| Product | AMP ‘Deimos’ v2.7.2.8 (Mainline) |
| Virtualization | Docker |
| Application | Counter-Strike 2 |
| Module | GenericModule |
| Current State | Failed |
I installed and updated the server.
Now i’m getting error while starting the server. Here’s my console feed :
SDR RelayNetworkStatus: avail=Attempting config=Attempting anyrelay=Not Attempted (Attempt #1 to fetch config (only-if-cached) from https://api.steampowered.com/ISteamApps/GetSDRConfig/v1?appid=730)
AuthStatus (invalid): Waiting (Waiting for Steam login)
Cannot create listen socket. Failed to bind socket. Error code 0x00000062.
- installed the whole cs2 server
- updated it fully
- pressed start and got error “Cannot create listen socket. Failed to bind socket. Error code 0x00000062.”
- Server tries to start 3 times then stops.
