Startup Issue with Call of Duty: Black Ops - Black Ops Plutonium crashes in first run
Application Call of Duty: Black Ops
Unable to complete task
This task could not be completed: Running Update Tasks - - State: 3.
/bin/bash failed with exit code 1
    1. I configured all the parameters
    1. I have the original game on Steam
    1. I logged in successfully.
Need full logs from amp, can’t help otherwise
Where are the logs? I can’t find them…
Click return to instance. Click on the folder icon in your instance. Go into AMP_Logs
I have this 2 logs. Server goes down when attempts to execute bash, I think…
Log 1:
[11:42:14] [Program Info/1] : Starting AMP version 2.6.2.0 (Phobos), built 13/06/2025 03:46
[11:42:14] [Program Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[11:42:14] [Core Info/1] : Loading configuration from provisionargs.kvp…
[11:42:14] [Program Info/1] : Running in a Docker environment.
[11:42:14] [Program Info/1] : OS: Linux / x86_64
[11:42:14] [Program Info/1] : CPU: Intel(R) Core™ i5-6500T CPU @ 2.50GHz (4C/4T)
[11:42:14] [Program Info/1] : RAM: 15868MB
[11:42:14] [Program Info/1] : AMP Instance ID: 5af10a27-8cbd-4775-b8d8-ee6875c10156
[11:42:14] [Program Info/1] : Performing first-time setup for this instance, please wait…
[11:42:15] [Core Info/1] : Loaded GenericModule version 2.6.2 by CubeCoders Limited
[11:42:15] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[11:42:15] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[11:42:15] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[11:42:15] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[11:42:16] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[11:42:16] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[11:42:16] [Loader Info/1] : Loaded AnalyticsPlugin by CubeCoders Limited
[11:42:16] [System Error/9] : Missing plugin/assembly: MaxMind.Db (/AMP/Plugins/MaxMind.Db/MaxMind.Db.dll) for
[11:42:16] [Loader Info/1] : GenericModule requests dependency steamcmdplugin…
[11:42:16] [System Info/9] : GeoIP database not found, downloading…
[11:42:16] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[11:42:16] [Loader Info/1] : GenericModule requests dependency RCONPlugin…
[11:42:16] [Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
[11:42:16] [Core Warning/1] : No such setting node: GenericModule.Meta.Prerequsites - maybe the relevant plugin/module isn’t loaded?
[11:42:16] [Core Warning/1] : No such setting node: GenericModule.Console.ActivateLogRegex - maybe the relevant plugin/module isn’t loaded?
[11:42:16] [Core Info/1] : Performing activation, please wait…
[11:42:17] [Core Info/1] : Activated successfully.
[11:42:17] [Core Info/1] : Licence Present: AMP Standard Edition - Lifetime Licence
[11:42:17] [Program Info/1] : AMP has completed its first time setup. Saving settings and shutting down.
Log 2:
[11:42:22] [Program Info/1] : Starting AMP version 2.6.2.0 (Phobos), built 13/06/2025 03:46
[11:42:22] [Program Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[11:42:22] [Program Info/1] : Running in a Docker environment.
[11:42:22] [Program Info/1] : OS: Linux / x86_64
[11:42:22] [Program Info/1] : CPU: Intel(R) Core™ i5-6500T CPU @ 2.50GHz (4C/4T)
[11:42:22] [Program Info/1] : RAM: 15868MB
[11:42:22] [Program Info/1] : AMP Instance ID: 5af10a27-8cbd-4775-b8d8-ee6875c10156
[11:42:23] [Core Info/1] : Loaded GenericModule version 2.6.2 by CubeCoders Limited
[11:42:23] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[11:42:23] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[11:42:23] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[11:42:23] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[11:42:23] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[11:42:23] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[11:42:24] [Loader Info/1] : Loaded AnalyticsPlugin by CubeCoders Limited
[11:42:24] [System Error/7] : Missing plugin/assembly: MaxMind.Db (/AMP/Plugins/MaxMind.Db/MaxMind.Db.dll) for
[11:42:24] [Loader Info/1] : GenericModule requests dependency steamcmdplugin…
[11:42:24] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[11:42:24] [Loader Info/1] : GenericModule requests dependency RCONPlugin…
[11:42:24] [Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
[11:42:24] [Core Info/1] : Licence Present: AMP Standard Edition - Lifetime Licence
[11:42:24] [FileManager Notice/1] : No SSH keypair available for embedded server, generating new keypair…
[11:42:24] [FileManager Notice/1] : Generated new keypair with fingerprint b7yZSy3UQ3ZfZJO++i2NvJvltCAMi+cUT4DtbUG4138=
[11:42:24] [Loader Notice/1] : Using keypair with fingerprint b7yZSy3UQ3ZfZJO++i2NvJvltCAMi+cUT4DtbUG4138=
[11:42:24] [Loader Info/1] : SFTP Server started on 0.0.0.0:2227
[11:42:25] [Core Info/1] : Webserver started on http://0.0.0.0:8084
[11:42:25] [System Info/9] : Checking for AMP updates…
[11:42:25] [System Info/7] : AMP is up to date.
[11:42:27] [System Activity/10] : Authentication attempt for user elessar from 127.0.0.1
[11:42:27] [System Activity/10] : Authentication success
[11:44:00] [API:elessar Activity/11] : Changing setting Meta.GenericModule.ServerKey to SUt0CCyWttkj49fPRdEN87Rx5qPLnYBH
[11:44:00] [Generic:elessar Warning/11] : Tried to merge config file ./call-of-dutybo1/server/Plutonium/storage/t5/dedicated.cfg but the file does not exist.
[11:44:00] [Generic:elessar Warning/11] : Tried to merge config file ./call-of-dutybo1/server/Plutonium/storage/t5/dedicated_sp.cfg but the file does not exist.
[11:44:19] [API:elessar Activity/22] : Changing setting Meta.GenericModule.sv_disableClientConsole to True
[11:44:19] [Generic:elessar Warning/22] : Tried to merge config file ./call-of-dutybo1/server/Plutonium/storage/t5/dedicated.cfg but the file does not exist.
[11:44:19] [Generic:elessar Warning/22] : Tried to merge config file ./call-of-dutybo1/server/Plutonium/storage/t5/dedicated_sp.cfg but the file does not exist.
[11:44:24] [API:elessar Activity/22] : Changing setting Meta.GenericModule.g_fixBulletDamageDupe to True
[11:44:24] [Generic:elessar Warning/22] : Tried to merge config file ./call-of-dutybo1/server/Plutonium/storage/t5/dedicated.cfg but the file does not exist.
[11:44:24] [Generic:elessar Warning/22] : Tried to merge config file ./call-of-dutybo1/server/Plutonium/storage/t5/dedicated_sp.cfg but the file does not exist.
[11:44:34] [API:elessar Activity/22] : Changing setting Meta.GenericModule.voice_deadChat to False
[11:44:34] [Generic:elessar Warning/22] : Tried to merge config file ./call-of-dutybo1/server/Plutonium/storage/t5/dedicated.cfg but the file does not exist.
[11:44:34] [Generic:elessar Warning/22] : Tried to merge config file ./call-of-dutybo1/server/Plutonium/storage/t5/dedicated_sp.cfg but the file does not exist.
[11:44:53] [API:elessar Activity/16] : Changing setting Meta.GenericModule.g_fix_viewkick_dupe to True
[11:44:53] [Generic:elessar Warning/16] : Tried to merge config file ./call-of-dutybo1/server/Plutonium/storage/t5/dedicated.cfg but the file does not exist.
[11:44:53] [Generic:elessar Warning/16] : Tried to merge config file ./call-of-dutybo1/server/Plutonium/storage/t5/dedicated_sp.cfg but the file does not exist.
[11:45:19] [Core:elessar Activity/21] : Starting the application.
[11:45:29] [Core:elessar Activity/7] : Updating the application.
ILocalize::AddFile() failed to load file “public/steambootstrapper_english.txt”.
[ 0%] Checking for available update…
[----] Downloading update (0 of 52312 KB)…
[ 0%] Downloading update (0 of 52312 KB)…
[ 0%] Downloading update (1250 of 52312 KB)…
[ 2%] Downloading update (3485 of 52312 KB)…
[ 6%] Downloading update (5607 of 52312 KB)…
[ 10%] Downloading update (7343 of 52312 KB)…
[ 14%] Downloading update (8654 of 52312 KB)…
[ 16%] Downloading update (9832 of 52312 KB)…
[ 18%] Downloading update (11102 of 52312 KB)…
[ 21%] Downloading update (12273 of 52312 KB)…
[ 23%] Downloading update (13448 of 52312 KB)…
[ 25%] Downloading update (14633 of 52312 KB)…
[ 27%] Downloading update (15818 of 52312 KB)…
[ 30%] Downloading update (17105 of 52312 KB)…
[ 32%] Downloading update (18292 of 52312 KB)…
[ 34%] Downloading update (19486 of 52312 KB)…
[ 37%] Downloading update (20652 of 52312 KB)…
[ 39%] Downloading update (21819 of 52312 KB)…
[ 41%] Downloading update (23103 of 52312 KB)…
[ 44%] Downloading update (24278 of 52312 KB)…
[ 46%] Downloading update (25447 of 52312 KB)…
[ 48%] Downloading update (26620 of 52312 KB)…
[ 50%] Downloading update (27811 of 52312 KB)…
[ 53%] Downloading update (29130 of 52312 KB)…
[ 55%] Downloading update (30287 of 52312 KB)…
[ 57%] Downloading update (31448 of 52312 KB)…
[ 60%] Downloading update (32629 of 52312 KB)…
[ 62%] Downloading update (33786 of 52312 KB)…
[ 64%] Downloading update (35050 of 52312 KB)…
[ 67%] Downloading update (36206 of 52312 KB)…
[ 69%] Downloading update (37382 of 52312 KB)…
[ 71%] Downloading update (38531 of 52312 KB)…
[ 73%] Downloading update (39660 of 52312 KB)…
[ 75%] Downloading update (40933 of 52312 KB)…
[ 78%] Downloading update (42079 of 52312 KB)…
[ 80%] Downloading update (43238 of 52312 KB)…
[ 82%] Downloading update (44399 of 52312 KB)…
[ 84%] Downloading update (45548 of 52312 KB)…
[ 87%] Downloading update (46811 of 52312 KB)…
[ 89%] Downloading update (47687 of 52312 KB)…
[ 91%] Downloading update (48299 of 52312 KB)…
[ 92%] Downloading update (48856 of 52312 KB)…
[ 93%] Downloading update (48958 of 52312 KB)…
[ 93%] Downloading update (49466 of 52312 KB)…
[ 94%] Downloading update (50106 of 52312 KB)…
[ 95%] Downloading update (50675 of 52312 KB)…
[ 96%] Downloading update (51232 of 52312 KB)…
[ 97%] Downloading update (51855 of 52312 KB)…
[ 99%] Downloading update (52312 of 52312 KB)…
[100%] Download Complete.
[----] Applying update…
[----] Extracting package…
[----] Installing update…
[----] Cleaning up…
[----] Update complete, launching…
[ 0%] Downloading update…
[----] Download complete.
[----] Cleaning up…
[----] Update complete, launching Steamcmd…
UpdateUI: skip show logo
[11:45:51] [System:elessar Warning/16] : steamcmd.sh[113]: Restarting steamcmd by request…
Steam Console Client (c) Valve Corporation - version 1747702063
– type ‘quit’ to exit –
Loading Steam API…IPC function call IClientUtils::GetConnectedUniverse took too long: 52 msec
OK
force_install_dir “/AMP/call-of-dutybo1/server/T5”
Cached credentials not found.
password:
Proceeding with login using username/password.
Logging in user ‘eltiocharliexd’ [U:1:0] to Steam Public…This account is protected by a Steam Guard mobile authenticator.
Please confirm the login in the Steam Mobile app on your phone.
[11:45:56] [steamcmdplugin:elessar Warning/7] : Steam Guard needed!
Waiting for confirmation…
Waiting for confirmation…OK
Waiting for client config…OK
Waiting for user info…OK
@sSteamCmdForcePlatformType” = “windows”
app_update 42700 validate
Update state (0x61) downloading, progress: 0.00 (0 / 10684442455)
Update state (0x61) downloading, progress: 0.58 (61871611 / 10684442455)
Update state (0x61) downloading, progress: 1.39 (148903419 / 10684442455)
Update state (0x61) downloading, progress: 2.17 (231747891 / 10684442455)
Update state (0x61) downloading, progress: 2.93 (313524946 / 10684442455)
Update state (0x61) downloading, progress: 3.76 (401433434 / 10684442455)
Update state (0x61) downloading, progress: 4.52 (483375868 / 10684442455)
Update state (0x61) downloading, progress: 5.31 (566935746 / 10684442455)
Update state (0x61) downloading, progress: 6.03 (644689340 / 10684442455)
Update state (0x61) downloading, progress: 6.81 (727851542 / 10684442455)
Update state (0x61) downloading, progress: 7.59 (810444961 / 10684442455)
Update state (0x61) downloading, progress: 8.37 (893819084 / 10684442455)
Update state (0x61) downloading, progress: 8.90 (950743212 / 10684442455)
Update state (0x61) downloading, progress: 9.48 (1012661964 / 10684442455)
Update state (0x61) downloading, progress: 9.98 (1066813868 / 10684442455)
Update state (0x61) downloading, progress: 10.38 (1108811422 / 10684442455)
Update state (0x61) downloading, progress: 11.05 (1180114590 / 10684442455)
Update state (0x61) downloading, progress: 11.68 (1248030850 / 10684442455)
Update state (0x61) downloading, progress: 12.38 (1322479746 / 10684442455)
Update state (0x61) downloading, progress: 13.08 (1397948665 / 10684442455)
Update state (0x61) downloading, progress: 13.85 (1479737593 / 10684442455)
Update state (0x61) downloading, progress: 14.57 (1557144208 / 10684442455)
Update state (0x61) downloading, progress: 15.25 (1629105559 / 10684442455)
Update state (0x61) downloading, progress: 15.96 (1705651607 / 10684442455)
Update state (0x61) downloading, progress: 16.74 (1788295663 / 10684442455)
Update state (0x61) downloading, progress: 17.40 (1859364211 / 10684442455)
Update state (0x61) downloading, progress: 18.13 (1936852762 / 10684442455)
Update state (0x61) downloading, progress: 18.90 (2019690266 / 10684442455)
Update state (0x61) downloading, progress: 19.52 (2085466345 / 10684442455)
Update state (0x61) downloading, progress: 20.30 (2169352425 / 10684442455)
Update state (0x61) downloading, progress: 21.02 (2245898473 / 10684442455)
Update state (0x61) downloading, progress: 21.69 (2316967990 / 10684442455)
Update state (0x61) downloading, progress: 22.44 (2397708342 / 10684442455)
Update state (0x61) downloading, progress: 23.08 (2465830029 / 10684442455)
Update state (0x61) downloading, progress: 23.83 (2546362585 / 10684442455)
Update state (0x61) downloading, progress: 24.58 (2626054361 / 10684442455)
Update state (0x61) downloading, progress: 25.28 (2700503257 / 10684442455)
Update state (0x61) downloading, progress: 25.99 (2777049305 / 10684442455)
Update state (0x61) downloading, progress: 26.72 (2854643929 / 10684442455)
Update state (0x61) downloading, progress: 27.39 (2926995673 / 10684442455)
Update state (0x61) downloading, progress: 28.15 (3007609780 / 10684442455)
Update state (0x61) downloading, progress: 28.91 (3088350132 / 10684442455)
Update state (0x61) downloading, progress: 29.56 (3157838585 / 10684442455)
Update state (0x61) downloading, progress: 30.34 (3241470241 / 10684442455)
Update state (0x61) downloading, progress: 31.11 (3324307745 / 10684442455)
Update state (0x61) downloading, progress: 32.06 (3425805428 / 10684442455)
Update state (0x61) downloading, progress: 33.01 (3527012155 / 10684442455)
Update state (0x61) downloading, progress: 33.91 (3623481147 / 10684442455)
Update state (0x61) downloading, progress: 34.86 (3724201216 / 10684442455)
Update state (0x61) downloading, progress: 35.89 (3834972519 / 10684442455)
Update state (0x61) downloading, progress: 36.69 (3920468412 / 10684442455)
Update state (0x61) downloading, progress: 37.73 (4031617468 / 10684442455)
Update state (0x61) downloading, progress: 38.63 (4127623165 / 10684442455)
Update state (0x61) downloading, progress: 39.49 (4219305349 / 10684442455)
Update state (0x61) downloading, progress: 40.39 (4315912890 / 10684442455)
Update state (0x61) downloading, progress: 41.32 (4415200970 / 10684442455)
Update state (0x61) downloading, progress: 42.36 (4525544427 / 10684442455)
Update state (0x61) downloading, progress: 43.31 (4627280875 / 10684442455)
Update state (0x61) downloading, progress: 44.21 (4723570519 / 10684442455)
Update state (0x61) downloading, progress: 45.06 (4814735522 / 10684442455)
Update state (0x61) downloading, progress: 45.82 (4895595647 / 10684442455)
Update state (0x61) downloading, progress: 46.62 (4980880089 / 10684442455)
Update state (0x61) downloading, progress: 47.36 (5060589313 / 10684442455)
Update state (0x61) downloading, progress: 48.07 (5136539943 / 10684442455)
Update state (0x61) downloading, progress: 48.77 (5210464904 / 10684442455)
Update state (0x61) downloading, progress: 49.50 (5288962728 / 10684442455)
Update state (0x61) downloading, progress: 50.14 (5357120168 / 10684442455)
Update state (0x61) downloading, progress: 50.79 (5426326184 / 10684442455)
Update state (0x61) downloading, progress: 51.50 (5502112328 / 10684442455)
Update state (0x61) downloading, progress: 52.24 (5581804104 / 10684442455)
Update state (0x61) downloading, progress: 52.98 (5660462696 / 10684442455)
Update state (0x61) downloading, progress: 53.66 (5733123944 / 10684442455)
Update state (0x61) downloading, progress: 54.34 (5805511624 / 10684442455)
Update state (0x61) downloading, progress: 55.09 (5885786952 / 10684442455)
Update state (0x61) downloading, progress: 55.81 (5962699080 / 10684442455)
Update state (0x61) downloading, progress: 56.52 (6039255944 / 10684442455)
Update state (0x61) downloading, progress: 57.23 (6115214728 / 10684442455)
Update state (0x61) downloading, progress: 57.97 (6193857928 / 10684442455)
Update state (0x61) downloading, progress: 58.64 (6265417544 / 10684442455)
Update state (0x61) downloading, progress: 59.44 (6351127816 / 10684442455)
Update state (0x61) downloading, progress: 60.10 (6421449672 / 10684442455)
Update state (0x61) downloading, progress: 60.84 (6500104520 / 10684442455)
Update state (0x61) downloading, progress: 61.54 (6575193672 / 10684442455)
Update state (0x61) downloading, progress: 62.23 (6649110504 / 10684442455)
Update state (0x61) downloading, progress: 63.00 (6731559912 / 10684442455)
Update state (0x61) downloading, progress: 63.71 (6807484936 / 10684442455)
Update state (0x61) downloading, progress: 64.42 (6883039656 / 10684442455)
Update state (0x61) downloading, progress: 65.13 (6958537128 / 10684442455)
Update state (0x61) downloading, progress: 65.83 (7033475784 / 10684442455)
Update state (0x61) downloading, progress: 66.54 (7108957992 / 10684442455)
Update state (0x61) downloading, progress: 67.20 (7180288776 / 10684442455)
Update state (0x61) downloading, progress: 67.95 (7260065704 / 10684442455)
Update state (0x61) downloading, progress: 68.68 (7338018344 / 10684442455)
Update state (0x61) downloading, progress: 69.41 (7416530824 / 10684442455)
Update state (0x61) downloading, progress: 70.09 (7488867080 / 10684442455)
Update state (0x61) downloading, progress: 70.84 (7568725416 / 10684442455)
Update state (0x61) downloading, progress: 71.51 (7640343624 / 10684442455)
Update state (0x61) downloading, progress: 71.97 (7689631287 / 10684442455)
Update state (0x61) downloading, progress: 72.92 (7791343159 / 10684442455)
Update state (0x61) downloading, progress: 73.88 (7894103607 / 10684442455)
Update state (0x61) downloading, progress: 74.86 (7998446837 / 10684442455)
Update state (0x61) downloading, progress: 75.90 (8109896603 / 10684442455)
Update state (0x61) downloading, progress: 76.82 (8207925605 / 10684442455)
Update state (0x61) downloading, progress: 77.77 (8309637477 / 10684442455)
Update state (0x61) downloading, progress: 78.71 (8409252197 / 10684442455)
Update state (0x61) downloading, progress: 79.66 (8511494363 / 10684442455)
Update state (0x61) downloading, progress: 80.62 (8614254811 / 10684442455)
Update state (0x61) downloading, progress: 81.59 (8716949273 / 10684442455)
Update state (0x61) downloading, progress: 82.43 (8807551527 / 10684442455)
Update state (0x61) downloading, progress: 83.37 (8907543487 / 10684442455)
Update state (0x61) downloading, progress: 84.16 (8992387683 / 10684442455)
Update state (0x61) downloading, progress: 85.09 (9091476683 / 10684442455)
Update state (0x61) downloading, progress: 86.04 (9193229023 / 10684442455)
Update state (0x61) downloading, progress: 86.98 (9293105807 / 10684442455)
Update state (0x61) downloading, progress: 87.85 (9386276109 / 10684442455)
Update state (0x61) downloading, progress: 88.74 (9481696525 / 10684442455)
Update state (0x61) downloading, progress: 89.53 (9566089879 / 10684442455)
Update state (0x61) downloading, progress: 90.29 (9647050307 / 10684442455)
Update state (0x61) downloading, progress: 91.02 (9724644931 / 10684442455)
Update state (0x61) downloading, progress: 91.73 (9801190979 / 10684442455)
Update state (0x61) downloading, progress: 92.51 (9884265995 / 10684442455)
Update state (0x61) downloading, progress: 93.21 (9959109515 / 10684442455)
Update state (0x61) downloading, progress: 93.94 (10037489295 / 10684442455)
Update state (0x61) downloading, progress: 94.69 (10117579103 / 10684442455)
Update state (0x61) downloading, progress: 95.35 (10187223411 / 10684442455)
Update state (0x61) downloading, progress: 96.14 (10271634547 / 10684442455)
Update state (0x61) downloading, progress: 96.90 (10352952459 / 10684442455)
Update state (0x61) downloading, progress: 97.59 (10426989855 / 10684442455)
Update state (0x61) downloading, progress: 98.35 (10508163727 / 10684442455)
Update state (0x61) downloading, progress: 99.02 (10579649231 / 10684442455)
Update state (0x61) downloading, progress: 99.83 (10666092651 / 10684442455)
Update state (0x81) verifying update, progress: 4.75 (507877024 / 10684442455)
Update state (0x81) verifying update, progress: 9.93 (1060896460 / 10684442455)
Update state (0x81) verifying update, progress: 16.69 (1783473149 / 10684442455)
IPC function call IClientAppManager::GetUpdateInfo took too long: 70 msec
Success! App ‘42700’ fully installed.
quit
Unloading Steam API…OK
[11:50:58] [System:elessar Info/18] : SteamCMD Update successful
[11:51:01] [System:elessar Info/12] : Extracting /AMP/call-of-dutybo1/server/plutonium-updater-x86_64-unknown-linux-gnu.tar.gz to /AMP/call-of-dutybo1/server/…
[11:51:12] [System:elessar Info/12] : Extracting /AMP/call-of-dutybo1/configs/master.zip to /AMP/call-of-dutybo1/configs…
[11:54:13] [System Activity/22] : Authentication attempt for user elessar from 127.0.0.1
[11:54:14] [System Activity/21] : Authentication success
This has now been fixed. Create a new instance
It works. Now I can build a BO1 server. Ty sir! :slight_smile:
