Startup Issue with ASKA - Disconnected with reason: CustomAuthenticationFailed
Application ASKA
i just wondered port 7777 not getting green, and saw that authentication error. so i renewed the token, copy & pasted, meanwhile i added the token and other options not only into webinterface of amp, also into server properties.txt and in /config/server.cfg
still getting this error, i can see the connection as time stamp on steams managegameservers site. i am not sure if it is really the token, i cant imagine its not correct after all.
  • created an aska server instance
  • filled configuration - tried to start
  • replaced token appid 1898300 now 3 times, still getting authenticationfailed
