Startup Issue with Conan Exiles - Server won't start
Application Conan Exiles
Just created this instance for Conan Exiles and I keep getting this error on startup during the update phase: This task could not be completed: Running Update Tasks - - State: 3.
/bin/bash failed with exit code 127
  • Created the instance.
  • Updated the server.
  • Tried to start the server.
Given you are not running in docker, you likely don’t have the dependencies installed to run it, which you were told about when creating the instance (big orange box)
Cool. I have no idea what Docker is, what it does or how to get it. Is it part of AMP?
A quick google would tell you what it is and does.
It’s not part of AMP, it’s a separate application that can be used in AMP to run servers in an isolated environment.
