Startup Issue with Astroneer - Not booting Up
Application Astroneer
It installs Proton GE, Then Says its Booted up. But Not Allowing to connect
  • Start a New Instance for Astroneer
  • Boot the new Instance
  • Try too connect but doesnt work
So is the issue “not booting up” or “not allowing to connect”?
Two very different issues…
You have to use your server’s public IP in the Astroneer client to connect. Which means you need NAT hairpin/loopback enabled on your router if home hosting, or be connected to a VPN
