Field
Value
Operating System
Windows - Windows 11 Home on x86_64
Product
AMPService ‘Phobos’ v2.6.0.6 (Mainline)
Virtualization
None
Application
Application Deployment
Module
ADSModule
Running in Container
No
Current State
Indeterminate
I can’t figure out how to set up access for other users to get access to the panel
set up roles with emails
tried reading though your discord support
tired using the deployment log to type the command in
You don’t type commands into the deployment log, it’s just a log.
Windows also doesn’t have an automated HTTPS setup, because it’s windows.
There’s a guide here that goes over everything:
[Documentation (2)]
There are a number of methods that can be used to set up secure HTTP (HTTPS) within AMP depending on your use case.
Note that with AMP Enterprise, use of HTTPS is mandatory.
1. Reverse proxy via nginx (recommended, Linux only)
If you use the default getamp.sh setup script to install AMP, and you select the option to set up HTTPS when running that script, AMP installs and configures an nginx reverse proxy and Let’s Encrypt certificate handled by certbot to provide secure …
