copy the complete log data in here from this day:
[00:00:00] [Logger Info] : Rollover from previous log file: AMP_Logs/AMPLOG 2024-04-30 22-49-09.log
[01:22:00] [Core Info] : Checking for AMP updates…
[01:22:00] [Core Info] : AMP is up to date.
[06:09:08] [Core Activity] : Authentication attempt for user Arksucht92 from 127.0.0.1
[06:09:08] [Core Activity] : Authentication success
[06:09:12] [API:Arksucht92 Activity] : Starting the application.
[06:09:12] [Generic:Arksucht92 Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini (INI format) using Unicode (UTF-8) encoding.
[06:09:14] [Generic:Arksucht92 Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini (INI format) using Unicode (UTF-8) encoding.
[06:09:15] [Generic:Arksucht92 Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/Game.ini (INI format) using Unicode (UTF-8) encoding.
[06:09:17] [Generic:Arksucht92 Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/Game.ini (INI format) using Unicode (UTF-8) encoding.
esync: up and running.
[Success]: Detected Server: ArkAscendedServer.exe
[Success]: Detected Api: AsaApi.dll
[06:09:39] [RCON:Arksucht92 Error] : Source RCON failed to connect:
Connection refused.
[06:09:39] [RCON:Arksucht92 Info] : Source RCON disconnecting…
[06:09:40] [RCON:Arksucht92 Info] : Source RCON disconnected
[06:09:45] [RCON:Arksucht92 Error] : Source RCON failed to connect:
Connection refused.
[06:09:45] [RCON:Arksucht92 Info] : Source RCON disconnecting…
[06:09:46] [RCON:Arksucht92 Info] : Source RCON disconnected
[06:09:51] [RCON:Arksucht92 Error] : Source RCON failed to connect:
Connection refused.
[06:09:51] [RCON:Arksucht92 Info] : Source RCON disconnecting…
[06:09:52] [RCON:Arksucht92 Info] : Source RCON disconnected
[06:09:57] [RCON:Arksucht92 Error] : Source RCON failed to connect:
Connection refused.
[06:09:57] [RCON:Arksucht92 Info] : Source RCON disconnecting…
[06:09:58] [RCON:Arksucht92 Info] : Source RCON disconnected
[06:10:03] [RCON:Arksucht92 Error] : Source RCON failed to connect:
Connection refused.
[06:10:03] [RCON:Arksucht92 Info] : Source RCON disconnecting…
[06:10:04] [RCON:Arksucht92 Info] : Source RCON disconnected
[06:10:09] [RCON:Arksucht92 Error] : Source RCON failed to connect:
Connection refused.
[06:10:09] [RCON:Arksucht92 Info] : Source RCON disconnecting…
[06:10:10] [RCON:Arksucht92 Info] : Source RCON disconnected
[06:10:15] [RCON:Arksucht92 Error] : Source RCON failed to connect:
Connection refused.
[06:10:15] [RCON:Arksucht92 Info] : Source RCON disconnecting…
[Success]: Loader Completed, Reason: Success
[06:10:16] [RCON:Arksucht92 Info] : Source RCON disconnected
[06:10:21] [RCON:Arksucht92 Error] : Source RCON failed to connect:
Connection refused.
[06:10:21] [RCON:Arksucht92 Info] : Source RCON disconnecting…
[06:10:22] [RCON:Arksucht92 Info] : Source RCON disconnected
[06:10:27] [RCON:Arksucht92 Error] : Source RCON failed to connect:
Connection refused.
[06:10:27] [RCON:Arksucht92 Info] : Source RCON disconnecting…
[06:10:28] [RCON:Arksucht92 Info] : Source RCON disconnected
[06:10:33] [RCON:Arksucht92 Error] : Source RCON failed to connect:
Connection refused.
[06:10:33] [RCON:Arksucht92 Info] : Source RCON disconnecting…
[06:10:34] [RCON:Arksucht92 Info] : Source RCON disconnected
[06:10:39] [Core:Arksucht92 Warning] : Slow method invocation: Start took 86935ms to complete.
[06:10:39] [Core:Arksucht92 Warning] : Slow response: Core.Start took 86937ms to complete.
[06:13:07] [Core Activity] : Authentication attempt for user Arksucht92 from 127.0.0.1
[06:13:08] [Core Activity] : Authentication success
[06:14:28] [RCON:Arksucht92 Error] : Source RCON failed to read packet length.
[06:14:28] [RCON:Arksucht92 Info] : Source RCON disconnecting…
[06:14:28] [Generic Warning] : The application stopped unexpectedly. Exit code 0
[06:14:29] [RCON:Arksucht92 Info] : Source RCON disconnected
[06:14:31] [Generic Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini (INI format) using Unicode (UTF-8) encoding.
[06:14:32] [Generic Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini (INI format) using Unicode (UTF-8) encoding.
[06:14:34] [Generic Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/Game.ini (INI format) using Unicode (UTF-8) encoding.
[06:14:36] [Generic Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/Game.ini (INI format) using Unicode (UTF-8) encoding.
[06:18:47] [Generic Warning] : The application stopped unexpectedly. Exit code 0
[06:18:47] [Generic Warning] : Application failed to start 2 times, not restarting.
[06:24:29] [Core Activity] : Authentication attempt for user Arksucht92 from 127.0.0.1
[06:24:30] [Core Activity] : Authentication success
[06:53:53] [Core Activity] : Authentication attempt for user Arksucht92 from 127.0.0.1
[06:53:54] [Core Activity] : Authentication success
[06:53:55] [Core:Anonymous Activity] : Authentication attempt for user Arksucht92 from 127.0.0.1
[06:53:56] [Core:Anonymous Activity] : Authentication success
[06:55:54] [Core Activity] : Authentication attempt for user Arksucht92 from 127.0.0.1
[06:55:55] [Core Activity] : Authentication success
[07:04:13] [Core Activity] : Authentication attempt for user Arksucht92 from 127.0.0.1
[07:04:13] [Core Activity] : Authentication success
[07:04:23] [Core:Arksucht92 Warning] : Slow method invocation: GetDirectoryListing took 2247ms to complete.
[07:04:23] [Core:Arksucht92 Warning] : Slow response: FileManagerPlugin.GetDirectoryListing took 2255ms to complete.
[07:04:23] [Core:Arksucht92 Warning] : Slow method invocation: GetDirectoryListing took 2328ms to complete.
[07:04:23] [Core:Arksucht92 Warning] : Slow response: FileManagerPlugin.GetDirectoryListing took 2329ms to complete.
[07:04:23] [Core:Arksucht92 Warning] : Slow method invocation: GetDirectoryListing took 2322ms to complete.
[07:04:23] [Core:Arksucht92 Warning] : Slow response: FileManagerPlugin.GetDirectoryListing took 2331ms to complete.
[07:04:26] [Core Activity] : Authentication attempt for user Arksucht92 from 127.0.0.1
[07:04:27] [Core Activity] : Authentication success
[07:05:07] [API:Arksucht92 Activity] : Updating the application.
tid(26870) burning pthread_key_t == 0 so we never use it
minidumps folder is set to /tmp/dumps
UpdateUI: skip show logoSteam Console Client (c) Valve Corporation - version 1709846822
– type ‘quit’ to exit –
Loading Steam API…OK
force_install_dir “2430930”
Waiting for client config…OK
Waiting for user info…OK
“@sSteamCmdForcePlatformType” = “windows”
app_update 2430930 validate
Update state (0x5) verifying install, progress: 0.00 (0 / 11652116853)
Update state (0x5) verifying install, progress: 1.31 (153028051 / 11652116853)
Update state (0x5) verifying install, progress: 3.32 (386493523 / 11652116853)
Update state (0x5) verifying install, progress: 5.25 (611844075 / 11652116853)
Update state (0x5) verifying install, progress: 7.32 (853295367 / 11652116853)
Update state (0x5) verifying install, progress: 8.77 (1022058507 / 11652116853)
Update state (0x5) verifying install, progress: 10.76 (1253587011 / 11652116853)
Update state (0x5) verifying install, progress: 12.98 (1512475087 / 11652116853)
Update state (0x5) verifying install, progress: 15.34 (1786868359 / 11652116853)
Update state (0x5) verifying install, progress: 17.45 (2033512383 / 11652116853)
Update state (0x5) verifying install, progress: 19.67 (2292000511 / 11652116853)
Update state (0x5) verifying install, progress: 21.90 (2551444027 / 11652116853)
Update state (0x5) verifying install, progress: 24.00 (2796184747 / 11652116853)
Update state (0x5) verifying install, progress: 26.61 (3100745347 / 11652116853)
Update state (0x5) verifying install, progress: 29.01 (3379747323 / 11652116853)
Update state (0x5) verifying install, progress: 31.50 (3670913431 / 11652116853)
Update state (0x5) verifying install, progress: 33.91 (3951102871 / 11652116853)
Update state (0x5) verifying install, progress: 35.78 (4169206679 / 11652116853)
Update state (0x5) verifying install, progress: 37.81 (4405136279 / 11652116853)
Update state (0x5) verifying install, progress: 39.72 (4628054267 / 11652116853)
Update state (0x5) verifying install, progress: 41.74 (4863708475 / 11652116853)
Update state (0x5) verifying install, progress: 43.57 (5076513327 / 11652116853)
Update state (0x5) verifying install, progress: 45.19 (5265069919 / 11652116853)
Update state (0x5) verifying install, progress: 47.89 (5579642719 / 11652116853)
Update state (0x5) verifying install, progress: 49.89 (5812749215 / 11652116853)
Update state (0x5) verifying install, progress: 51.99 (6058115999 / 11652116853)
Update state (0x5) verifying install, progress: 53.84 (6273320943 / 11652116853)
Update state (0x5) verifying install, progress: 54.99 (6407538671 / 11652116853)
Update state (0x5) verifying install, progress: 56.97 (6638225391 / 11652116853)
Update state (0x5) verifying install, progress: 58.59 (6826537740 / 11652116853)
Update state (0x5) verifying install, progress: 59.92 (6981700364 / 11652116853)
Update state (0x5) verifying install, progress: 61.74 (7194022668 / 11652116853)
Update state (0x5) verifying install, progress: 63.81 (7434730252 / 11652116853)
Update state (0x5) verifying install, progress: 65.07 (7582479116 / 11652116853)
Update state (0x5) verifying install, progress: 66.70 (7771927340 / 11652116853)
Update state (0x5) verifying install, progress: 68.27 (7954381612 / 11652116853)
Update state (0x5) verifying install, progress: 69.62 (8112605996 / 11652116853)
Update state (0x5) verifying install, progress: 70.53 (8218362668 / 11652116853)
Update state (0x5) verifying install, progress: 71.96 (8385078060 / 11652116853)
Update state (0x5) verifying install, progress: 73.62 (8577993500 / 11652116853)
Update state (0x5) verifying install, progress: 74.95 (8732777852 / 11652116853)
Update state (0x5) verifying install, progress: 76.00 (8855208732 / 11652116853)
Update state (0x5) verifying install, progress: 77.29 (9005865756 / 11652116853)
Update state (0x5) verifying install, progress: 78.57 (9154982684 / 11652116853)
Update state (0x5) verifying install, progress: 79.70 (9286593292 / 11652116853)
Update state (0x5) verifying install, progress: 80.62 (9393941260 / 11652116853)
Update state (0x5) verifying install, progress: 81.63 (9511676684 / 11652116853)
Update state (0x5) verifying install, progress: 82.41 (9602018574 / 11652116853)
Update state (0x5) verifying install, progress: 83.34 (9711214820 / 11652116853)
Update state (0x5) verifying install, progress: 84.66 (9864947581 / 11652116853)
Update state (0x5) verifying install, progress: 85.90 (10009469301 / 11652116853)
Update state (0x5) verifying install, progress: 87.29 (10170950005 / 11652116853)
Update state (0x5) verifying install, progress: 88.13 (10269516149 / 11652116853)
Update state (0x5) verifying install, progress: 89.34 (10410025333 / 11652116853)
Update state (0x5) verifying install, progress: 90.72 (10570457461 / 11652116853)
Update state (0x5) verifying install, progress: 92.06 (10726695285 / 11652116853)
Update state (0x5) verifying install, progress: 93.22 (10861961589 / 11652116853)
Update state (0x5) verifying install, progress: 94.06 (10959479157 / 11652116853)
Update state (0x5) verifying install, progress: 94.88 (11055948149 / 11652116853)
Update state (0x5) verifying install, progress: 95.50 (11127251317 / 11652116853)
Update state (0x5) verifying install, progress: 95.78 (11160805749 / 11652116853)
Update state (0x5) verifying install, progress: 96.63 (11259371893 / 11652116853)
Update state (0x5) verifying install, progress: 97.89 (11406172533 / 11652116853)
Update state (0x5) verifying install, progress: 99.10 (11546681717 / 11652116853)
Success! App ‘2430930’ fully installed.
quit
[07:07:22] [steamcmdplugin:Arksucht92 Info] : SteamCMD Update successful
[07:07:26] [Generic:Arksucht92 Info] : Extracting /home/amp/.ampdata/instances/Test301/ark-sa/2430930/ShooterGame/Binaries/Win64/AsaApi_1.15.zip to /home/amp/.ampdata/instances/Test301/ark-sa/2430930/ShooterGame/Binaries/Win64/…
[07:07:29] [Generic:Arksucht92 Info] : Skipping download - target already exists (/home/amp/.ampdata/instances/Test301/ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/Game.ini)
[07:07:29] [Generic:Arksucht92 Info] : Skipping download - target already exists (/home/amp/.ampdata/instances/Test301/ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini)
[07:07:29] [Generic:Arksucht92 Info] : Skipping download - target already exists (/home/amp/.ampdata/instances/Test301/ark-sa/2430930/.backupExclude)
[07:07:29] [Generic:Arksucht92 Info] : Skipping download - target already exists (/home/amp/.ampdata/instances/Test301/ark-sa/2430930/ShooterGame/.backupExclude)
[07:07:58] [Generic:Arksucht92 Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini (INI format) using Unicode (UTF-8) encoding.
[07:08:00] [Generic:Arksucht92 Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini (INI format) using Unicode (UTF-8) encoding.
[07:08:02] [Generic:Arksucht92 Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/Game.ini (INI format) using Unicode (UTF-8) encoding.
[07:08:04] [Generic:Arksucht92 Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/Game.ini (INI format) using Unicode (UTF-8) encoding.
[07:08:42] [API:Arksucht92 Activity] : Starting the application.
[07:08:42] [Generic:Arksucht92 Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini (INI format) using Unicode (UTF-8) encoding.
[07:08:44] [Generic:Arksucht92 Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini (INI format) using Unicode (UTF-8) encoding.
[07:08:45] [Generic:Arksucht92 Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/Game.ini (INI format) using Unicode (UTF-8) encoding.
[07:08:46] [Generic:Arksucht92 Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/Game.ini (INI format) using Unicode (UTF-8) encoding.
[07:10:09] [Core:Arksucht92 Warning] : Slow method invocation: Start took 86320ms to complete.
[07:10:09] [Core:Arksucht92 Warning] : Slow response: Core.Start took 86321ms to complete.
[07:12:19] [Generic:Arksucht92 Warning] : The application stopped unexpectedly. Exit code 0
[07:12:22] [Generic:Arksucht92 Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini (INI format) using Unicode (UTF-8) encoding.
[07:12:24] [Generic:Arksucht92 Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini (INI format) using Unicode (UTF-8) encoding.
[07:12:25] [Generic:Arksucht92 Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/Game.ini (INI format) using Unicode (UTF-8) encoding.
[07:12:27] [Generic:Arksucht92 Info] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/Game.ini (INI format) using Unicode (UTF-8) encoding.
[07:12:48] [RCON:Arksucht92 Error] : Source RCON failed to connect:
Connection refused.
[07:12:48] [RCON:Arksucht92 Info] : Source RCON disconnecting…
[07:12:49] [RCON:Arksucht92 Info] : Source RCON disconnected
[07:12:54] [RCON:Arksucht92 Error] : Source RCON failed to connect:
Connection refused.
[07:12:54] [RCON:Arksucht92 Info] : Source RCON disconnecting…
[07:12:55] [RCON:Arksucht92 Info] : Source RCON disconnected
[07:13:00] [RCON:Arksucht92 Error] : Source RCON failed to connect:
Connection refused.
[07:13:00] [RCON:Arksucht92 Info] : Source RCON disconnecting…
[07:13:01] [RCON:Arksucht92 Info] : Source RCON disconnected
[07:13:06] [RCON:Arksucht92 Error] : Source RCON failed to connect:
Connection refused.
[07:13:06] [RCON:Arksucht92 Info] : Source RCON disconnecting…
[07:13:07] [RCON:Arksucht92 Info] : Source RCON disconnected
[07:13:12] [RCON:Arksucht92 Error] : Source RCON failed to connect:
Connection refused.
[07:13:12] [RCON:Arksucht92 Info] : Source RCON disconnecting…
[07:13:13] [RCON:Arksucht92 Info] : Source RCON disconnected
[07:16:44] [Core Activity] : Authentication attempt for user Arksucht92 from 127.0.0.1
[07:16:44] [Core Activity] : Authentication success
[07:17:17] [RCON:Arksucht92 Error] : Source RCON failed to read packet length.
[07:17:17] [RCON:Arksucht92 Info] : Source RCON disconnecting…
[07:17:18] [Generic:Arksucht92 Warning] : The application stopped unexpectedly. Exit code 0
[07:17:18] [Generic:Arksucht92 Warning] : Application failed to start 2 times, not restarting.
[07:17:18] [RCON:Arksucht92 Info] : Source RCON disconnected
[07:17:27] [Core:Anonymous Activity] : Authentication attempt for user Arksucht92 from 127.0.0.1
[07:17:27] [Core:Anonymous Activity] : Authentication success
[07:22:00] [Core Info] : Checking for AMP updates…
[07:22:00] [Core Info] : AMP is up to date.
[08:12:30] [Core Activity] : Authentication attempt for user Arksucht92 from 127.0.0.1
[08:12:31] [Core Activity] : Authentication success
[09:12:19] [Generic Warning] : RCON failed to connect after 2 hours. Aborting.
[09:12:50] [Generic:Arksucht92 Warning] : RCON failed to connect after 2 hours. Aborting.
[12:24:35] [Core Activity] : Authentication attempt for user Arksucht92 from 127.0.0.1
[12:24:36] [Core Activity] : Authentication success
