| Operating System | Linux - Ubuntu 22.04.3 on x86_64 |
| Product | AMP ‘Decadeus’ v2.4.6.6 (Mainline) |
| Virtualization | None |
| Module | ADSModule |
| Running in Container | No |
The server has been running just fine for a while now, and this morning players reported being unable to login. I investigated and noted that logging into the server was causing errors in the console. The first being
“a fatal error in the mono runtime or one of the native libraries
used by your application.”
followed by the following errors
FMOD failed to initialize the output device.: "Error initializing output device. " (60)
ALSA lib conf.c:5180:(_snd_config_evaluate) function snd_func_card_inum returned error: No such file or directory
ALSA lib confmisc.c:422:(snd_func_concat) error evaluating strings
ALSA lib conf.c:5180:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
ALSA lib confmisc.c:1334:(snd_func_refer) error evaluating name
ALSA lib conf.c:5180:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5703:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM default
Forced to initialize FMOD to to the device driver’s system output rate 48000, this may impact performance and/or give inconsistent experiences compared to selected sample rate 48000
ALSA lib confmisc.c:855:(parse_card) cannot find card ‘0’
FMOD initialized on nosound output
Begin MonoManager ReloadAssembly
- Completed reload, in 0.084 seconds
UnloadTime: 0.675071 ms
Fallback handler could not load library /AMP/seven-days-to-die/294420/7DaysToDieServer_Data/MonoBleedingEdge/x86_64/data-0x17aaf70.so
ERROR: ld.so: object ‘libdoorstop_x64.so’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
Fallback handler could not load library /AMP/seven-days-to-die/294420/7DaysToDieServer_Data/MonoBleedingEdge/x86_64/data-0x1c76610.so
2023-10-27T00:17:46 0.291 INF Version: Alpha 21.1 (b16) Compatibility Version: Alpha 21.1, Build: LinuxPlayer 64 Bit
- Start server isntance
- Try and login to the server
- Server console spits out error and restarts
