Startup Issue with Counter-Strike 1.6 - Could not complete action
Application Counter-Strike 1.6
Could not complete action.
AMP was unable to start the application. Possible causes may include insufficient permissions to load the executable, or the file not being correctly flagged as being an executable file. Check AMPs logs for more information.
You probably need to chmod +x hlds_linux
Either that or you didn’t install the files as the amp user
As an aside, AMP already has options for Metamod-r, AMX Mod X and ReHLDS
done but reunion isnt working it shows fail load why?
No idea. This pack isn’t part of the template so you will need to figure it out yourself
