Startup Issue with ARK: Survival Evolved - Server crashes due to symbolic link issues
Application ARK: Survival Evolved
EDIT: This turned out to be a lack of storage issue and can be closed.
This is the error that I am getting. I am unsure how to link the files to the amp user. Under the amp user. The only amp related files I can see is .amp data, but I could not find the path defined in the error. Not sure where to go from here. Tested installing Minecraft to rule out an error with Amp itself.
ln: failed to create symbolic link ‘/AMP/ark-se/376030/ShooterGame/Binaries/Win64’: No such file or directory
  • Tried updatin multiple times
  • Deleted instance and created a new one
  • Uninstall then reinstall AMP
