| Virtualization | None |
| Application | Arma 3 |
| Module | GenericModule |
| Running in Container | No |
| Current State | Stopped |
I just installed a fresh Arma 3 server and it fails to start giving me error 139. My OS is linux.
- Installed AMP on Linux machine
- Set up Arma 3 instance
- Update the instance to get server files from Steam
- Click on the start button
- Server fails to start error 139
06:47:50
8:47:50 Could not enable linux core dumps. Error 1 - ��^^
8:47:50 SteamAPI initialization failed. Steam features won't be accessible!
8:47:50 Initializing stats manager.
sh: 1: /sbin/ifconfig: not found
8:47:50 Stats config disabled.
8:47:50 sessionID: 2ff080239cb19683b526b6594d8c84782600ca9f
06:48:12
8:48:12 Updating base class ->RscButton, by a3\ui_f\config.bin/CA_RscButton/ (original a3\ui_f\config.bin)
8:48:12 Updating base class ->CA_RscButton, by a3\ui_f\config.bin/CA_RscButton_dialog/ (original a3\ui_f\config.bin)
8:48:12 Updating base class ->RscActiveText, by a3\ui_f\config.bin/CA_Ok/ (original a3\ui_f\config.bin)
8:48:12 Updating base class ->RscText, by a3\ui_f\config.bin/CA_Ok_image/ (original a3\ui_f\config.bin)
8:48:12 Updating base class ->RscText, by a3\ui_f\config.bin/CA_Ok_image2/ (original a3\ui_f\config.bin)
8:48:12 Updating base class ->RscText, by a3\ui_f\config.bin/CA_Ok_text/ (original a3\ui_f\config.bin)
8:48:12 Updating base class ->RscPicture, by a3\ui_f\config.bin/RscVignette/ (original a3\ui_f\config.bin)
8:48:12 Updating base class ->RscControlsGroupNoScrollbars, by a3\ui_f\config.bin/RscMapControlTooltip/ (original a3\ui_f\config.bin)
8:48:12 Updating base class RscUnitInfo->RscUnitInfoAirNoWeapon, by a3\ui_f\config.bin/RscInGameUI/RscUnitInfoAir/ (original a3\ui_f\config.bin)
8:48:12 Updating base class RscControlsGroup->RscControlsGroupNoScrollbars, by a3\ui_f\config.bin/RscInGameUI/RscTaskOverview/controls/TaskOverviewAssigned/ (original bin\config.bin)
8:48:12 Updating base class RscShortcutButton->RscButtonMenu, by a3\ui_f\config.bin/RscDisplayDebug/Controls/B_OK/ (original bin\config.bin)
8:48:12 Updating base class RscShortcutButton->RscButtonMenu, by a3\ui_f\config.bin/RscDisplayDebug/Controls/B_Cancel/ (original bin\config.bin)
8:48:12 Updating base class RscShortcutButton->RscButtonMenu, by a3\ui_f\config.bin/RscDisplayDebug/Controls/B_Clear/ (original bin\config.bin)
8:48:12 Updating base class ->RscText, by a3\ui_f\config.bin/RscDisplayCapture/controls/TimeLines/ (original bin\config.bin)
8:48:12 Updating base class RscShortcutButton->RscButtonMenu, by a3\ui_f\config.bin/RscDisplayCapture/controls/ButtonAverages/ (original bin\config.bin)
8:48:12 Updating base class RscShortcutButton->RscButtonMenu, by a3\ui_f\config.bin/RscDisplayCapture/controls/ButtonSavePreviousData/ (original bin\config.bin)
8:48:12 Updating base class RscShortcutButton->RscButtonMenu, by a3\ui_f\config.bin/RscDisplayCapture/controls/ButtonPreviousData/ (original bin\config.bin)
8:48:12 Updating base class RscPicture->RscPictureKeepAspect, by a3\ui_f\config.bin/RscDisplayMain/IconPicture/ (original bin\config.bin)
8:48:12 Updating base class IconPicture->RscPictureKeepAspect, by a3\ui_f\config.bin/RscDisplayMain/DlcOwnedIconPicture/ (original a3\ui_f\config.bin)
8:48:12 Updating base class IconPicture->RscPictureKeepAspect, by a3\ui_f\config.bin/RscDisplayMain/DlcIconPicture/ (original a3\ui_f\config.bin)
8:48:12 Updating base class RscControlsGroup->RscControlsGroupNoScrollbars, by a3\ui_f\config.bin/RscDisplayCampaignLoad/controls/OverviewGroup/ (original bin\config.bin)
8:48:12 Updating base class RscButton->RscButtonSearch, by a3\ui_f\config.bin/RscDisplayCampaignLoad/controls/SearchButton/ (original bin\config.bin)
8:48:12 Updating base class RscShortcutButton->RscButtonMenuCancel, by a3\ui_f\config.bin/RscDisplayCampaignLoad/controls/ButtonCancel/ (original bin\config.bin)
8:48:12 Updating base class RscShortcutButton->RscButtonMenu, by a3\ui_f\config.bin/RscDisplayCampaignLoad/controls/ButtonGameOptions/ (original bin\config.bin)
8:48:12 Updating base class RscShortcutButton->RscButtonMenuSteam, by a3\ui_f\config.bin/RscDisplayCampaignLoad/controls/ButtonBuyDLC/ (original bin\config.bin)
8:48:12 Updating base class RscShortcutButton->RscButtonMenu, by a3\ui_f\config.bin/RscDisplayCampaignLoad/controls/ButtonRevert/ (original bin\config.bin)
8:48:12 Updating base class RscShortcutButton->RscButtonMenuOK, by a3\ui_f\config.bin/RscDisplayCampaignLoad/controls/ButtonOK/ (original bin\config.bin)
8:48:12 Updating base class RscListBox->RscCombo, by a3\ui_f\config.bin/RscDisplayCustomizeController/Steepness/ (original bin\config.bin)
8:48:12 Updating base class ->RscStandardDisplay, by a3\ui_f\config.bin/RscDisplayControlSchemes/ (original bin\config.bin)
8:48:12 Updating base class ButtonOK->RscButtonMenuCancel, by a3\ui_f\config.bin/RscDisplayControlSchemes/controls/ButtonCancel/ (original bin\config.bin)
8:48:12 Updating base class RscButton->RscButtonMenuOK, by a3\ui_f\config.bin/RscDisplayControlSchemes/controls/ButtonOK/ (original bin\config.bin)
8:48:12 Updating base class RscPicture->RscPictureKeepAspect, by a3\ui_f\config.bin/RscDisplayFileSelectImage/controls/OverviewPicture/ (original bin\config.bin)
8:48:12 Updating base class RscShortcutButton->RscButtonMenuCancel, by a3\ui_f\config.bin/RscDisplayFieldManual/Controls/ButtonCancel/ (original bin\config.bin)
8:48:12 Cannot delete class B_KickOff, it is referenced somewhere (used as a base class probably).
8:48:12 Updating base class RscButton->RscButtonMenuCancel, by a3\ui_f\config.bin/RscDisplayPublishMission/controls/ButtonCancel/ (original bin\config.bin)
8:48:12 Updating base class RscShortcutButton->RscButtonMenuOK, by a3\ui_f\config.bin/RscDisplayPublishMissionSelectTags/controls/ButtonOK/ (original bin\config.bin)
8:48:12 Updating base class ButtonOK->RscButtonMenuCancel, by a3\ui_f\config.bin/RscDisplayPublishMissionSelectTags/controls/ButtonCancel/ (original bin\config.bin)
8:48:12 Updating base class ->RscSubmenu, by a3\ui_f\config.bin/RscMainMenu/ (original bin\config.bin)
8:48:12 Updating base class ->DistanceClose, by a3\ui_f\config.bin/CfgSimpleTasks/Icon3D/DistanceMid/ (original bin\config.bin)
8:48:12 Updating base class ->DistanceClose, by a3\ui_f\config.bin/CfgSimpleTasks/Icon3D/DistanceLong/ (original bin\config.bin)
06:48:13
8:48:13 Updating base class ->ctrlDefaultText, by a3\3den\config.bin/ctrlStatic/ (original a3\3den\config.bin)
8:48:13 Updating base class ->ctrlActiveText, by a3\3den\config.bin/ctrlActivePicture/ (original a3\3den\config.bin)
8:48:13 Updating base class ->ctrlDefaultText, by a3\3den\config.bin/ctrlStructuredText/ (original a3\3den\config.bin)
8:48:13 Updating base class ->ctrlControlsGroup, by a3\3den\config.bin/ctrlControlsGroupNoScrollbars/ (original a3\3den\config.bin)
8:48:13 Updating base class ->ctrlDefault, by a3\3den\config.bin/ctrlCheckbox/ (original a3\3den\config.bin)
8:48:13 Updating base class ->ctrlCheckbox, by a3\3den\config.bin/ctrlCheckboxBaseline/ (original a3\3den\config.bin)
8:48:13 Updating base class RscText->ctrlStaticBackgroundDisable, by a3\3den\config.bin/RscDisplayOptionsAudio/ControlsBackground/BackgroundDisable/ (original a3\3den\config.bin)
8:48:13 Updating base class RscText->ctrlStaticBackgroundDisableTiles, by a3\3den\config.bin/RscDisplayOptionsAudio/ControlsBackground/BackgroundDisableTiles/ (original a3\3den\config.bin)
8:48:13 Updating base class RscText->ctrlStaticBackgroundDisable, by a3\3den\config.bin/RscDisplayConfigure/ControlsBackground/BackgroundDisable/ (original a3\3den\config.bin)
8:48:13 Updating base class RscText->ctrlStaticBackgroundDisableTiles, by a3\3den\config.bin/RscDisplayConfigure/ControlsBackground/BackgroundDisableTiles/ (original a3\3den\config.bin)
8:48:13 Updating base class RscText->ctrlStaticBackgroundDisable, by a3\3den\config.bin/RscDisplayConfigureAction/ControlsBackground/BackgroundDisable/ (original a3\3den\config.bin)
8:48:13 Updating base class RscText->ctrlStaticBackgroundDisableTiles, by a3\3den\config.bin/RscDisplayConfigureAction/ControlsBackground/BackgroundDisableTiles/ (original a3\3den\config.bin)
8:48:13 Updating base class RscText->ctrlStaticBackgroundDisable, by a3\3den\config.bin/RscDisplayConfigureControllers/ControlsBackground/BackgroundDisable/ (original a3\3den\config.bin)
8:48:13 Updating base class RscText->ctrlStaticBackgroundDisableTiles, by a3\3den\config.bin/RscDisplayConfigureControllers/ControlsBackground/BackgroundDisableTiles/ (original a3\3den\config.bin)
8:48:13 Updating base class RscText->ctrlStaticBackgroundDisable, by a3\3den\config.bin/RscDisplayGameOptions/ControlsBackground/BackgroundDisable/ (original a3\3den\config.bin)
8:48:13 Updating base class RscText->ctrlStaticBackgroundDisableTiles, by a3\3den\config.bin/RscDisplayGameOptions/ControlsBackground/BackgroundDisableTiles/ (original a3\3den\config.bin)
8:48:13 Updating base class controls->, by a3\3den\config.bin/RscDisplayArcadeMap_Layout_2/Controls/ (original a3\ui_f\config.bin)
8:48:13 Updating base class controls->, by a3\3den\config.bin/RscDisplayArcadeMap_Layout_6/Controls/ (original a3\ui_f\config.bin)
8:48:13 Updating base class ->ctrlControlsGroupNoScrollbars, by a3\3den\config.bin/Cfg3DEN/Attributes/Default/ (original a3\3den\config.bin)
8:48:13 Updating base class ->ctrlStatic, by a3\3den\config.bin/Cfg3DEN/Attributes/Title/Controls/Title/ (original a3\3den\config.bin)
8:48:13 Updating base class ->ctrlToolbox, by a3\3den\config.bin/Cfg3DEN/Attributes/Toolbox/Controls/Value/ (original a3\3den\config.bin)
8:48:13 Updating base class Mod_Base->, by a3\data_f_destroyer\config.bin/CfgMods/Jets/ (original a3\data_f_jets\config.bin)
06:48:14
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/data_f_jets.pbo - 150370
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/data_f_sams.pbo - 150370
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/dubbing_f_jets.pbo - 119457
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/editorpreviews_f_destroyer.pbo - 132141
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/editorpreviews_f_jets.pbo - 119457
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/editorpreviews_f_sams.pbo - 132141
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/functions_f_destroyer.pbo - 150071
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/functions_f_jets.pbo - 119457
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/languagemissions_f_jets.pbo - 150726
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/language_f_destroyer.pbo - 150726
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/language_f_jets.pbo - 150726
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/language_f_sams.pbo - 150726
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/missions_f_jets.pbo - 130755
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/modules_f_jets.pbo - 119459
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/music_f_jets.pbo - 119459
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/props_f_destroyer.pbo - 132141
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/props_f_jets.pbo - 129371
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/sounds_f_jets.pbo - 141706
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/static_f_destroyer.pbo - 140243
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/static_f_jets.pbo - 146744
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/static_f_sams.pbo - 146744
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/ui_f_jets.pbo - 126137
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/weapons_f_destroyer.pbo - 132268
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/weapons_f_jets.pbo - 148847
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/jets/addons/weapons_f_sams.pbo - 149414
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/expansion/addons/air_f_exp.pbo - 150339
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/expansion/addons/anims_f_exp.pbo - 126506
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/expansion/addons/armor_f_exp.pbo - 141671
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/expansion/addons/boat_f_exp.pbo - 150071
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/expansion/addons/cargoposes_f_exp.pbo - 126224
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/expansion/addons/characters_f_exp.pbo - 150282
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/expansion/addons/characters_f_oldman.pbo - 148698
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/expansion/addons/data_f_exp.pbo - 148936
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/expansion/addons/data_f_oldman.pbo - 148580
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/expansion/addons/dubbing_f_exp.pbo - 119457
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/expansion/addons/dubbing_f_oldman.pbo - 148756
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/expansion/addons/dubbing_radio_f_exp.pbo - 119458
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/expansion/addons/dubbing_radio_f_exp_data_chi.pbo - 119458
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/expansion/addons/dubbing_radio_f_exp_data_engfre.pbo - 119457
8:48:14 /home/amp/.ampdata/instances/Arma301/arma3/233780/expansion/addons/dubbing_radio_f_exp_data_fre.pbo - 119457
06:48:15
8:48:14 addons/ui_f_decade.pbo - 150746
8:48:14 addons/ui_f_exp_a.pbo - 119478
8:48:14 addons/weapons_f.pbo - 150697
8:48:14 addons/weapons_f_beta.pbo - 150174
8:48:14 addons/weapons_f_bootcamp.pbo - 141713
8:48:14 addons/weapons_f_decade.pbo - 150757
8:48:14 addons/weapons_f_epa.pbo - 148783
8:48:14 addons/weapons_f_epb.pbo - 137810
8:48:14 addons/weapons_f_epc.pbo - 130416
8:48:14 addons/weapons_f_gamma.pbo - 148783
8:48:14 addons/weapons_f_mod.pbo - 149339
8:48:14
8:48:14 =======================
8:48:14
8:48:15 ============================================================================================= List of mods ===============================================================================================
8:48:15 modsReadOnly = false
8:48:15 safeModsActivated = false
8:48:15 customMods = false
8:48:15 hash = '74E5FD3DB08937F555F7D7C6734DD62360B65B8B'
8:48:15 hashShort = '6d331509'
8:48:15 name | modDir | default | official | origin | hash | hashShort | fullPath
8:48:15 ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
8:48:15 Arma 3 Art of War | aow | true | true | GAME DIR | e1eb2d3a47ed44a690451ad42e47805847dfb43e | baf85a92 | /home/amp/.ampdata/instances/Arma301/arma3/233780/aow
8:48:15 Arma 3 Contact (Platform) | enoch | true | true | GAME DIR | 1fa4e5e7422fde7e58f61907daf400115c800a3b | ca00378e | /home/amp/.ampdata/instances/Arma301/arma3/233780/enoch
8:48:15 Arma 3 Tanks | tank | true | true | GAME DIR | fedd2fd12a04161ffe07db067e6429a771aa77fd | 5dfa6fe0 | /home/amp/.ampdata/instances/Arma301/arma3/233780/tank
8:48:15 Arma 3 Tac-Ops | tacops | true | true | GAME DIR | 342f445a851b4963e566698674eccf6c9bfcc774 | 26a76da4 | /home/amp/.ampdata/instances/Arma301/arma3/233780/tacops
8:48:15 Arma 3 Laws of War | orange | true | true | GAME DIR | 3ec57cfa7e4d3102e1226ddef812f63feb3b5c20 | 951b0eba | /home/amp/.ampdata/instances/Arma301/arma3/233780/orange
8:48:15 Arma 3 Malden | argo | true | true | GAME DIR | 28e56c102addfacaa41afd6400972b2b8c4b079b | 47943270 | /home/amp/.ampdata/instances/Arma301/arma3/233780/argo
8:48:15 Arma 3 Jets | jets | true | true | GAME DIR | 0b3d97c900e402c9ae7571516c6d8757d74abd3f | 6004bd8f | /home/amp/.ampdata/instances/Arma301/arma3/233780/jets
8:48:15 Arma 3 Apex | expansion | true | true | GAME DIR | 016ce3d12a145862928da83795ee028c18943480 | efa20156 | /home/amp/.ampdata/instances/Arma301/arma3/233780/expansion
8:48:15 Arma 3 Marksmen | mark | true | true | GAME DIR | 40a8c35898391e8246e65d85692f9b4cd9acd46d | dd6a80ec | /home/amp/.ampdata/instances/Arma301/arma3/233780/mark
8:48:15 Arma 3 Helicopters | heli | true | true | GAME DIR | 0bd6e366e62857e63a2777988167802ddf6448c5 | e0bc8b30 | /home/amp/.ampdata/instances/Arma301/arma3/233780/heli
8:48:15 Arma 3 Karts | kart | true | true | GAME DIR | 26118ce424d417b3735cc8afcfe9e3ab882708a5 | b5d72482 | /home/amp/.ampdata/instances/Arma301/arma3/233780/kart
8:48:15 Arma 3 Zeus | curator | true | true | GAME DIR | 40c6eaacbe0fa7b2242015d351d0f62c83feb001 | b58391d9 | /home/amp/.ampdata/instances/Arma301/arma3/233780/curator
8:48:15 Arma 3 | A3 | true | true | NOT FOUND (Empty) | | |
8:48:15 ==========================================================================================================================================================================================================
8:48:15 InitSound ...
8:48:15 InitSound - complete
8:48:15 PhysX3 SDK Init started ...
8:48:15 PhysX3 SDK Init ended.
06:48:19
8:48:19 Warning Message: You cannot play/edit this mission; it is dependent on downloadable content that has been deleted.\na3_characters_f
8:48:19 Loading movesType CfgGesturesMale
8:48:19 MovesType CfgGesturesMale load time 89.0 ms
8:48:19 Loading movesType CfgMovesMaleSdr
06:48:25
8:48:25 Warning: looped for animation: a3\anims_f_epa\data\anim\sdr\cts\hubcleaned\briefing\hubbriefing_loop.rtm differs (looped now 0)! MoveName: hubbriefing_ext
06:48:27
8:48:27 Warning: looped for animation: a3\anims_f_epa\data\anim\sdr\cts\hubcleaned\spectator\hubspectator_stand.rtm differs (looped now 1)! MoveName: hubspectator_stand_contact
8:48:27 MovesType CfgMovesMaleSdr load time 8114.0 ms
8:48:27 BattlEye Server: Initialized (v1.220, Arma 3 2.14.151229)
[S_API] SteamAPI_Init(): Loaded local 'steamclient.so' OK.
06:48:28
CAppInfoCacheReadFromDiskThread took 0 milliseconds to initialize
Setting breakpad minidump AppID = 107410
SteamInternal_SetMinidumpSteamID: Caching Steam ID: 76561197960265728 [API loaded no]
dlmopen steamservice.so failed: steamservice.so: cannot open shared object file: No such file or directory
06:48:36
Connected to Steam servers
8:48:36 UPNP failed
8:48:36 Host identity created.
8:48:36 BattlEye Server: Config entry: RConPassword 0743285b6c8f44bba67a03aae3386dad
8:48:36 BattlEye Server: Config entry: RConPort 2307
8:48:36 BattlEye Server: Config entry: RConIP 0.0.0.0
8:48:36 BattlEye Server: RCon admin #0 (127.0.0.1:45867) logged in
