Startup Issue with Call of Duty: Modern Warfare 3 (2011) - Server not starting correctly
Product AMP ‘Phobos’ v2.6.2.4 (Mainline)
Application Call of Duty: Modern Warfare 3 (2011)
Current State Stopping
Got an issue with a new instance of Call Of Duty: Modern Warfare 3 (2011). As far as I can tell it installed, and started, but nothing was showing in the dedicated server panel (everything is open and forwarded correctly).
Suddenly, the master and the authentication ports went into ‘not listening’ status. So I attempted to reboot the instance for it to hang. Had to hard kill it.
Started it back up, server says it is running and all ports are listening, however the console output is blank and I am still not seeing it in the server list.
Also, the RAM and CPU usage is at 0% across the board.
I do not think it is actually running.
Is there an issue with the instance build?
My AMP build is sitting on Ubuntu 24.04.02 LTS.
Thanks in advance.
  • Starting server
  • Server says it is running but there is nothing in the console output
  • attempt to restart or stop server results in requiring to force kill it because it will not restart/stop
Looks like the monitoring is an issue for this one. But there is no console output on Linux in AMP from what I can see. Are the ports not showing as listening every time or just the one time? Stopping the server likely isn’t working properly due to the monitoring trouble. I’ll see if I can get the template fixed to address that.
Ports will all show as listening, then after a while the Authentication Port and the Master Server Port will go into ‘Not Listening’.
During install, I see this error:
src/clientdll/applicationmanager.cpp (6602) : Assertion Failed: BStartUpdateDepotsJob: 42750 missing required app 1493710
After the install is finished, I see this:
16:22:55
bash
16:22:55
wine: created the configuration directory ‘/AMP/call-of-dutymw3/.wine’
16:23:00
wine: configuration in L"/AMP/call-of-dutymw3/.wine" has been updated.
Then nothing after that.
System logs are pretty much empty, however I do see this:
[2025-07-25 20:33:49] Log session started
[2025-07-25 20:33:49] [0,0] Log session ended
And I see this in the other log:
[2025-07-25 20:23:18] Log session started
[2025-07-25 20:23:18] [0,0] SetSteamID( [A:1:0:0] )
[2025-07-25 20:23:18] [1,2] Connect() starting connection (eNetQOSLevelLow, 81.171.115.5:27017, UDP)
[2025-07-25 20:23:23] [1,2] ConnectFailed(‘Connection Failed’) (81.171.115.5:27017, UDP)
[2025-07-25 20:23:23] [0,0] StartAutoReconnect() will start in 3 seconds
[2025-07-25 20:23:26] [1,6] Connect() starting connection (eNetQOSLevelMedium, 81.171.115.6:27017, UDP)
[2025-07-25 20:23:31] [1,6] ConnectFailed(‘Connection Failed’) (81.171.115.6:27017, UDP)
[2025-07-25 20:23:31] [0,0] StartAutoReconnect() will start in 5 seconds
[2025-07-25 20:23:36] [1,8] Connect() starting connection (eNetQOSLevelMedium, 68.142.91.34:27017, UDP)
[2025-07-25 20:23:41] [1,8] ConnectFailed(‘Connection Failed’) (68.142.91.34:27017, UDP)
[2025-07-25 20:23:41] [0,0] StartAutoReconnect() will start in 7 seconds
[2025-07-25 20:23:48] [1,10] Connect() starting connection (eNetQOSLevelMedium, 208.111.171.82:27017, UDP)
[2025-07-25 20:23:53] [1,10] ConnectFailed(‘Connection Failed’) (208.111.171.82:27017, UDP)
[2025-07-25 20:23:53] [0,0] StartAutoReconnect() will start in 11 seconds
[2025-07-25 20:24:04] [1,11] Connect() starting connection (eNetQOSLevelMedium, 81.171.115.7:27017, TCP)
[2025-07-25 20:26:17] [1,11] ConnectFailed(‘Invalid State’) (81.171.115.7:27017, TCP)
[2025-07-25 20:26:17] [0,0] StartAutoReconnect() will start in 6 seconds
[2025-07-25 20:26:23] [1,13] Connect() starting connection (eNetQOSLevelMedium, 81.171.115.8:27017, TCP)
[2025-07-25 20:28:37] [1,13] ConnectFailed(‘Invalid State’) (81.171.115.8:27017, TCP)
[2025-07-25 20:28:37] [0,0] StartAutoReconnect() will start in 11 seconds
[2025-07-25 20:28:48] [1,16] Connect() starting connection (eNetQOSLevelMedium, 68.142.83.183:27017, UDP)
[2025-07-25 20:28:53] [1,16] ConnectFailed(‘Connection Failed’) (68.142.83.183:27017, UDP)
[2025-07-25 20:28:53] [0,0] StartAutoReconnect() will start in 23 seconds
[2025-07-25 20:29:16] [1,18] Connect() starting connection (eNetQOSLevelMedium, 79.141.174.8:27017, UDP)
[2025-07-25 20:29:21] [1,18] ConnectFailed(‘Connection Failed’) (79.141.174.8:27017, UDP)
[2025-07-25 20:29:21] [0,0] StartAutoReconnect() will start in 23 seconds
[2025-07-25 20:29:44] [1,20] Connect() starting connection (eNetQOSLevelMedium, 208.111.133.85:27017, UDP)
[2025-07-25 20:29:49] [1,20] ConnectFailed(‘Connection Failed’) (208.111.133.85:27017, UDP)
[2025-07-25 20:29:49] [0,0] StartAutoReconnect() will start in 11 seconds
[2025-07-25 20:30:00] [1,22] Connect() starting connection (eNetQOSLevelMedium, 72.165.61.188:27017, UDP)
[2025-07-25 20:30:05] [1,22] ConnectFailed(‘Connection Failed’) (72.165.61.188:27017, UDP)
[2025-07-25 20:30:05] [0,0] StartAutoReconnect() will start in 47 seconds
[2025-07-25 20:30:52] [1,23] Connect() starting connection (eNetQOSLevelMedium, 68.142.91.35:27017, TCP)
[2025-07-25 20:33:07] [1,23] ConnectFailed(‘Invalid State’) (68.142.91.35:27017, TCP)
[2025-07-25 20:33:07] [0,0] StartAutoReconnect() will start in 89 seconds
[2025-07-25 20:33:49] [0,0] LogOff()
Other than that, no console output, no other logs.
Got the main part addressed for monitoring. Try making a new instance and you should have the latest change. If that one has issues let me know.
