| Operating System | Linux - Ubuntu 22.04.5 on x86_64 |
| Virtualization | None |
| Module | ADSModule |
| Running in Container | No |
I am having some issues where it seems the Webserver Port and docker container always tries to start using the same port when creating an instance.
OS is ubuntu.
Error log:
docker: Error response from daemon: driver failed programming external connectivity on endpoint AMP_Rust01_CONFIGURE (3b2c8f8f5cef67ad225238ec262f7715a2d5b14e68ed6490faca7bd6c292d18b): failed to bind port 0.0.0.0:8081/tcp: Error starting userland proxy: listen tcp4 0.0.0.0:8081: bind: address already in use.
Failed to configure new instance Rust01 - Startup failure: Docker returned error code 125
Configuration Failed: Startup failure: Docker returned error code 125
Create Instance Failed: Startup failure: Docker returned error code 125
- Create in Docker Containers = Enabled
- Create instance (any game)
