Field | Value |
Operating System | Windows - Windows 10 Pro on x86_64 |
Product | AMPService ‘Decadeus’ v2.4.5.0 (Mainline) |
Virtualization | None |
Application | Application Deployment |
Module | ADSModule |
Running in Container | No |
Current State | Indeterminate |
[07:56:09] [Program Info] : Starting AMP version 2.4.5.0 (Decadeus), built 21/06/2023 23:52
[07:56:09] [Program Info] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[07:56:09] [Core Info] : Loading configuration from provisionargs.kvp…
[07:56:09] [Core Warning] : Current time zone is set to Central Standard Time - It is recommended you switch to UTC+0 to avoid time-zone related issues
[07:56:09] [Program Info] : OS: Windows / x86_64
[07:56:09] [Program Info] : CPU: Intel(R) Xeon(R) Gold 6138 CPU @ 2.00GHz (20C/40T)
[07:56:09] [Program Info] : RAM: 130718MB
[07:56:09] [Program Info] : AMP Instance ID: c443edea-16fe-423a-8a8d-981b7fb6082b
[07:56:09] [Program Info] : Performing first-time setup for this instance, please wait…
[07:56:10] [Loader Info] : Loaded RustModule version 1.0.0.0 by CubeCoders Limited
[07:56:10] [Loader Info] : Loaded FileManagerPlugin by CubeCoders Limited
[07:56:10] [Loader Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[07:56:10] [Loader Info] : Loaded WebRequestPlugin by CubeCoders Limited
[07:56:10] [Loader Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[07:56:10] [Loader Info] : Loaded CommonCorePlugin by CubeCoders Limited
[07:56:10] [Loader Info] : RustModule requests dependency steamcmdplugin…
[07:56:10] [Loader Info] : Loaded steamcmdplugin by CubeCoders Limited
[07:56:10] [Loader Info] : RustModule requests dependency RCONPlugin…
[07:56:10] [Loader Info] : Loaded RCONPlugin by CubeCoders Limited
[07:56:10] [Core Info] : Performing activation, please wait…
[07:56:12] [Core Error] : Couldn’t activate: Common Language Runtime detected an invalid program.
[07:56:12] [Core Error] : InvalidProgramException
[07:56:12] [Core Error] : [0] (InvalidProgramException) : Common Language Runtime detected an invalid program.
[07:56:12] [Core Error] : at CCLClient45.Licencing.Log(String message)
at CCLClient45.Licencing.()
at GSMyAdmin.LicenceManager.()
[07:56:12] [Core Info] : Failed to activate: Server Unavailable
[07:56:12] [Program Info] : AMP has completed its first time setup. Saving settings and shutting down.
- Tried to start the instance
