Startup Issue with BeamMP - BeamMP instance won't start
Product AMP ‘Decadeus’ v2.4.7.0 (Mainline)
Application BeamMP
Just repeatedly says Application stopped unexpectedly with exit code 255. The console is blank.
I tried to follow the steps in the post but it doesn’t fix it. Startup Issue with BeamMP - After the update BeamMP dont let me start it - #7 by BenZockt
  • Created Instance
  • Setup configuration with Auth key
  • Tried to start
Can you share the information from the support tab please? (The Copy to Clipboard button which includes the startup flags etc)
An extremely helpful community member on Discord was able to help me with this. This ticket can be closed.
What was the solution? I had this issue too.
With the BeamMP server the template was updated and it needed to be downloaded. To do that go to Configuration->Instance Deployment and click Fetch Latest. That will get the new templates. Then delete rebuild the instance. With my SOTF instance I just needed to delete and rebuild.
Oh sweet, thank you! Sounds like that’ll do it.
