Startup Issue with ARK: Survival Ascended - Can not start ASA server
Product AMP ‘Callisto’ v2.5.0.8 (Mainline)
Application ARK: Survival Ascended
21:42:46 Redirecting stderr to ‘/home/amp/Steam/logs/stderr.txt’
ILocalize::AddFile() failed to load file “public/steambootstrapper_english.txt”.
[ 0%] Checking for available update…
21:42:47
KeyValues Error: LoadFromBuffer: missing { (current key: ‘<!DOCTYPE’) in file manifest [offset: 15]
../tier1/KeyValues.cpp (2925) : Assertion Failed: Error while parsing text KeyValues for resource manifest
[ 0%] Downloading Update…
[----] !!! Fatal Error: Steamcmd needs to be online to update. Please confirm your network connection and try again.
21:42:48
threadtools.cpp (3294) : Assertion Failed: Illegal termination of worker thread ‘Thread(0x0x63732320/0x0xf15e2b’
bash21:42:48
cp: cannot stat ‘/AMP/ark-sa/linux32/steamclient.so’: No such file or directory
rm: cannot remove ‘GE-Proton*.*’: No such file or directory
  • Install ubuntu 24.04
  • Install AMP
  • Create a ASA server
  • ASA server fails to start with the below error
This points to a connectivity issue. Steam can’t talk to it’s content servers. Have you tried again since your original post?
I just tried again and it didn’t work…
Then I noticed there was a pending AMP update so I ran that and tried again and now it works, so whatever the issue was apparently got fixed in the new release.
Before this though I did manually verified that the machine itself was able to talk to Steams content servers (as I had seen a similar reply before).
Aye updating is always a good move. Glad it’s working for you!
