Startup Issue with Application Deployment - Server does not start with mod
hello with mod 1020675 (Offline Raid Protection) I get an error message regarding sound.
On my server without amp it runs without problems the mod manufacturer thinks that this could be because no sound card is included.
how can i fix this?
ALSA lib conf.c:5180:(_snd_config_evaluate) function snd_func_card_inum returned error: No such file or directory
ALSA lib confmisc.c:422:(snd_func_concat) error evaluating strings
ALSA lib conf.c:5180:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
ALSA lib confmisc.c:1334:(snd_func_refer) error evaluating name
ALSA lib conf.c:5180:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5703:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM default
ALSA lib confmisc.c:855:(parse_card) cannot find card ‘0’
  • mod searched where the error is caused
  • mod manufacturer contacted to see if the problem can be solved in another way
  • support ticket opened
You can just ignore that spam
okay but the server dont start with this issus :smiley:
