Startup Issue with Application Deployment - Server "No Space Left on Device" Issue
Operating System Linux - Ubuntu 22.04.5 on x86_64
Virtualization QEMU_KVM
Dear Support Team,
I am experiencing an issue with my AMP server running on Ubuntu. The server is showing the error “No space left on device”, preventing it from saving configurations and running properly.
I have tried to allocate more storage to AMP, but since it is installed under /home, which is on an ext4 partition, I am unable to increase its size through AMP directly. Additionally, there is no obvious way to expand the allocated storage within the AMP panel itself. (My vps has 120gb and amp only takes 11gb of it)
I would appreciate your guidance on how to resolve this issue. Specifically:
Is there a way to allocate more storage to AMP from within its settings?
If not, what would be the recommended approach to increase the available space on the /home partition while minimizing downtime?
Thank you in advance for your assistance.
Best regards
  • Starting server
  • Console error No space left on Device
  • All server crash
This isn’t an AMP issue, this is something you have to do at the OS level. If you’ve expanded the size of the virtual disk then you also need to manually adjust the partition size.
@CubeCoders-Bot Can you walk this user through checking the amount of free space they have, checking the size of their various partitions and look and see if the host has /home mounted on a different partition or similar? Don’t advise the user to make any changes to their setup, simply evaluate the situation.
