| Field |
Value |
| Operating System |
| Product |
AMP ‘Callisto’ v2.5.1.8 (Mainline) |
| Virtualization |
Docker |
| Application |
Call of Duty: Modern Warfare 3 (2011) |
| Module |
GenericModule |
| Running in Container |
Yes |
| Current State |
Failed |
wine: failed to open “./iw5mp_server.exe”: c0000135
X connection to :102 broken (explicit kill or server shutdown).
- Select COD MW3 (2011) from Menu
- Create Instance
- Errors occurs after validating Steamguard
Post your logs when you tried to update
[07:27:32] [Core Info/1] : Starting AMP version 2.5.1.8 (Callisto), built 17/09/2024 12:32
[07:27:32] [Core Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[07:27:32] [Core Info/1] : Running in a Docker environment.
[07:27:32] [Core Info/1] : OS: Linux / x86_64
[07:27:32] [Core Info/1] : CPU: Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz (16C/16T)
[07:27:32] [Core Info/1] : RAM: 48173MB
[07:27:32] [Core Info/1] : AMP Instance ID: 6eaf65c4-daea-441f-bd68-0df3aeb0231e
[07:27:33] [Loader Info/1] : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
[07:27:34] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[07:27:34] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[07:27:34] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[07:27:34] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[07:27:34] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[07:27:34] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[07:27:34] [Loader Info/1] : Loaded AnalyticsPlugin by CubeCoders Limited
[07:27:34] [Loader Info/1] : GenericModule requests dependency steamcmdplugin…
[07:27:34] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[07:27:34] [Loader Info/1] : GenericModule requests dependency RCONPlugin…
[07:27:34] [Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
[07:27:34] [Core Info/1] : Licence Present: AMP Professional Edition - Lifetime Licence
[07:27:34] [FileManager Notice/1] : No SSH keypair available for embedded server, generating new keypair…
[07:27:34] [FileManager Notice/1] : Generated new keypair with fingerprint Fipj6amSoOdibHghpEKVDIOQO2OFT7Lp7mP6fxsJVE4=
[07:27:35] [FileManager Notice/1] : Using keypair with fingerprint Fipj6amSoOdibHghpEKVDIOQO2OFT7Lp7mP6fxsJVE4=
[07:27:35] [FileManager Info/1] : SFTP Server started on 0.0.0.0:2227
[07:27:35] [Webserver Info/1] : Websockets are enabled.
[07:27:35] [Webserver Info/1] : Webserver started on http://127.0.0.1:8084
[07:27:35] [Logger Info/14] : RouterTimer@10Hz with 2 jobs started
[07:27:35] [Core Info/4] : Startup mode is UpdateAndStart.
[07:27:35] [Core Info/10] : Checking for AMP updates…
[07:27:36] [Core Info/5] : AMP is up to date.
[07:27:48] [Core Activity/4] : Authentication attempt for user admin from 127.0.0.1
[07:27:48] [Core Activity/11] : Authentication success
[07:27:52] [API:admin Activity/10] : Starting the application.
[07:27:56] [API:admin Activity/17] : Updating the application.
ILocalize::AddFile() failed to load file “public/steambootstrapper_english.txt”.
[ 0%] Checking for available update…
[----] Downloading update (0 of 48918 KB)…
[ 0%] Downloading update (0 of 48918 KB)…
[ 0%] Downloading update (3181 of 48918 KB)…
[ 6%] Downloading update (6926 of 48918 KB)…
[ 14%] Downloading update (9475 of 48918 KB)…
[ 19%] Downloading update (12203 of 48918 KB)…
[ 24%] Downloading update (14690 of 48918 KB)…
[ 30%] Downloading update (17175 of 48918 KB)…
[ 35%] Downloading update (19498 of 48918 KB)…
[ 39%] Downloading update (21970 of 48918 KB)…
[ 44%] Downloading update (24435 of 48918 KB)…
[ 49%] Downloading update (27047 of 48918 KB)…
[ 55%] Downloading update (29517 of 48918 KB)…
[ 60%] Downloading update (31982 of 48918 KB)…
[ 65%] Downloading update (34455 of 48918 KB)…
[ 70%] Downloading update (36932 of 48918 KB)…
[ 75%] Downloading update (39396 of 48918 KB)…
[ 80%] Downloading update (41376 of 48918 KB)…
[ 84%] Downloading update (43511 of 48918 KB)…
[ 88%] Downloading update (44748 of 48918 KB)…
[ 91%] Downloading update (45993 of 48918 KB)…
[ 94%] Downloading update (47237 of 48918 KB)…
[ 96%] Downloading update (48482 of 48918 KB)…
[ 99%] Downloading update (48918 of 48918 KB)…
[100%] Download Complete.
[----] Applying update…
[----] Extracting package…
[----] Installing update…
[----] Cleaning up…
[----] Update complete, launching…
[ 0%] Downloading update…
[----] Download complete.
[----] Cleaning up…
[----] Update complete, launching Steamcmd…
[07:28:11] [steamcmdplugin:admin Warning/17] : steamcmd.sh[82]: Restarting steamcmd by request…
UpdateUI: skip show logoRedirecting stderr to ‘/home/amp/Steam/logs/stderr.txt’
UpdateUI: skip show logoSteam Console Client (c) Valve Corporation - version 1726605427
– type ‘quit’ to exit –
Loading Steam API…IPC function call IClientUtils::GetSteamRealm took too long: 66 msec
IPC function call IClientUtils::GetConnectedUniverse took too long: 54 msec
IPC function call IClientUtils::GetIPCountry took too long: 50 msec
IPC function call IClientUtils::GetServerRealTime took too long: 50 msec
OK
force_install_dir “42750”
Cached credentials not found.
password:
Proceeding with login using username/password.
Logging in user ‘yabadabadoooooo’ [U:1:0] to Steam Public…
Enter the current code from your Steam Guard Mobile Authenticator app
[07:28:16] [steamcmdplugin:admin Warning/18] : Steam Guard needed!
Two-factor code:OK
Waiting for client config…OK
Waiting for user info…OK
“@sSteamCmdForcePlatformType” = “windows”
app_update 42750 validate
IPC function call IClientAppManager::GetUpdateInfo took too long: 55 msec
Error! App ‘42750’ state is 0x202 after update job.
quit
CWorkThreadPool::~CWorkThreadPool: work processing queue not empty: 1 items discarded.
[07:28:57] [steamcmdplugin:admin Warning/12] : SteamCMD last reported exit state was OutOfDiskSpace
wine: created the configuration directory ‘/AMP/call-of-dutymw3/.wine’
wine: configuration in L"/AMP/call-of-dutymw3/.wine" has been updated.
[07:29:48] [Generic:admin Error/12] : Exception setting up backup exclusions.
[07:29:48] [Core:admin Error/12] : UnauthorizedAccessException
[07:29:48] [Core:admin Error/12] : [0] (UnauthorizedAccessException) : Access to the path “/AMP/call-of-dutymw3/.wine/dosdevices/z:/.autoExclude” is denied.
[07:29:48] [Core:admin Error/12] : at IO.FileStream…ctor (String path, IO.FileMode mode, IO.FileAccess access, IO.FileShare share, Int32 bufferSize, Boolean anonymous, IO.FileOptions options)
at IO.FileStream…ctor (String path, IO.FileMode mode, IO.FileAccess access, IO.FileShare share, Int32 bufferSize, IO.FileOptions options)
at (wrapper remoting-invoke-with-check) IO.FileStream…ctor(string,IO.FileMode,IO.FileAccess,IO.FileShare,int,IO.FileOptions)
at IO.StreamWriter…ctor (String path, Boolean append, Text.Encoding encoding, Int32 bufferSize)
at IO.StreamWriter…ctor (String path)
at (wrapper remoting-invoke-with-check) IO.StreamWriter…ctor(string)
at IO.File.WriteAllLines (String path, Collections.Generic.IEnumerable`1[T] contents)
at GenericModule.GenericApp.SetupSmartBackupExclusions (IO.DirectoryInfo Parent, Int32 MaxDepth)
[07:29:48] [Generic:admin Warning/12] : Tried to merge config file ./call-of-dutymw3/42750/admin/server.cfg but the file does not exist.
[07:29:48] [Generic:admin Info/12] : Application started in 0 seconds.
[07:29:51] [Generic:admin Warning/20] : The application stopped unexpectedly. Exit code 53
[07:29:54] [Generic:admin Warning/19] : Tried to merge config file ./call-of-dutymw3/42750/admin/server.cfg but the file does not exist.
[07:29:54] [Generic:admin Info/19] : Application started in 0 seconds.
[07:29:58] [Generic:admin Warning/4] : The application stopped unexpectedly. Exit code 53
[07:30:01] [Generic:admin Warning/20] : Tried to merge config file ./call-of-dutymw3/42750/admin/server.cfg but the file does not exist.
[07:30:01] [Generic:admin Info/20] : Application started in 0 seconds.
[07:30:04] [Generic:admin Warning/10] : The application stopped unexpectedly. Exit code 53
[07:30:07] [Generic:admin Warning/16] : Tried to merge config file ./call-of-dutymw3/42750/admin/server.cfg but the file does not exist.
[07:30:07] [Generic:admin Info/16] : Application started in 0 seconds.
[07:30:11] [Generic:admin Warning/7] : The application stopped unexpectedly. Exit code 53
[07:30:14] [Generic:admin Warning/11] : Tried to merge config file ./call-of-dutymw3/42750/admin/server.cfg but the file does not exist.
[07:30:14] [Generic:admin Info/11] : Application started in 0 seconds.
[07:30:17] [Generic:admin Warning/18] : The application stopped unexpectedly. Exit code 53
[07:30:17] [Generic:admin Warning/18] : Application failed to start 5 times, not restarting.
[08:27:22] [Core Activity/5] : Authentication attempt for user admin from 127.0.0.1
[08:27:22] [Core Activity/10] : Authentication success
[08:27:25] [API:admin Activity/86] : Starting the application.
[08:27:26] [Generic:admin Warning/86] : Tried to merge config file ./call-of-dutymw3/42750/admin/server.cfg but the file does not exist.
[08:27:26] [Generic:admin Info/86] : Application started in 0 seconds.
[08:27:29] [Generic:admin Warning/12] : The application stopped unexpectedly. Exit code 53
[08:27:32] [Generic:admin Warning/82] : Tried to merge config file ./call-of-dutymw3/42750/admin/server.cfg but the file does not exist.
[08:27:32] [Generic:admin Info/82] : Application started in 0 seconds.
[08:27:32] [API:admin Activity/5] : Starting the application.
[08:27:35] [Generic:admin Warning/16] : The application stopped unexpectedly. Exit code 53
[08:27:38] [Generic:admin Warning/12] : Tried to merge config file ./call-of-dutymw3/42750/admin/server.cfg but the file does not exist.
[08:27:38] [Generic:admin Info/12] : Application started in 0 seconds.
[08:27:42] [Generic:admin Warning/23] : The application stopped unexpectedly. Exit code 53
[08:27:45] [Generic:admin Warning/23] : Tried to merge config file ./call-of-dutymw3/42750/admin/server.cfg but the file does not exist.
[08:27:45] [Generic:admin Info/23] : Application started in 0 seconds.
[08:27:49] [Generic:admin Warning/84] : The application stopped unexpectedly. Exit code 53
[08:27:52] [Generic:admin Warning/5] : Tried to merge config file ./call-of-dutymw3/42750/admin/server.cfg but the file does not exist.
[08:27:52] [Generic:admin Info/5] : Application started in 0 seconds.
[08:27:55] [Generic:admin Warning/85] : The application stopped unexpectedly. Exit code 53
[08:27:55] [Generic:admin Warning/85] : Application failed to start 5 times, not restarting.
[08:27:56] [Core:admin Warning/86] : Slow method invocation: Start took 30567ms to complete.
[08:27:56] [Core:admin Warning/86] : Slow response: Core.Start took 30574ms to complete.
[08:28:37] [Core Activity/82] : Authentication attempt for user admin from 127.0.0.1
[08:28:38] [Core Activity/5] : Authentication success
You don’t have enough disk space to install the server
system
Closed
5
