| Product | AMP ‘Phobos’ v2.6.0.12 (Mainline) |
| Virtualization | Docker |
| Application | ARK: Survival Ascended |
| Module | GenericModule |
| Current State | Starting |
created an ark ascended server wait approx an hour or so for it to boot all ports show as listening apart from 8888 wait a little longer as i cant find it in ark servers to then give up and go bed. wake up next day to an Error. here is amp logs that ive just found . turns out it may be an RCON connection issue.
[15:25:53] [Program Info/1] : Starting AMP version 2.6.0.12 (Phobos), built 14/02/2025 01:26
[15:25:53] [Program Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[15:25:53] [Program Info/1] : Running in a Docker environment.
[15:25:53] [Program Info/1] : OS: Linux / x86_64
[15:25:53] [Program Info/1] : CPU: AMD EPYC 7282 16-Core Processor (6C/6T)
[15:25:53] [Program Info/1] : RAM: 16002MB
[15:25:53] [Program Info/1] : AMP Instance ID: 104254b6-24ca-439d-b2c5-5d2e16f8184b
[15:25:56] [Core Info/1] : Loaded GenericModule version 2.6.0.12 by CubeCoders Limited
[15:25:56] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[15:25:56] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[15:25:57] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[15:25:57] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[15:25:57] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[15:25:57] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[15:25:57] [Loader Info/1] : Loaded AnalyticsPlugin by CubeCoders Limited
[15:25:57] [Loader Info/1] : GenericModule requests dependency steamcmdplugin…
[15:25:57] [System Error/11] : Missing plugin/assembly: MaxMind.Db (/AMP/Plugins/steamcmdplugin/MaxMind.Db.dll) for steamcmdplugin
[15:25:57] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[15:25:57] [Loader Info/1] : GenericModule requests dependency RCONPlugin…
[15:25:57] [System Info/1] : Starting Source RCON Passthru server at 0.0.0.0:7777
[15:25:57] [Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
[15:25:57] [Core Info/1] : Licence Present: AMP Standard Edition - Lifetime Licence
[15:25:58] [Loader Notice/1] : Using keypair with fingerprint CIQhQDY41ujK2gVf6EQ08dLdv4g30XoDAipiamQvc1o=
[15:25:58] [Loader Info/1] : SFTP Server started on 0.0.0.0:2224
[15:26:01] [Core Info/1] : Webserver started on http://127.0.0.1:8081
[15:26:01] [System Info/10] : Checking for AMP updates…
[15:26:01] [System Info/7] : Startup mode is UpdateAndStart.
[15:26:02] [System Info/9] : AMP is up to date.
UpdateUI: skip show logoSteam Console Client (c) Valve Corporation - version 1738027521
– type ‘quit’ to exit –
Loading Steam API…IPC function call IClientUtils::GetSteamRealm took too long: 111 msec
OK
force_install_dir “2430930”
IPC function call IClientAppManager::ForceInstallDirOverride took too long: 60 msec
Waiting for client config…OK
Waiting for user info…OK
“@sSteamCmdForcePlatformType” = “windows”
app_update 2430930 validate
Update state (0x5) verifying install, progress: 0.00 (0 / 32206494396)
Update state (0x5) verifying install, progress: 0.01 (2642278 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 45 msec
Update state (0x5) verifying install, progress: 0.57 (185112914 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 56 msec
Update state (0x5) verifying install, progress: 1.17 (375360890 / 32206494396)
Update state (0x5) verifying install, progress: 1.75 (564104570 / 32206494396)
Update state (0x5) verifying install, progress: 2.08 (671059322 / 32206494396)
Update state (0x5) verifying install, progress: 2.85 (916426106 / 32206494396)
Update state (0x5) verifying install, progress: 3.41 (1096781178 / 32206494396)
Update state (0x5) verifying install, progress: 4.03 (1299160526 / 32206494396)
Update state (0x5) verifying install, progress: 4.86 (1565498830 / 32206494396)
Update state (0x5) verifying install, progress: 5.54 (1784651214 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 62 msec
Update state (0x5) verifying install, progress: 5.99 (1929384442 / 32206494396)
Update state (0x5) verifying install, progress: 6.49 (2089152898 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 163 msec
Update state (0x5) verifying install, progress: 6.93 (2230710658 / 32206494396)
Update state (0x5) verifying install, progress: 7.91 (2548429186 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 106 msec
Update state (0x5) verifying install, progress: 8.50 (2737172866 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 52 msec
Update state (0x5) verifying install, progress: 9.23 (2974151042 / 32206494396)
Update state (0x5) verifying install, progress: 10.13 (3261660378 / 32206494396)
Update state (0x5) verifying install, progress: 11.08 (3567844570 / 32206494396)
Update state (0x5) verifying install, progress: 12.20 (3929482326 / 32206494396)
Update state (0x5) verifying install, progress: 13.04 (4200014934 / 32206494396)
Update state (0x5) verifying install, progress: 14.17 (4562822230 / 32206494396)
Update state (0x5) verifying install, progress: 15.13 (4872494150 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 41 msec
Update state (0x5) verifying install, progress: 16.26 (5236628834 / 32206494396)
Update state (0x5) verifying install, progress: 17.02 (5481938022 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 64 msec
Update state (0x5) verifying install, progress: 17.65 (5685361766 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 76 msec
Update state (0x5) verifying install, progress: 18.08 (5821666382 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 85 msec
Update state (0x5) verifying install, progress: 18.62 (5996778574 / 32206494396)
Update state (0x5) verifying install, progress: 19.42 (6253679694 / 32206494396)
Update state (0x5) verifying install, progress: 20.46 (6588610326 / 32206494396)
Update state (0x5) verifying install, progress: 21.53 (6935439950 / 32206494396)
Update state (0x5) verifying install, progress: 22.44 (7227842386 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 63 msec
IPC function call IClientAppManager::GetUpdateInfo took too long: 61 msec
IPC function call IClientAppManager::GetUpdateInfo took too long: 72 msec
Update state (0x5) verifying install, progress: 23.03 (7415548850 / 32206494396)
Update state (0x5) verifying install, progress: 24.19 (7790233678 / 32206494396)
Update state (0x5) verifying install, progress: 24.86 (8008120022 / 32206494396)
Update state (0x5) verifying install, progress: 25.69 (8273863586 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 70 msec
Update state (0x5) verifying install, progress: 26.54 (8547088254 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 74 msec
Update state (0x5) verifying install, progress: 27.29 (8790094034 / 32206494396)
Update state (0x5) verifying install, progress: 28.23 (9091035346 / 32206494396)
Update state (0x5) verifying install, progress: 29.02 (9344790738 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 50 msec
Update state (0x5) verifying install, progress: 29.71 (9568280826 / 32206494396)
Update state (0x5) verifying install, progress: 30.78 (9914111718 / 32206494396)
Update state (0x5) verifying install, progress: 31.47 (10136424874 / 32206494396)
Update state (0x5) verifying install, progress: 32.54 (10478394226 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 207 msec
IPC function call IClientAppManager::GetUpdateInfo took too long: 241 msec
Update state (0x5) verifying install, progress: 33.07 (10649312114 / 32206494396)
Update state (0x5) verifying install, progress: 33.82 (10892651182 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 48 msec
Update state (0x5) verifying install, progress: 34.85 (11224406958 / 32206494396)
Update state (0x5) verifying install, progress: 35.55 (11449119730 / 32206494396)
Update state (0x5) verifying install, progress: 36.50 (11756565354 / 32206494396)
Update state (0x5) verifying install, progress: 37.48 (12071107986 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 47 msec
Update state (0x5) verifying install, progress: 38.34 (12347313990 / 32206494396)
Update state (0x5) verifying install, progress: 39.09 (12590583622 / 32206494396)
Update state (0x5) verifying install, progress: 40.28 (12972958550 / 32206494396)
Update state (0x5) verifying install, progress: 41.12 (13244332942 / 32206494396)
Update state (0x5) verifying install, progress: 42.22 (13596544282 / 32206494396)
Update state (0x5) verifying install, progress: 43.03 (13858583306 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 54 msec
Update state (0x5) verifying install, progress: 43.76 (14092415754 / 32206494396)
Update state (0x5) verifying install, progress: 44.53 (14342515274 / 32206494396)
Update state (0x5) verifying install, progress: 45.22 (14563416370 / 32206494396)
Update state (0x5) verifying install, progress: 46.11 (14850893814 / 32206494396)
Update state (0x5) verifying install, progress: 47.21 (15204818246 / 32206494396)
Update state (0x5) verifying install, progress: 48.30 (15556801762 / 32206494396)
Update state (0x5) verifying install, progress: 48.98 (15775954146 / 32206494396)
Update state (0x5) verifying install, progress: 50.05 (16118009570 / 32206494396)
Update state (0x5) verifying install, progress: 50.97 (16416853730 / 32206494396)
Update state (0x5) verifying install, progress: 51.83 (16691151942 / 32206494396)
Update state (0x5) verifying install, progress: 52.79 (17002460594 / 32206494396)
Update state (0x5) verifying install, progress: 53.47 (17221612978 / 32206494396)
Update state (0x5) verifying install, progress: 54.50 (17553546370 / 32206494396)
Update state (0x5) verifying install, progress: 55.69 (17937325186 / 32206494396)
Update state (0x5) verifying install, progress: 56.68 (18253995138 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 51 msec
Update state (0x5) verifying install, progress: 57.45 (18501839602 / 32206494396)
Update state (0x5) verifying install, progress: 58.43 (18817460978 / 32206494396)
Update state (0x5) verifying install, progress: 59.54 (19176073970 / 32206494396)
Update state (0x5) verifying install, progress: 60.63 (19527563010 / 32206494396)
Update state (0x5) verifying install, progress: 61.23 (19721549570 / 32206494396)
Update state (0x5) verifying install, progress: 62.35 (20080162562 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 42 msec
Update state (0x5) verifying install, progress: 63.23 (20363510678 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 139 msec
IPC function call IClientAppManager::GetUpdateInfo took too long: 66 msec
Update state (0x5) verifying install, progress: 64.02 (20618499986 / 32206494396)
Update state (0x5) verifying install, progress: 64.86 (20889032594 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 43 msec
Update state (0x5) verifying install, progress: 65.69 (21155370898 / 32206494396)
Update state (0x5) verifying install, progress: 66.30 (21351454370 / 32206494396)
Update state (0x5) verifying install, progress: 67.16 (21630375586 / 32206494396)
Update state (0x5) verifying install, progress: 68.26 (21984387310 / 32206494396)
Update state (0x5) verifying install, progress: 69.24 (22298864450 / 32206494396)
Update state (0x5) verifying install, progress: 69.73 (22456150850 / 32206494396)
Update state (0x5) verifying install, progress: 70.82 (22809704758 / 32206494396)
Update state (0x5) verifying install, progress: 71.47 (23018371382 / 32206494396)
Update state (0x5) verifying install, progress: 72.54 (23363352886 / 32206494396)
Update state (0x5) verifying install, progress: 73.33 (23616288926 / 32206494396)
Update state (0x5) verifying install, progress: 74.38 (23956027550 / 32206494396)
Update state (0x5) verifying install, progress: 75.39 (24278997021 / 32206494396)
Update state (0x5) verifying install, progress: 76.13 (24519997469 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 69 msec
IPC function call IClientAppManager::GetUpdateInfo took too long: 57 msec
Update state (0x5) verifying install, progress: 76.78 (24727615517 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 83 msec
Update state (0x5) verifying install, progress: 77.44 (24940476445 / 32206494396)
Update state (0x5) verifying install, progress: 78.48 (25276835869 / 32206494396)
Update state (0x5) verifying install, progress: 79.55 (25620996125 / 32206494396)
Update state (0x5) verifying install, progress: 80.53 (25934369553 / 32206494396)
Update state (0x5) verifying install, progress: 81.37 (26207374033 / 32206494396)
Update state (0x5) verifying install, progress: 82.29 (26501759761 / 32206494396)
Update state (0x5) verifying install, progress: 83.02 (26739440721 / 32206494396)
Update state (0x5) verifying install, progress: 83.84 (27001310321 / 32206494396)
Update state (0x5) verifying install, progress: 84.70 (27277314833 / 32206494396)
Update state (0x5) verifying install, progress: 85.36 (27492649761 / 32206494396)
Update state (0x5) verifying install, progress: 86.05 (27713899297 / 32206494396)
Update state (0x5) verifying install, progress: 87.07 (28040590033 / 32206494396)
Update state (0x5) verifying install, progress: 88.06 (28359592721 / 32206494396)
Update state (0x5) verifying install, progress: 89.07 (28686465809 / 32206494396)
IPC function call IClientAppManager::GetUpdateInfo took too long: 59 msec
Update state (0x5) verifying install, progress: 89.93 (28961768209 / 32206494396)
Update state (0x5) verifying install, progress: 90.77 (29233726225 / 32206494396)
Update state (0x5) verifying install, progress: 92.20 (29693418257 / 32206494396)
Update state (0x5) verifying install, progress: 93.28 (30042274577 / 32206494396)
Update state (0x5) verifying install, progress: 94.11 (30308107025 / 32206494396)
Update state (0x5) verifying install, progress: 95.11 (30632440593 / 32206494396)
Update state (0x5) verifying install, progress: 95.94 (30897586961 / 32206494396)
Update state (0x5) verifying install, progress: 97.23 (31315274513 / 32206494396)
Update state (0x5) verifying install, progress: 98.27 (31648727825 / 32206494396)
Update state (0x5) verifying install, progress: 99.27 (31970663185 / 32206494396)
Success! App ‘2430930’ fully installed.
quit
[15:30:06] [System Info/18] : SteamCMD Update successful
[15:30:09] [System Info/18] : Skipping download - target already exists (/AMP/ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/Game.ini)
[15:30:09] [System Info/18] : Skipping download - target already exists (/AMP/ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini)
[15:30:10] [System Info/18] : Skipping download - target already exists (/AMP/ark-sa/2430930/.backupExclude)
[15:30:10] [System Info/11] : Skipping download - target already exists (/AMP/ark-sa/2430930/ShooterGame/.backupExclude)
Latest Proton GE version downloaded
[15:31:14] [Generic Info/18] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini (INI format) using Unicode (UTF-8) encoding.
[15:31:14] [Generic Info/18] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/Game.ini (INI format) using Unicode (UTF-8) encoding.
[15:31:15] [Generic Info/11] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini (INI format) using Unicode (UTF-8) encoding.
[15:31:15] [Generic Info/11] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/Game.ini (INI format) using Unicode (UTF-8) encoding.
fsync: up and running.
[15:31:35] [System Error/11] : Source RCON failed to connect:
Connection refused.
[15:31:35] [RCON Info/18] : Source RCON disconnecting…
[15:31:36] [RCON Info/18] : Source RCON disconnected
[15:31:41] [System Error/18] : Source RCON failed to connect:
Connection refused.
- Launch Ark Ascended Vanilla “will add mods”
- wait 2 hours for loading of said server
- Recieve Error
