Startup Issue with Application Deployment - Startup issue with Ark Survival Ascended
Operating System Linux - Ubuntu 24.04 on x86_64
Product AMP ‘Callisto’ v2.5.0.14 (Mainline)
Fails at Proton GE download
  • Creating of Ark instance fails during Update
  • This task could not be completed: Running Update Tasks - - State: 3 /bin/bash failed with exit code 1
  • The update fails
Update your instance from the main instances screen. Check the console for any errors. Your templates are out of date
Hi Greenlan,
Tried as you suggested, unfortunately same result, below are snippets from logs and config:
Config Repo:
CubeCoders/AMPTemplates
Greelan/AMPTemplates:dev
Fetch Latest:
Updating existing remote source GitHub - CubeCoders/AMPTemplates: For the AMP community to share Generic Module templates.
Already up to date.
Updating remote source Greelan/AMPTemplates:dev
Updating existing remote source GitHub - Greelan/AMPTemplates: For the AMP community to share Generic Module templates.
Already up to date.
Main Instance Update
Stopping instance ARKSurvivalAscendedServer01…
Instance ARKSurvivalAscendedServer01 has stopped.
Using default tag: latest
latest: Pulling from cubecoders/ampbase
Digest: sha256:0bdb5f2fc08648bf9d664c675460692517ffac159212fd9132ef28baf1f84e62
Status: Image is up to date for cubecoders/ampbase:latest
docker.io/cubecoders/ampbase:latest
4abc5191292cfbfcbcf9f73e4f52c98efc1771380004b9d34453a1bf16757d7b
Slow method invocation: RefreshInstanceConfig took 7369ms to complete.
Slow response: ADSModule.RefreshInstanceConfig took 7369ms to complete.
3640b3dcf1a7395e87938cf094180fc5ee342349cfbe1640709a7afb029d3fff
Start Ark Instance
This task could not be completed: Starting ARK: Survival Ascended… - - State: 3.
Application failed to start 2 times consecutively.
Log:
[Core Info/1] : Starting AMP version 2.5.0.14 (Callisto), built 14/06/2024 03:45
[Core Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[Core Info/1] : Running in a Docker environment.
[Core Info/1] : OS: Linux / x86_64
[Core Info/1] : CPU: 12th Gen Intel(R) Core™ i5-12600K (8C/16T)
[Core Info/1] : RAM: 64099MB
[Core Info/1] : AMP Instance ID: 9ebd0368-4088-4c6d-869c-1c082a9207ae
[Loader Info/1] : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
[Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[Loader Info/1] : GenericModule requests dependency steamcmdplugin…
[Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[Loader Info/1] : GenericModule requests dependency RCONPlugin…
[Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
[Core Info/1] : Licence Present: AMP Advanced Edition
[FileManager Notice/1] : Using keypair with fingerprint LS8AU8954HiCob8747wFoAgJKq27N1+emwRRnjdIKrQ=
[FileManager Info/1] : SFTP Server started on 0.0.0.0:2230
[Webserver Info/1] : Websockets are enabled.
[Webserver Info/1] : Webserver started on http://127.0.0.1:8087
[Logger Info/12] : RouterTimer@10Hz with 2 jobs started
[Core Info/1] : Checking for AMP updates…
[Core Info/1] : Startup mode is StartApplication.
[Generic Info/1] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini (INI format) using Unicode (UTF-8) encoding.
[Generic Info/1] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/Game.ini (INI format) using Unicode (UTF-8) encoding.
wine: created the configuration directory ‘/AMP/ark-sa/.proton/compatdata/pfx’
fsync: up and running.
[00:05:16] [Core Info/6] : AMP is up to date.
wine: configuration in L"/AMP/ark-sa/.proton/compatdata/pfx" has been updated.
[Generic Warning/10] : The application stopped unexpectedly. Exit code 53
[Generic Info/14] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini (INI format) using Unicode (UTF-8) encoding.
[Generic Info/14] : Merging config file ./ark-sa/2430930/ShooterGame/Saved/Config/WindowsServer/Game.ini (INI format) using Unicode (UTF-8) encoding.
[Generic Warning/17] : The application stopped unexpectedly. Exit code 53
[Generic Warning/17] : Application failed to start 2 times, not restarting.
[Core Activity/17] : Authentication attempt for user admin from 127.0.0.1
[Core Activity/15] : Authentication success
[RCON Error/5] : Source RCON failed to connect:
Connection refused.
Ark Instance Update
UpdateUI: skip show logoSteam Console Client (c) Valve Corporation - version 1718904263
– type ‘quit’ to exit –
Loading Steam API…OK
force_install_dir “2430930”
Waiting for client config…OK
Waiting for user info…OK
@sSteamCmdForcePlatformType” = “windows”
app_update 2430930 validate
Update state (0x5) verifying install, progress: 6.28 (772434951 / 12298024618)
Update state (0x5) verifying install, progress: 13.92 (1711959047 / 12298024618)
Update state (0x5) verifying install, progress: 20.98 (2580529178 / 12298024618)
Update state (0x5) verifying install, progress: 28.77 (3538498230 / 12298024618)
Update state (0x5) verifying install, progress: 36.65 (4506752534 / 12298024618)
Update state (0x5) verifying install, progress: 43.79 (5384794566 / 12298024618)
Update state (0x5) verifying install, progress: 51.78 (6367529926 / 12298024618)
Update state (0x5) verifying install, progress: 56.79 (6984381022 / 12298024618)
Update state (0x5) verifying install, progress: 57.65 (7089238622 / 12298024618)
Update state (0x5) verifying install, progress: 59.81 (7355389838 / 12298024618)
Update state (0x5) verifying install, progress: 67.77 (8334280734 / 12298024618)
Update state (0x5) verifying install, progress: 75.06 (9231260209 / 12298024618)
Update state (0x5) verifying install, progress: 82.82 (10185687665 / 12298024618)
Update state (0x5) verifying install, progress: 90.96 (11186498113 / 12298024618)
Update state (0x5) verifying install, progress: 99.07 (12183341617 / 12298024618)
Success! App ‘2430930’ fully installed.
quit
bash00:58:41
rm: cannot remove ‘GE-Proton*.*’: No such file or directory
What are your Proton settings under the SteamCMD and Updates menu?
Hi Greenlan,
I think I just found the issue, found a log entry at the same time in the firewall blocking “objects.githubusercontent.com” the malware filter pulling rules from URLhaus was causing the block, stating the IP was a Phishing address, I put a temporary hold on this and reran the update on Ark and it went through immediately and is now up and running.
Will dig a little deeper in the Firewall logs and report back any findings, may help others in future.
*** Update: IP Address being flagged on return is 45.128.232.165 pointing to ISP PFCloud, reporting Geofeed Tampering, cant see how the AMP Ark Update resulted in this and is more than likely caused upstream and not as a direct implication of AMP, however what is clear is on request for the Proton update this IP was injected on return and is Phishing and as a result the entire connection is immediately closed and blocked resulting in all associated IP’s being blocked including the legitimate ones until cleared. To resolve I removed the blocks and retried, checked the logs and noticed the IP is no longer present in the return traffic leading me to suspect the issue was detected upstream, blocked at that point thus resolving the issue. As such for any who may come across a similar issue, take specific note of the time in the AMP logs and correlate back to your level 2 firewall logs and this may help you resolve the issue.
Proton is downloaded from the Proton-GE GitHub
