Startup Issue with ARK: Survival Evolved - The server stalls at startup with 0% cpu usage
Application ARK: Survival Evolved
Current State Starting
If I copy the mods from my game client the server starts but has building bugs (I can’t place some of the structures, even vanilla ones). I have checked and the mods downloaded by the server are the same size as the ones from my client.
I would like a more detailed log to see where exactly the server stalls.
  • tried running without mods and it works
  • tried copying mods from my pc client and it works
  • clean install of the mods from the server is not working although the files have the correct size.
Are the .mod files there as well as the mod dirs?
Yes. They are and they have the name of the folders.
The log shows this:
[11:30:37] [Program Info] : Starting AMP version 2.4.6.6 (Decadeus), built 05/10/2023 11:56
[11:30:37] [Program Info] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[11:30:37] [Core Warning] : Current time zone is set to GTB Standard Time - It is recommended you switch to UTC+0 to avoid time-zone related issues
[11:30:37] [Program Info] : OS: Windows / x86_64
[11:30:37] [Program Info] : CPU: Intel(R) Core™ i7-4790K CPU @ 4.00GHz (4C/8T)
[11:30:37] [Program Info] : RAM: 32192MB
[11:30:37] [Program Info] : AMP Instance ID: 9d96a191-78e6-406b-85ea-ec8adb6acc27
[11:30:38] [Loader Info] : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
[11:30:38] [Core Info] : Metrics publishing is enabled at udp://localhost:12820.
[11:30:38] [Loader Info] : Loaded FileManagerPlugin by CubeCoders Limited
[11:30:38] [Loader Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[11:30:38] [Loader Info] : Loaded WebRequestPlugin by CubeCoders Limited
[11:30:38] [Loader Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[11:30:38] [Loader Info] : Loaded CommonCorePlugin by CubeCoders Limited
[11:30:38] [Loader Info] : GenericModule requests dependency steamcmdplugin…
[11:30:38] [Loader Info] : Loaded steamcmdplugin by CubeCoders Limited
[11:30:38] [Loader Info] : GenericModule requests dependency RCONPlugin…
[11:30:38] [Loader Info] : Loaded RCONPlugin by CubeCoders Limited
[11:30:38] [Core Warning] : Unable to update setting node GenericModule.App.Ports.$GamePort - the target type of (List) is not supported.
[11:30:38] [Core Warning] : Unable to update setting node GenericModule.App.Ports.$PeerPort - the target type of (List) is not supported.
[11:30:38] [Core Warning] : Unable to update setting node GenericModule.App.Ports.$QueryPort - the target type of (List) is not supported.
[11:30:38] [Core Warning] : Unable to update setting node GenericModule.App.Ports.$RCONPort - the target type of (List) is not supported.
[11:30:38] [Core Info] : Licence Present: AMP Professional Edition
[11:30:38] [FileManager Notice] : Using keypair with fingerprint mKxaFe2M5tE32qWvmrTEb2CnftUF9vdLaBlsl2cSwMQ=
[11:30:38] [FileManager Info] : SFTP Server started on 0.0.0.0:2224
[11:30:38] [Webserver Info] : Websockets are enabled.
[11:30:38] [Webserver Info] : Webserver started on http://127.0.0.1:8081
[11:30:38] [Webserver Info] : RouterTimer@10Hz with 2 jobs started
[11:30:38] [Core Info] : Checking for AMP updates…
[11:30:38] [Core Info] : Startup mode is StartApplication.
[11:30:38] [Core Info] : AMP is up to date.
[11:30:39] [Generic Warning] : Tried to merge config file ./ark-se/376030/./ShooterGame/Saved/Config/LinuxServer/GameUserSettings.ini but the file does not exist.
[11:30:39] [Generic Warning] : Tried to merge config file ./ark-se/376030/./ShooterGame/Saved/Config/LinuxServer/Game.ini but the file does not exist.
[11:30:39] [Generic Info] : Merging config file ./ark-se/376030/./ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini (INI format) using Unicode (UTF-8) encoding.
[11:30:39] [Generic Info] : Merging config file ./ark-se/376030/./ShooterGame/Saved/Config/WindowsServer/Game.ini (INI format) using Unicode (UTF-8) encoding.
[11:39:14] [Core Activity] : Authentication attempt for user admin from 127.0.0.1
[11:39:17] [Core Activity] : Authentication success
[11:39:17] [Core Warning] : Slow method invocation: Login took 2901ms to complete.
[11:39:17] [Core Warning] : Slow response: Core.Login took 2912ms to complete.
[11:49:26] [API:admin Activity] : Changing setting Meta.GenericModule.DisableStructureDecayPvE to False
[11:49:26] [Generic:admin Warning] : Tried to merge config file ./ark-se/376030/./ShooterGame/Saved/Config/LinuxServer/GameUserSettings.ini but the file does not exist.
[11:49:26] [Generic:admin Warning] : Tried to merge config file ./ark-se/376030/./ShooterGame/Saved/Config/LinuxServer/Game.ini but the file does not exist.
[11:49:26] [Generic:admin Info] : Merging config file ./ark-se/376030/./ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini (INI format) using Unicode (UTF-8) encoding.
[11:49:26] [Generic:admin Info] : Merging config file ./ark-se/376030/./ShooterGame/Saved/Config/WindowsServer/Game.ini (INI format) using Unicode (UTF-8) encoding.
