Startup Issue with Arma 3 - Unable to edit server.cfg in AMP panel
Application Arma 3
Hello,
I am running an Arma 3 server using your AMP Game Panel.
The file server.cfg is marked as controlled by AMP and any manual modification is automatically reverted after a restart. Because of this, I am unable to change important server settings.
I would like to know if it is possible to allow manual editing of server.cfg or disable AMP control for this file.
Thank you.
  • Open the Arma 3 instance in the AMP panel
  • Go to File Manager and edit server.cfg
  • Restart the server and the changes are reverted
The comments at the top of the file tell you how to manage it
Also: Arma 3 Server Guide
