Startup Issue with ARK: Survival Evolved - Errors on startup
Product AMP ‘Phobos’ v2.6.2.6 (Mainline)
Application ARK: Survival Evolved
Fails to install I believe - console output
Redirecting stderr to ‘D:\AMPDatastore\Instances\ARKSurvivalEvolved01\ark-se\logs\stderr.txt’
Logging directory: ‘D:\AMPDatastore\Instances\ARKSurvivalEvolved01\ark-se/logs’
13:43:22
Steam Console Client (c) Valve Corporation - version 1751406682
– type ‘quit’ to exit –
Loading Steam API…OK
force_install_dir “376030”
13:43:24
13:43:25
Waiting for client config…OK
Waiting for user info…OK
app_update 376030 -beta ServerBranch validate
ERROR! Failed to set beta ‘ServerBranch’
quit
Unloading Steam API…OK
I have confirmed the dependencies from #1 are installed on my machine too
  • Clicking update
  • clicking start
  • Reading output
That instance is broken, it doesn’t have the AMP settings
Is this a controller/target setup? If so make sure the configuration repositories are up to date on all installations
Updating the config repos worked! Thanks so much for the quick reply!
