Field
Value
Operating System
Product
AMP ‘Deimos’ v2.7.0.0 (Mainline)
Virtualization
Docker
Application
Counter-Strike 1.6
Module
GenericModule
Running in Container
Yes
Current State
Failed
This task could not be completed: Starting Counter-Strike 1.6… - - State: 3.
Application failed to start 2 times consecutively.
install cs 1.6 instance
configuration > update
enable rehlds
update > run
Console:
Error: /AMP/counter-strike/90/engine_i486.so: undefined symbol: SteamGameServer_Init
Unable to load engine, image is corrupt.
As the setting says: “Only works with the Steam Legacy server.”
Do you switch to the Steam Legacy server and install it?
Well, the server is installed automaticatlly and only then I can enable rehlds, and apparently upon updating the steamcmd is run again with beta legacy. However, this seems to be resulting in a botched installation, thus the problem at hand. I fixed it installing everything manually, the downside being the web gui is pretty useless now.
Doesn’t sound right, SteamCMD should change the files
Anyway you can create an instance with the startup mode set to “Do Nothing” and then this wouldn’t happen
system
Closed
April 14, 2026, 8:21pm
5
