Exoric
April 12, 2026, 5:20am
1
Field
Value
Operating System
Windows - Windows 11 Home on x86_64
Product
AMP ‘Deimos’ v2.7.0.0 (Mainline)
Virtualization
None
Application
Conan Exiles
Module
GenericModule
Running in Container
No
Current State
Stopped
I am not sure how to set Savage Wilds as custom map. I did /Game/Mods/Savage_Wilds/Savage_Wilds as indicated but it keeps crashing. It doesn’t crash when I remove this.
Adding Savage wild
Removed the path and it doesn’t crash
added it back in and it crashes
Did you install the mod and update Mod List (both via AMP’s settings) as well?
Exoric
April 12, 2026, 6:14am
3
I thought I did, but do I need to put more than just ConanSandbox\Mods\2377569193\Savage_Wilds.pak in there?
I tried “C:\AMPDatastore\Instances\BelladonnaRP01\conan-exiles\443030\ConanSandbox\Mods\2377569193\Savage_Wilds.pak”
didn’t work
Just 2377569193\Savage_Wilds.pak , as the example says
But the mod also needs to be downloaded via steamcmd under Configuration>Updates>Steam Workshop
Exoric
April 12, 2026, 6:57am
5
I did download it already. I have the path wrong. I will correct that. Thank you!
I was also wondering if you knew how to change the query port?
Ports can be changed from the main AMP page (which shows all your instances), by clicking on the pencil icon on the instance tile and going to the Network and Ports tab
Exoric
April 12, 2026, 3:37pm
7
Thank you so much!!! I have been trying to figure that out for awhile now.
system
Closed
May 12, 2026, 3:38pm
8
