Startup Issue with Application Deployment - Several docker errors when starting up instances
Virtualization HyperV
Whats the best procedure to resolve this?
9:00:03
docker: Error response from daemon: Conflict. The container name “/AMP_DST” is already in use by container “d8affc18c8b931347a621ba4a2fe8d40d76745507a756b65fb74ed77f3197beb”. You have to remove (or rename) that container to be able to reuse that name.
See ‘docker run --help’.
19:00:08
Start for instance Ark6-LostIsland was requested, but it is already running.
19:00:13
Start for instance Ark20-DK was requested, but it is already running.
19:00:18
docker: Error response from daemon: Conflict. The container name “/AMP_Starbound01” is already in use by container “3aa62a16d67d72d540cc5453393647370f504eb0503644f1c9da2cc227d35d15”. You have to remove (or rename) that container to be able to reuse that name.
19:00:24
docker: Error response from daemon: Conflict. The container name “/AMP_ValheimMistlands01” is already in use by container “387f8ab61ca02e44eb7f3f320ea2873291b850988da917d28aa7d2edf0678b51”. You have to remove (or rename) that container to be able to reuse that name.
19:00:26
Slow method invocation: Login took 2755ms to complete.
Slow response: Core.Login took 2791ms to complete.
19:00:29
docker: Error response from daemon: Conflict. The container name “/AMP_Terraria01” is already in use by container “a2cce88909ebca07b666ea411ff2763606a4fffac0f332c5e6d0839422de850f”. You have to remove (or rename) that container to be able to reuse that name.
19:00:35
docker: Error response from daemon: Conflict. The container name “/AMP_Terraria301” is already in use by container “91f402d78d330f6cee9b998336fba44ac208f13e705a5396693acca422878af1”. You have to remove (or rename) that container to be able to reuse that name.
19:00:40
docker: Error response from daemon: Conflict. The container name “/AMP_DSTCaves01” is already in use by container “d4c6f0d53062e08a42f9ff4cd3fa49b20510b282dd25d73a05d7158aa2610644”. You have to remove (or rename) that container to be able to reuse that name.
19:00:46
docker: Error response from daemon: Conflict. The container name “/AMP_FrozenFlame01” is already in use by container “ba8e6de413ebc0ecee0391c648da1dcd5df2d1fcdb5d465cd86cbacd1ff88296”. You have to remove (or rename) that container to be able to reuse that name.
19:00:51
docker: Error response from daemon: Conflict. The container name “/AMP_MCJava101” is already in use by container “e2454ad2de9886b5f2b71816b2a3bca6c6033f901d02da967cd9978320278190”. You have to remove (or rename) that container to be able to reuse that name.
19:00:56
docker: Error response from daemon: Conflict. The container name “/AMP_MCJava201” is already in use by container “da61ccfd43d6f63c7399d04b7bb5f09d344dcdc85dace0a7523625c4569be8df”. You have to remove (or rename) that container to be able to reuse that name.
19:01:02
docker: Error response from daemon: Conflict. The container name “/AMP_MCJava301” is already in use by container “7ea68554ca0ad2de9f79ed1fba78cacff8ba9902723d65802f8093fc6bfdc24d”. You have to remove (or rename) that container to be able to reuse that name.
19:01:07
docker: Error response from daemon: Conflict. The container name “/AMP_MCJava401” is already in use by container “8cdf6fe6edef6ecec4a1718b4cbe0b0efe0be8dcaf32532ae4744ea8df4d7fd8”. You have to remove (or rename) that container to be able to reuse that name.
19:01:13
docker: Error response from daemon: Conflict. The container name “/AMP_MCJava501” is already in use by container “f710783f88afb6d92fab748af66e26d80813f783e9b7cf597e8c313d7e0336ec”. You have to remove (or rename) that container to be able to reuse that name.
19:01:19
docker: Error response from daemon: Conflict. The container name “/AMP_Terraria1401” is already in use by container “50836e6fbcc81eb2b86d8b5a23875293780fa6d44798fe3e482b4d7237dc722b”. You have to remove (or rename) that container to be able to reuse that name.
  • Cause Unknown
  • Start instance
Reboot would be simplest. Looks like you have legacy processes running from before the update
Also make sure you clear browser cache
I have a suspicion these issues were preexisting before the update.
