dependency steamcmdplugin…
[19:25:21] [Logger Info] : Loaded steamcmdplugin by CubeCoders Limited
[19:25:21] [Logger Info] : GenericModule requests dependency RCONPlugin…
[19:25:21] [Logger Info] : Loaded RCONPlugin by CubeCoders Limited
[19:25:21] [Logger Warning] : No such setting node: GenericModule.App.Ports. - maybe the relevant plugin/module isn’t loaded?
[19:25:21] [Logger Info] : Licence Present: AMP Professional Edition
[19:25:21] [Logger Notice] : Using keypair with fingerprint qlucxWCW7BEfQ+E3A2NAGLMd0NJOWywchZcGktTWjEI=
[19:25:21] [Logger Info] : SFTP Server started on 192.168.1.3:2226
[19:25:21] [Webserver Info] : Websockets are enabled.
[19:25:21] [Logger Info] : Webserver started on http://192.168.1.3:8083
[19:25:21] [Logger Info] : RouterTimer@10Hz with 2 jobs started
[19:25:21] [Core Info] : Checking for AMP updates…
[19:25:21] [Logger Info] : Startup mode is StartApplication.
[19:25:21] [Core Info] : AMP is up to date.
[19:25:22] [Logger Warning] : The application stopped unexpectedly. Exit code 1
[19:25:22] [Logger Warning] : Application failed to start 0 times, not restarting.
Launcher Error: A CPU that supports the SSE4.2 instruction set is required.
[19:25:27] [Logger Activity] : Authentication attempt for user admin from 192.168.1.3
[19:25:28] [Core Activity] : Authentication success
[19:25:30] [API:admin Activity] : Starting the application.
[19:25:30] [Logger:admin Warning] : The application stopped unexpectedly. Exit code 1
[19:25:30] [Logger:admin Warning] : Application failed to start 0 times, not restarting.
[19:26:15] [Logger Activity] : Authentication attempt for user admin from 192.168.1.3
[19:26:15] [Core Activity] : Authentication success
[19:38:52] [Logger Activity] : Authentication attempt for user admin from 192.168.1.3
[19:38:52] [Core Activity] : Authentication success
[19:38:54] [API:admin Activity] : Updating the application.
[19:39:20] [API:admin Activity] : Updating the application.
Steam Console Client (c) Valve Corporation - version 1698778122
– type ‘quit’ to exit –
Loading Steam API…dlmopen steamservice.so failed: steamservice.so: cannot open shared object file: No such file or directory
OK
force_install_dir 730
Logging in user ‘tomogcamilla@get2net.dk’ to Steam Public…OK
Waiting for client config…OK
Waiting for user info…OK
app_update 730 validate
Update state (0x5) verifying install, progress: 0.00 (7 / 35210551328)
Update state (0x5) verifying install, progress: 2.44 (858778649 / 35210551328)
Update state (0x5) verifying install, progress: 5.44 (1915708292 / 35210551328)
Update state (0x5) verifying install, progress: 8.14 (2867128872 / 35210551328)
Update state (0x5) verifying install, progress: 10.85 (3818917350 / 35210551328)
Update state (0x5) verifying install, progress: 13.41 (4723050464 / 35210551328)
Update state (0x5) verifying install, progress: 15.97 (5623750232 / 35210551328)
Update state (0x5) verifying install, progress: 18.67 (6572887403 / 35210551328)
Update state (0x5) verifying install, progress: 21.36 (7519286012 / 35210551328)
Update state (0x5) verifying install, progress: 24.09 (8482803607 / 35210551328)
Update state (0x5) verifying install, progress: 26.80 (9435002207 / 35210551328)
Update state (0x5) verifying install, progress: 29.47 (10376421879 / 35210551328)
Update state (0x5) verifying install, progress: 32.17 (11327040305 / 35210551328)
Update state (0x5) verifying install, progress: 34.88 (12280177767 / 35210551328)
Update state (0x5) verifying install, progress: 37.62 (13247124139 / 35210551328)
Update state (0x5) verifying install, progress: 40.32 (14195926846 / 35210551328)
Update state (0x5) verifying install, progress: 43.05 (15158026078 / 35210551328)
Update state (0x5) verifying install, progress: 45.76 (16113426896 / 35210551328)
Update state (0x5) verifying install, progress: 48.50 (17076070080 / 35210551328)
Update state (0x5) verifying install, progress: 51.19 (18023738728 / 35210551328)
Update state (0x5) verifying install, progress: 53.94 (18992407340 / 35210551328)
Update state (0x5) verifying install, progress: 56.63 (19939000534 / 35210551328)
Update state (0x5) verifying install, progress: 58.32 (20533759837 / 35210551328)
Update state (0x5) verifying install, progress: 61.02 (21486533541 / 35210551328)
Update state (0x5) verifying install, progress: 63.77 (22453204210 / 35210551328)
Update state (0x5) verifying install, progress: 66.47 (23403709502 / 35210551328)
Update state (0x5) verifying install, progress: 69.20 (24365432643 / 35210551328)
Update state (0x5) verifying install, progress: 71.91 (25321117596 / 35210551328)
Update state (0x5) verifying install, progress: 74.62 (26274374247 / 35210551328)
Update state (0x5) verifying install, progress: 77.31 (27222117513 / 35210551328)
Update state (0x5) verifying install, progress: 80.06 (28187943209 / 35210551328)
Update state (0x5) verifying install, progress: 82.76 (29141327208 / 35210551328)
Update state (0x5) verifying install, progress: 85.50 (30105489434 / 35210551328)
Update state (0x5) verifying install, progress: 88.21 (31058825994 / 35210551328)
Update state (0x5) verifying install, progress: 90.83 (31982738475 / 35210551328)
Update state (0x5) verifying install, progress: 93.34 (32866878693 / 35210551328)
Update state (0x5) verifying install, progress: 95.80 (33730960078 / 35210551328)
Update state (0x5) verifying install, progress: 98.05 (34524789430 / 35210551328)
Success! App ‘730’ fully installed.
quit
[19:40:40] [steamcmdplugin:admin Info] : SteamCMD Update successful
[19:40:49] [API:admin Activity] : Updating the application.
OK
Update state (0x5) verifying install, progress: 0.01 (4194311 / 35210551328)
Update state (0x5) verifying install, progress: 2.92 (1027029963 / 35210551328)
Update state (0x5) verifying install, progress: 5.72 (2013107094 / 35210551328)
Update state (0x5) verifying install, progress: 8.41 (2960452136 / 35210551328)
Update state (0x5) verifying install, progress: 11.16 (3929017830 / 35210551328)
Update state (0x5) verifying install, progress: 13.87 (4882009372 / 35210551328)
Update state (0x5) verifying install, progress: 16.39 (5769600088 / 35210551328)
Update state (0x5) verifying install, progress: 19.06 (6712310548 / 35210551328)
Update state (0x5) verifying install, progress: 21.75 (7658348274 / 35210551328)
Update state (0x5) verifying install, progress: 24.44 (8604552103 / 35210551328)
Update state (0x5) verifying install, progress: 27.15 (9558705991 / 35210551328)
Update state (0x5) verifying install, progress: 29.80 (10492184725 / 35210551328)
Update state (0x5) verifying install, progress: 32.52 (11451908492 / 35210551328)
Update state (0x5) verifying install, progress: 35.22 (12399894987 / 35210551328)
Update state (0x5) verifying install, progress: 37.93 (13356827403 / 35210551328)
Update state (0x5) verifying install, progress: 40.62 (14302380033 / 35210551328)
[19:41:24] [Logger Activity] : Authentication attempt for user admin from 192.168.1.3
[19:41:24] [Core Activity] : Authentication success
Update state (0x5) verifying install, progress: 43.32 (15253557837 / 35210551328)
Update state (0x5) verifying install, progress: 46.01 (16198870576 / 35210551328)
Update state (0x5) verifying install, progress: 48.72 (17156076403 / 35210551328)
Update state (0x5) verifying install, progress: 51.41 (18101043554 / 35210551328)
Update state (0x5) verifying install, progress: 54.14 (19062667618 / 35210551328)
Update state (0x5) verifying install, progress: 56.77 (19987516667 / 35210551328)
Update state (0x5) verifying install, progress: 59.44 (20928663163 / 35210551328)
Update state (0x5) verifying install, progress: 62.16 (21886724229 / 35210551328)
Update state (0x5) verifying install, progress: 64.86 (22835941412 / 35210551328)
Update state (0x5) verifying install, progress: 67.57 (23793486136 / 35210551328)
Update state (0x5) verifying install, progress: 70.26 (24740111220 / 35210551328)
Update state (0x5) verifying install, progress: 72.99 (25698727002 / 35210551328)
Update state (0x5) verifying install, progress: 75.65 (26635495127 / 35210551328)
Update state (0x5) verifying install, progress: 78.34 (27583291148 / 35210551328)
Update state (0x5) verifying install, progress: 81.06 (28542494277 / 35210551328)
Update state (0x5) verifying install, progress: 83.75 (29488070603 / 35210551328)
Update state (0x5) verifying install, progress: 86.48 (30450162869 / 35210551328)
Update state (0x5) verifying install, progress: 89.17 (31396583773 / 35210551328)
Update state (0x5) verifying install, progress: 91.89 (32355389845 / 35210551328)
Update state (0x5) verifying install, progress: 94.57 (33300343017 / 35210551328)
Update state (0x5) verifying install, progress: 96.73 (34059350703 / 35210551328)
Update state (0x5) verifying install, progress: 99.27 (34954132156 / 35210551328)
quit
[19:42:08] [steamcmdplugin:admin Info] : SteamCMD Update successful
[19:42:11] [API:admin Activity] : Starting the application.
[19:42:11] [Logger:admin Warning] : The application stopped unexpectedly. Exit code 1
[19:42:11] [Logger:admin Warning] : Application failed to start 0 times, not restarting.
[19:42:15] [API:admin Activity] : Starting the application.
[19:42:15] [Logger:admin Warning] : The application stopped unexpectedly. Exit code 1
[19:42:15] [Logger:admin Warning] : Application failed to start 0 times, not restarting.
I didnt get any other messages besides the first one.
Hi Tom,
Thanks for providing the logs. The error message we're interested in is this one:
The error means that your processor architecture doesn't support SSE4.2 instructions, which are required for running the game. As you're using a virtual machine (QEMU KVM), it's likely you'll need to enable these instructions in your virtual machine settings.
If your physical processor supports SSE4.2 but your virtual machine doesn't, you will need to reconfigure your VM to enable SSE4.2 support. If your physical processor does not support SSE4.2, I'm afraid you won't be able to run the game on this machine.
The bot did an awesome job here! If you happen to be on Proxmox you should choose host as the CPU type. This is a common issue we’ve run into. :slight_smile:
Thanks for the additional info, IceOfWraith!
Tom, if you'd like to follow IceOfWraith's advice and you're using Proxmox as your hypervisor, changing the CPU type to 'host' in the VM's configuration might help. As he mentioned, this issue arises when the virtual machine doesn't have access to the host's full instruction set.
Thanks for the help, now i have somthing to go for
You're welcome, Tom! If you have more questions or run into any more issues, don't hesitate to post back. Good luck with your setup!
