Startup Issue with Call of Duty MW 2- Call of Duty MW2 instance not recognizing Podman install
Field Value C
Operating System Linux - Ubuntu 26.04 on x86_64
Product AMP ‘Deimos’ v2.7.2.4 (Mainline)
Virtualization Proxmox
Application Call of Duty MW 2
Current State Not started
This task could not be completed: Starting Instance - Starting WTF CoD (WTFCoD01)… - State: 3.
Couldn’t find Podman or Docker - Podman is required to run containerized instances. The user running AMP (amp) must also be a member of the ‘docker’ group if using Docker.
  • installed podman using getamp installPodman (as root)
  • created Call of Duty Modern Warfare instance and configured instance to use container
  • could not proceeed - received error that podman was not found
  • edit/ also installed docker and added amp to the docker group. still does not see it.
