wagri
26 February 2025 11:28
1
Field
Value
Operating System
Product
AMP ‘Phobos’ v2.6.0.12 (Mainline)
Virtualization
Docker
Application
Conan Exiles
Module
GenericModule
Running in Container
Yes
Current State
Stopped
Error below
wine: Unhandled page fault on execute access to 0000000143CCC000 at address 0000000143CCC000 (thread 0104), starting debugger…
creation of the instance
installation of the game server
i starup the server after installation
Wine works fine in docker:
[2025.02.26-11.37.30:955][ 0]LogServerStats: Starting ServerStatReporter (Official server: 0)
[2025.02.26-11.37.30:959][ 0]LogServerStats: Startup report. StartupTime=59 Name=Conan Exiles Server - Powered by AMP Map=The Exiled Lands QueryPort=27030 Type=2 Region=0 MaxPlayers=40
It’s just in your case that you have issues. The likely cause is that the host you are running it on is configured properly for virtualisation.
What’s the system?
wagri
26 February 2025 12:19
3
so my system is running on Window Server 2022, with the docker engine installed.
I have two instance of Minecraft and they are running great, i have this error on any game that use wine with SteamCMD.
Where do i have to look to see what’s the issue ?
Right. You’ve unlikely to have much joy at the moment. The layers of virtualisation in docker on windows means permissions or something else along the way is not being handled correctly
By definition if you are running a server with wine it means you are running a windows exe. But rather than running it directly on windows (the normal native way) you are running windows to run WSL to run Linux to run Docker to run Wine to run the Windows exe
See how that can get messy?
wagri
26 February 2025 22:31
5
Yes i get it but the idea of virtualisation is to make sure it’s independant from the host that’s what i like.
So where do i have to look to solve the issue ?
It’s a known issue that has affected others and not really anything you can do
system
Closed
29 March 2025 02:01
7
