Startup Issue with Application Deployment - the instance never starts and cannot be managed
Operating System Linux - Ubuntu 24.04 on x86_64
Product AMP ‘Callisto’ v2.5.0.14 (Mainline)
When starting a space engineers server, the server never starts, docker gives error 125 and starting without docker leads to it not starting at all.
  • start a SpaceEngineers Instance
  • click manage
  • Nothing happens
What does the deployment log say? It should its attempt to start docker and the log output from Docker.
I’m new to amp, where do I find the deployment logs?
If you’re refering to the console you get when managing an instance I can’t even get that far.
Main menu on the left hand side that says “Deployment Log”
17:53:02
Application Service port ranges have not been specified, using any available…
Non-managed instances exist, autoconfigure cannot guarentee that the configuration is valid!
17:53:03
facb4f58a8013c0277dbc0fbebb469467efb9e0ccf9ef3f9de83a9002fcba712
