| Field |
Value |
| Operating System |
| Product |
AMP ‘Phobos’ v2.6.0.0 (Mainline) |
| Virtualization |
Docker |
| Application |
Arma 3 |
| Module |
GenericModule |
| Running in Container |
Yes |
| Current State |
Failed |
Getting the following bash error when attempting to start an arma3 server after updating to 2.6.
-f: -c: line 1: unexpected EOF while looking for matching `‘’
- Ran sudo su -l; getamp update; on the host.
- Instance refused to start with the error code in the detailed description.
- Figured i had to update the docker containers and ran, ampinstmgr upgradeall.
- Issue persisted. Read something on the discord about needing to upgrade via GUI, ran an upgrade via that.
From the release notes:
IMPORTANT NOTICE
It is important to make sure your generic templates are updated! If after updating some generic instances won’t start, update them from ADS to make sure they’re running the latest configuration for your given application.
Is that different from updating through the web GUI? If not, how to I go about updating them through ADS?
Sorry, still new to the service and still trying to figure everything out.
ADS is the main page where you see all your instances. There is an update button on each instance and an Update All button at the top
Gotcha, I’ve already gone through and updated the instance through that button about three times now. Still getting the same error when starting the instance.
Also read somewhere on the forum to go into configuration → instance deployment → instance management and check on the fetch latest. The issue still persists.
I’ve gone ahead and started up another arma instance just to make sure there’s not some weird issue with the template not working in 2.6, but it started up normally.
Anything else I can try?
Update it again now after clicking fetch latest. Check the deployment log for any errors
Hit the “Fetch latest” button once more for good luck before updating the instance.
Deployment log isn’t showing anything of interest that I can tell.
17:01:52
Updating existing remote source https://github.com/CubeCoders/AMPTemplates.git...
No local changes to save
No stash entries found.
Already up to date.
17:01:57
Managed remote instance ThePlave01 at http://127.0.0.1:8081/
17:02:00
Authentication token for arma requested by ManageInstance on behalf of arma
17:02:03
Slow method invocation: ManageInstance took 6805ms to complete.
Slow response: ADSModule.ManageInstance took 6805ms to complete.
17:02:11
Slow method invocation: Login took 5253ms to complete.
Slow response: Core.Login took 5253ms to complete.
17:02:13
Slow method invocation: Servers took 9723ms to complete.
Slow response: ADSModule.Servers took 9724ms to complete.
:arma17:02:33
Slow method invocation: Servers took 3293ms to complete.
Slow response: ADSModule.Servers took 3294ms to complete.
Slow method invocation: Servers took 2790ms to complete.
Slow response: ADSModule.Servers took 2790ms to complete.
Slow method invocation: Servers took 2129ms to complete.
Slow response: ADSModule.Servers took 2129ms to complete.
17:03:17
Slow method invocation: Servers took 7628ms to complete.
Slow response: ADSModule.Servers took 7629ms to complete.
Slow method invocation: Servers took 6069ms to complete.
Slow response: ADSModule.Servers took 6069ms to complete.
Slow method invocation: Servers took 5080ms to complete.
Slow response: ADSModule.Servers took 5080ms to complete.
Slow method invocation: Servers took 4096ms to complete.
Slow response: ADSModule.Servers took 4096ms to complete.
Slow method invocation: Servers took 3103ms to complete.
Slow response: ADSModule.Servers took 3103ms to complete.
Slow method invocation: Servers took 2123ms to complete.
Slow response: ADSModule.Servers took 2123ms to complete.
Slow method invocation: Servers took 7121ms to complete.
Slow response: ADSModule.Servers took 7121ms to complete.
17:04:22
17:04:24
17:04:26
Slow method invocation: ManageInstance took 4368ms to complete.
Slow response: ADSModule.ManageInstance took 4368ms to complete.
17:04:42
Slow method invocation: Login took 7205ms to complete.
Slow response: Core.Login took 7205ms to complete.
17:04:44
Slow method invocation: Servers took 17564ms to complete.
Slow response: ADSModule.Servers took 17564ms to complete.
:arma17:05:42
17:05:45
17:05:46
Slow method invocation: ManageInstance took 3980ms to complete.
Slow response: ADSModule.ManageInstance took 3980ms to complete.
17:05:52
Slow method invocation: Login took 3606ms to complete.
Slow response: Core.Login took 3607ms to complete.
17:05:54
Slow method invocation: Servers took 7264ms to complete.
Slow response: ADSModule.Servers took 7264ms to complete.
:arma17:06:05
Slow method invocation: Servers took 2061ms to complete.
Slow response: ADSModule.Servers took 2061ms to complete.
17:06:52
Slow method invocation: Servers took 2231ms to complete.
Slow response: ADSModule.Servers took 2231ms to complete.
17:07:55
Slow method invocation: Servers took 2469ms to complete.
Slow response: ADSModule.Servers took 2469ms to complete.
17:08:05
Slow method invocation: Servers took 2132ms to complete.
Slow response: ADSModule.Servers took 2132ms to complete.
Slow method invocation: Servers took 3131ms to complete.
Slow response: ADSModule.Servers took 3131ms to complete.
Slow method invocation: Servers took 4053ms to complete.
Slow response: ADSModule.Servers took 4054ms to complete.
17:10:27
17:10:29
17:10:32
Slow method invocation: ManageInstance took 4946ms to complete.
Slow response: ADSModule.ManageInstance took 4946ms to complete.
17:10:41
Slow method invocation: Login took 6710ms to complete.
Slow response: Core.Login took 6710ms to complete.
17:10:43
Slow method invocation: Servers took 11493ms to complete.
Slow response: ADSModule.Servers took 11494ms to complete.
:arma17:10:48
Slow method invocation: Servers took 2121ms to complete.
Slow response: ADSModule.Servers took 2121ms to complete.
17:10:50
Slow method invocation: Servers took 2042ms to complete.
Slow response: ADSModule.Servers took 2042ms to complete.
Console log for the instance is showing still showing the same error message as before after updating it.
Invalid Date
bashInvalid Date
-f: -c: line 1: unexpected EOF while looking for matching `''
-p: -c: line 1: unexpected EOF while looking for matching `''
Invalid Date
Invalid Date
I don’t see in that log that you updated the instance from ADS
You also need to clear your browser cache (all images and files)
Hit the update button, a loading icon appeared, but nothing popped up in the bottom right corner like normal. Just hit it again and got the pop up this time.
Console logs for the instance are showing that its actually updating now.
SteamCMDInvalid Date
UpdateUI: skip show logoSteam Console Client (c) Valve Corporation - version 1728594755
-- type 'quit' to exit --
Loading Steam API...OK
force_install_dir "233780"
Logging in using cached credentials.
Logging in user 'theplaveman' [U:1:1818924611] to Steam Public...OK
Waiting for user info...OK
app_update 233780 -beta public validate
Update state (0x5) verifying install, progress: 18.82 (1012274991 / 5377303279)
Update state (0x5) verifying install, progress: 51.54 (2771484720 / 5377303279)
Update state (0x5) verifying install, progress: 82.96 (4460822238 / 5377303279)
Success! App '233780' fully installed.
quit
workshop_download_item 107410 1779063631 validate
Downloading item 1779063631 ...
Success. Downloaded item 1779063631 to "/AMP/arma3/233780/steamapps/workshop/content/107410/1779063631" (3623412 bytes) workshop_download_item 107410 843577117 validate
Downloading item 843577117 ...
Success. Downloaded item 843577117 to "/AMP/arma3/233780/steamapps/workshop/content/107410/843577117" (7951223442 bytes) workshop_download_item 107410 843632231 validate
Downloading item 843632231 ...
Success. Downloaded item 843632231 to "/AMP/arma3/233780/steamapps/workshop/content/107410/843632231" (856614623 bytes) workshop_download_item 107410 843593391 validate
Downloading item 843593391 ...
Success. Downloaded item 843593391 to "/AMP/arma3/233780/steamapps/workshop/content/107410/843593391" (2892412524 bytes) workshop_download_item 107410 843425103 validate
Downloading item 843425103 ...
Success. Downloaded item 843425103 to "/AMP/arma3/233780/steamapps/workshop/content/107410/843425103" (7516251732 bytes) quit
workshop_download_item 107410 1862208264 validate
Downloading item 1862208264 ...
Success. Downloaded item 1862208264 to "/AMP/arma3/233780/steamapps/workshop/content/107410/1862208264" (36249 bytes) workshop_download_item 107410 1808238502 validate
Downloading item 1808238502 ...
Success. Downloaded item 1808238502 to "/AMP/arma3/233780/steamapps/workshop/content/107410/1808238502" (36766 bytes) workshop_download_item 107410 1858070328 validate
Downloading item 1858070328 ...
Success. Downloaded item 1858070328 to "/AMP/arma3/233780/steamapps/workshop/content/107410/1858070328" (46153 bytes) workshop_download_item 107410 1858075458 validate
Downloading item 1858075458 ...
Success. Downloaded item 1858075458 to "/AMP/arma3/233780/steamapps/workshop/content/107410/1858075458" (1377860 bytes) workshop_download_item 107410 3078351739 validate
Downloading item 3078351739 ...
Success. Downloaded item 3078351739 to "/AMP/arma3/233780/steamapps/workshop/content/107410/3078351739" (225770678 bytes) quit
workshop_download_item 107410 1180533757 validate
Downloading item 1180533757 ...
Success. Downloaded item 1180533757 to "/AMP/arma3/233780/steamapps/workshop/content/107410/1180533757" (54012 bytes) workshop_download_item 107410 945476727 validate
Downloading item 945476727 ...
Success. Downloaded item 945476727 to "/AMP/arma3/233780/steamapps/workshop/content/107410/945476727" (52115 bytes) workshop_download_item 107410 861133494 validate
Downloading item 861133494 ...
Success. Downloaded item 861133494 to "/AMP/arma3/233780/steamapps/workshop/content/107410/861133494" (1480207899 bytes) workshop_download_item 107410 583496184 validate
Downloading item 583496184 ...
Success. Downloaded item 583496184 to "/AMP/arma3/233780/steamapps/workshop/content/107410/583496184" (11751310970 bytes) workshop_download_item 107410 450814997 validate
Downloading item 450814997 ...
Success. Downloaded item 450814997 to "/AMP/arma3/233780/steamapps/workshop/content/107410/450814997" (4572277 bytes) quit
workshop_download_item 107410 2257686620 validate
Downloading item 2257686620 ...
Success. Downloaded item 2257686620 to "/AMP/arma3/233780/steamapps/workshop/content/107410/2257686620" (129298200 bytes) workshop_download_item 107410 2801179774 validate
Downloading item 2801179774 ...
Success. Downloaded item 2801179774 to "/AMP/arma3/233780/steamapps/workshop/content/107410/2801179774" (99907 bytes) workshop_download_item 107410 1377912885 validate
Downloading item 1377912885 ...
Success. Downloaded item 1377912885 to "/AMP/arma3/233780/steamapps/workshop/content/107410/1377912885" (189590592 bytes) workshop_download_item 107410 3036808726 validate
Downloading item 3036808726 ...
Success. Downloaded item 3036808726 to "/AMP/arma3/233780/steamapps/workshop/content/107410/3036808726" (113768515 bytes) workshop_download_item 107410 623475643 validate
Downloading item 623475643 ...
Success. Downloaded item 623475643 to "/AMP/arma3/233780/steamapps/workshop/content/107410/623475643" (22953127 bytes) quit
workshop_download_item 107410 1673456286 validate
Downloading item 1673456286 ...
Success. Downloaded item 1673456286 to "/AMP/arma3/233780/steamapps/workshop/content/107410/1673456286" (21477597185 bytes) workshop_download_item 107410 3020755032 validate
Downloading item 3020755032 ...
Success. Downloaded item 3020755032 to "/AMP/arma3/233780/steamapps/workshop/content/107410/3020755032" (251315669 bytes) workshop_download_item 107410 894678801 validate
Downloading item 894678801 ...
Success. Downloaded item 894678801 to "/AMP/arma3/233780/steamapps/workshop/content/107410/894678801" (85999443 bytes) quit
Invalid Date
However the deployment logs are not showing it.
18:10:08
18:14:15
Getting the same issue on firefox as well.
SteamCMD
18:16:31
18:16:32
18:16:33
18:16:34
18:16:35
18:16:37
18:16:38
18:16:39
18:16:40
18:16:41
18:16:43
18:16:44
18:16:45
18:16:46
18:16:47
18:16:49
18:16:50
18:16:51
18:16:52
18:16:53
18:16:54
bash
18:16:54
18:16:59
18:10:08
18:14:15
18:16:11
18:16:12
18:16:40
Wrong update button. That is for Arma
To update the instance:
- Click Return to Instances
- Stop the Arma instance - there is a red button on the instance tile
- Click the update button next to the stop button
