Startup Issue with Application Deployment - Path of Titans cant start error
Product AMP ‘Decadeus’ v2.4.5.4 (Mainline)
Virtualization QEMU_KVM
Hello, I keep getting an error on my Path of Titan server! I have now tested Debian 10 & 11 & 12 everywhere the same error occurs.
/AMP/path-of-titans/PathOfTitans/Binaries/Linux/PathOfTitansServer-Linux-Shipping: /usr/lib/x86_64-linux-gnu/libstdc++.so.6 : version `GLIBCXX_3.4.29’ not found (required by /AMP/path-of-titans/PathOfTitans/Binaries/Linux/…/…/Plugins/AlderonGames/Source/ThirdParty/Sentry/Linux/lib/libsentry.so)
How can I fix this?
  • Discord-Helpcenter
  • Look for the error at google
What’s the output of ldd --version ?
You are running the instance in docker so your host OS is irrelevant.
AMP’s docker images are Debian 11 based atm. The POT devs recently pushed an update that requires newer libs than what Debian 11 has.
Run it outside docker on Debian 12 and it will be fine. There is also a way to change the docker image to a temporary Debian 12 image but that involves some messing around.
