| Product | AMP ‘Callisto’ v2.5.0.0 (Mainline) |
| Virtualization | QEMU_KVM |
| Module | ADSModule |
| Running in Container | No |
docker: Error response from daemon: AppArmor enabled on system but the docker-default profile could not be loaded: running apparmor_parser apparmor_parser --version failed with output:
error: exec: “apparmor_parser”: executable file not found in $PATH.
Failed to configure new instance SonsOfTheForest01 - Startup failure: Docker returned error code 127
Configuration Failed: Startup failure: Docker returned error code 127
Create Instance Failed: Startup failure: Docker returned error code 127
- Install Amp on a neu Server
- Install Docker and Restart
- Try to create a new Instance with Sons of the Forest
