I clicked “stop instance” for an application several weeks ago, and the “Stopping Instance” message now shows perpetually, and has been this way for a month. I also cannot delete the instance since I have important files in it. I cannot manage the instance at all.
[05:27:05] [Core Info/1] : Starting AMP version 2.5.1.0 (Callisto), built 06/07/2024 22:13
[05:27:05] [Core Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[05:27:05] [Logger Info/1] : Deleting 112 old log files...
[05:27:05] [Core Info/1] : Running in a QEMU KVM environment.
[05:27:05] [Core Info/1] : OS: Linux / x86_64
[05:27:05] [Core Info/1] : CPU: AMD EPYC 7543P 32-Core Processor (2C/2T)
[05:27:05] [Core Info/1] : RAM: 7959MB
[05:27:05] [Core Info/1] : AMP Instance ID: 0638079e-78c4-4fe9-8d20-2a34f79ff90a
[05:27:06] [Loader Info/1] : Loaded MinecraftModule version 1.0.0.3 by CubeCoders Limited
[05:27:06] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[05:27:06] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[05:27:06] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[05:27:06] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[05:27:06] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[05:27:06] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[05:27:06] [Loader Info/1] : Loaded AnalyticsPlugin by CubeCoders Limited
[05:27:06] [Analytics Info/5] : GeoIP database not found, downloading...
[05:27:07] [Core Info/1] : Licence Present: AMP Enterprise Edition - Lifetime Licence
[05:27:07] [FileManager Notice/1] : Using keypair with fingerprint ZoGYIlsigKQpmf4W9mbXPM0dOpJRUqyBBsYKDXKRd50=
[05:27:07] [FileManager Info/1] : SFTP Server started on 0.0.0.0:2224
[05:27:07] [Webserver Info/1] : Websockets are enabled.
[05:27:07] [Logger Info/10] : RouterTimer@10Hz with 2 jobs started
[05:27:07] [Webserver Info/1] : Webserver started on http://0.0.0.0:8081
[05:27:07] [Core Info/1] : Checking for AMP updates...
[05:27:07] [Core Info/1] : Startup mode is UpdateAndStart.
[05:27:08] [Minecraft Warning/5] : Unable to get Bedrock version data from https://www.minecraft.net/en-us/download/server/bedrock: Match not found.
[05:27:08] [Minecraft Info/5] : Trying first Bedrock info fallback...
[05:27:08] [Core Info/8] : A new update is available!
[05:27:08] [Minecraft Info/8] : Updating Modpack cache for 4 modpacks...
[05:27:10] [Minecraft Info/16] : Update complete.
[05:27:13] [Minecraft Warning/16] : Unable to get first fallback Bedrock version data from https://www.minecraft.net/en-us/download/server/bedrock: Match not found.
[05:27:13] [Minecraft Info/16] : Trying second Bedrock info fallback...
[05:27:14] [Minecraft Info/5] : Latest Bedrock version: 1.21.31.04
[05:27:15] [Core Activity/8] : Authentication attempt for user admin from 127.0.0.1
[05:27:16] [Core Activity/16] : Authentication success
[05:27:16] [Minecraft Info/16] : Java located at /usr/lib/jvm/temurin-20-jdk-amd64/bin/java
[05:27:16] [Minecraft Info/16] : Using 'Fabric' compatibility mode.
Downloading Minecraft server
Installing Fabric Loader 0.16.9(24w44a) on the server
Downloading required files
Downloading library org.ow2.asm:asm:9.7.1
Downloading library org.ow2.asm:asm-analysis:9.7.1
Downloading library org.ow2.asm:asm-commons:9.7.1
Downloading library org.ow2.asm:asm-tree:9.7.1
Downloading library org.ow2.asm:asm-util:9.7.1
Downloading library net.fabricmc:sponge-mixin:0.15.4+mixin.0.8.7
Downloading library net.fabricmc:intermediary:24w44a
Downloading library net.fabricmc:fabric-loader:0.16.9
Generating server launch JAR
[05:27:23] [ERROR]: Uncaught exception in thread "main"
java.lang.RuntimeException: An exception occurred when launching the server!
at net.fabricmc.loader.impl.launch.server.FabricServerLauncher.main(FabricServerLauncher.java:71)
at net.fabricmc.installer.ServerLauncher.main(ServerLauncher.java:69)
Caused by: java.lang.RuntimeException: Error invoking MC server bundler: java.lang.UnsupportedClassVersionError: net/minecraft/bundler/Main has been compiled by a more recent version of the Java Runtime (class file version 65.0), this version of the Java Runtime only recognizes class file versions up to 64.0
at net.fabricmc.loader.impl.game.minecraft.BundlerProcessor.process(BundlerProcessor.java:102)
at net.fabricmc.loader.impl.game.minecraft.MinecraftGameProvider.locateGame(MinecraftGameProvider.java:193)
at net.fabricmc.loader.impl.launch.knot.Knot.createGameProvider(Knot.java:175)
at net.fabricmc.loader.impl.launch.knot.Knot.init(Knot.java:130)
at net.fabricmc.loader.impl.launch.knot.Knot.launch(Knot.java:68)
at net.fabricmc.loader.impl.launch.knot.KnotServer.main(KnotServer.java:23)
at net.fabricmc.loader.impl.launch.server.FabricServerLauncher.main(FabricServerLauncher.java:69)
... 1 more
Caused by: java.lang.UnsupportedClassVersionError: net/minecraft/bundler/Main has been compiled by a more recent version of the Java Runtime (class file version 65.0), this version of the Java Runtime only recognizes class file versions up to 64.0
at java.base/java.lang.ClassLoader.defineClass1(Native Method)
at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:1013)
at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:875)
at net.fabricmc.loader.impl.game.minecraft.BundlerProcessor$1.loadClass(BundlerProcessor.java:65)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
at java.base/java.lang.Class.forName0(Native Method)
at java.base/java.lang.Class.forName(Class.java:496)
at java.base/java.lang.Class.forName(Class.java:475)
at net.fabricmc.loader.impl.game.minecraft.BundlerProcessor.process(BundlerProcessor.java:85)
... 7 more
[05:27:23] [Minecraft Warning/6] : Server failed to start 1/5 times...
[05:27:23] [Minecraft Warning/6] : The application stopped unexpectedly. Exit code 1
[05:27:23] [Minecraft Info/6] : Java located at /usr/lib/jvm/temurin-20-jdk-amd64/bin/java
[05:27:23] [Minecraft Info/6] : Using 'Fabric' compatibility mode.
... 1 more
... 7 more
[05:27:23] [Minecraft Warning/16] : Server failed to start 2/5 times...
[05:27:23] [Minecraft Warning/16] : Server stopped within 5 seconds of starting, AMP will not attempt to restart it.
[05:27:39] [API:admin Activity/14] : Sent to console: `start`
[05:27:39] [Minecraft:admin Error/14] : Failed to write to Minecraft server STDIN stream. Server process will be killed (if it isn't already dead)
[05:27:39] [Core:admin Error/14] : IOException
[05:27:39] [Core:admin Error/14] : [0] (IOException) : Write fault on path /home/amp/.ampdata/instances/mc01/[Unknown]
[05:27:39] [Core:admin Error/14] : at IO.FileStream.WriteInternal (Byte[] src, Int32 offset, Int32 count)
at IO.FileStream.Write (Byte[] array, Int32 offset, Int32 count)
at MinecraftModule.MinecraftApp.WriteLine (String message)
[05:32:02] [API:admin Activity/6] : Changing setting MinecraftModule.Java.JavaVersion to /usr/lib/jvm/temurin-17-jdk-amd64/bin/java
[05:32:06] [API:admin Activity/16] : Starting the application.
[05:32:06] [Minecraft:admin Info/16] : Java located at /usr/lib/jvm/temurin-17-jdk-amd64/bin/java
[05:32:06] [Minecraft:admin Info/16] : Using 'Fabric' compatibility mode.
[05:32:07] [ERROR]: Uncaught exception in thread "main"
Caused by: java.lang.RuntimeException: Error invoking MC server bundler: java.lang.UnsupportedClassVersionError: net/minecraft/bundler/Main has been compiled by a more recent version of the Java Runtime (class file version 65.0), this version of the Java Runtime only recognizes class file versions up to 61.0
... 1 more
Caused by: java.lang.UnsupportedClassVersionError: net/minecraft/bundler/Main has been compiled by a more recent version of the Java Runtime (class file version 65.0), this version of the Java Runtime only recognizes class file versions up to 61.0
at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:1017)
at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:879)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:525)
at java.base/java.lang.Class.forName(Class.java:467)
... 7 more
[05:32:08] [Minecraft:admin Warning/15] : Server failed to start 3/5 times...
[05:32:08] [Minecraft:admin Warning/15] : Server stopped within 5 seconds of starting, AMP will not attempt to restart it.
[05:33:55] [API:admin Activity/13] : Updating the application.
[05:41:51] [Core Error/13] : SocketException
[05:41:51] [Core Error/13] : [0] (SocketException) : Connection refused
[05:41:51] [Core Error/13] : at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
at Net.Sockets.UdpClient.Send (Byte[] dgram, Int32 bytes)
at ModuleShared.MetricsInfoPublisher.UpdateMetrics ()
[05:42:26] [Core Activity/15] : Authentication attempt for user admin from 127.0.0.1
[05:42:27] [Core Activity/8] : Authentication success
[05:42:39] [API:admin Activity/30] : Changing setting MinecraftModule.Java.JavaVersion to /usr/lib/jvm/temurin-20-jdk-amd64/bin/java
[05:42:45] [API:admin Activity/8] : Starting the application.
[05:42:45] [Minecraft:admin Info/8] : Java located at /usr/lib/jvm/temurin-20-jdk-amd64/bin/java
[05:42:45] [Minecraft:admin Info/8] : Using 'Fabric' compatibility mode.
[05:42:45] [ERROR]: Uncaught exception in thread "main"
... 1 more
... 7 more
[05:42:46] [Minecraft:admin Warning/13] : Server failed to start 4/5 times...
[05:42:46] [Minecraft:admin Warning/13] : Server stopped within 5 seconds of starting, AMP will not attempt to restart it.
[05:45:48] [Core Activity/32] : Authentication attempt for user admin from 127.0.0.1
[05:45:48] [Core Activity/15] : Authentication success
[05:46:46] [Core Activity/15] : Authentication attempt for user admin from 127.0.0.1
[05:46:46] [Core Activity/32] : Authentication success
[05:47:15] [Core Activity/14] : Authentication attempt for user admin from 127.0.0.1
[05:47:15] [Core Activity/31] : Authentication success
[05:47:33] [Core Activity/31] : Authentication attempt for user admin from 127.0.0.1
[05:47:33] [Core Activity/32] : Authentication success
[05:47:46] [API:admin Activity/5] : Updating the application.
[05:47:57] [API:admin Activity/5] : Starting the application.
[05:47:57] [Minecraft:admin Info/5] : Java located at /usr/lib/jvm/temurin-20-jdk-amd64/bin/java
[05:47:57] [Minecraft:admin Info/5] : Using 'Fabric' compatibility mode.
[05:47:57] [ERROR]: Uncaught exception in thread "main"
... 1 more
... 7 more
[05:47:58] [Minecraft:admin Warning/31] : Server failed to start 5/5 times...
[05:47:58] [Minecraft:admin Warning/31] : Server stopped within 5 seconds of starting, AMP will not attempt to restart it.
[05:48:39] [Core Activity/14] : Authentication attempt for user admin from 127.0.0.1
[05:48:39] [Core Activity/5] : Authentication success
[05:48:47] [API:admin Activity/32] : Sent to console: `stop`
[05:48:47] [Minecraft:admin Error/32] : Failed to write to Minecraft server STDIN stream. Server process will be killed (if it isn't already dead)
[05:48:47] [Core:admin Error/32] : IOException
[05:48:47] [Core:admin Error/32] : [0] (IOException) : Write fault on path /home/amp/.ampdata/instances/mc01/[Unknown]
[05:48:47] [Core:admin Error/32] : at IO.FileStream.WriteInternal (Byte[] src, Int32 offset, Int32 count)
[05:50:46] [API:admin Activity/31] : Changing setting Core.AMP.AppStartupMode to 1
[05:51:57] [API:admin Activity/30] : Changing setting LocalFileBackupPlugin.Cloud.UseS3Storage to True
