| Operating System | Linux - Debian GNU/Linux 11 on x86_64 |
| Product | AMP ‘Callisto’ v2.5.0.0 (Mainline) |
| Virtualization | QEMU_KVM |
| Module | ADSModule |
| Running in Container | No |
I stopped the server then restarted it, but it didn’t want to launch again after that.
- Stop server and rebooted
- Checked for other settings
- Ran log and I don’t know what the issue is.
[03:46:29] [Core Info] : Starting AMP version 2.5.0.0 (Callisto), built 22/03/2024 17:32
[03:46:29] [Core Info] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[03:46:29] [Logger Info] : Purging old audit logs (this may take a moment)…
[03:46:29] [Core Info] : Running in a Docker environment.
[03:46:29] [Core Info] : OS: Linux / x86_64
[03:46:29] [Core Info] : CPU: AMD EPYC 7543P 32-Core Processor (8C/8T)
[03:46:29] [Core Info] : RAM: 32114MB
[03:46:29] [Core Info] : AMP Instance ID: 9ef3df47-2707-4d28-92ae-d9d7550fb1d5
[03:46:29] [Loader Info] : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
[03:46:29] [Core Info] : Metrics publishing is enabled at udp://178.16.142.251:12820.
[03:46:29] [Loader Info] : Loaded FileManagerPlugin by CubeCoders Limited
[03:46:29] [Loader Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[03:46:29] [Loader Info] : Loaded WebRequestPlugin by CubeCoders Limited
[03:46:29] [Loader Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[03:46:29] [Loader Info] : Loaded CommonCorePlugin by CubeCoders Limited
[03:46:29] [Loader Info] : GenericModule requests dependency steamcmdplugin…
[03:46:29] [Loader Info] : Loaded steamcmdplugin by CubeCoders Limited
[03:46:29] [Loader Info] : GenericModule requests dependency RCONPlugin…
[03:46:29] [Loader Info] : Loaded RCONPlugin by CubeCoders Limited
[03:46:29] [Core Warning] : No such setting node: GenericModule.App.Ports. - maybe the relevant plugin/module isn’t loaded?
[03:46:29] [Core Info] : Licence Present: AMP Enterprise Edition
[03:46:30] [FileManager Notice] : Using keypair with fingerprint y4p0+xOQH+AUy2ZzeLcRFAAXRgzl3AA3Kd9AHQxWxAM=
[03:46:30] [FileManager Info] : SFTP Server started on 0.0.0.0:2224
[03:46:30] [Webserver Info] : Websockets are enabled.
[03:46:31] [Webserver Info] : Webserver started on http://0.0.0.0:8081
[03:46:31] [Logger Info] : RouterTimer@10Hz with 2 jobs started
[03:46:31] [Core Info] : Checking for AMP updates…
[03:46:31] [Core Info] : Startup mode is UpdateAndStart.
tid(79) burning pthread_key_t == 0 so we never use it
minidumps folder is set to /tmp/dumps
[03:46:31] [Core Info] : AMP is up to date.
UpdateUI: skip show logoSteam Console Client (c) Valve Corporation - version 1709846822
– type ‘quit’ to exit –
Loading Steam API…OK
force_install_dir “2394010”
[03:46:33] [Core Activity] : Authentication attempt for user admin from 127.0.0.1
[03:46:33] [Core Activity] : Authentication success
Waiting for client config…OK
Waiting for user info…OK
“@sSteamCmdForcePlatformType” = “windows”
app_update 2394010 validate
Update state (0x5) verifying install, progress: 5.36 (2099156 / 39195172)
Update state (0x5) verifying install, progress: 7.43 (201851684 / 2717769030)
Update state (0x5) verifying install, progress: 19.89 (540443092 / 2717769030)
Update state (0x5) verifying install, progress: 32.29 (877686964 / 2717769030)
Update state (0x5) verifying install, progress: 44.68 (1214279860 / 2717769030)
Update state (0x5) verifying install, progress: 57.18 (1554018484 / 2717769030)
Update state (0x5) verifying install, progress: 69.83 (1897951412 / 2717769030)
Update state (0x5) verifying install, progress: 82.26 (2235592884 / 2717769030)
Update state (0x5) verifying install, progress: 94.84 (2577428657 / 2717769030)
Success! App ‘2394010’ fully installed.
quit
[03:46:53] [steamcmdplugin Info] : SteamCMD Update successful
tid(110) burning pthread_key_t == 0 so we never use it
force_install_dir “2394010/Pal/Binaries/Win64”
app_update 1007 validate
Update state (0x5) verifying install, progress: 9.49 (4194304 / 44194776)
Success! App ‘1007’ fully installed.
quit
[03:47:00] [steamcmdplugin Info] : SteamCMD Update successful
[03:47:03] [Generic Info] : Extracting /AMP/palworld/2394010/Pal/Binaries/Win64/UE4SS_v3.0.1.zip to /AMP/palworld/2394010/Pal/Binaries/Win64…
[03:47:04] [Generic Info] : Merging config file ./palworld/2394010/Pal/Saved/Config/WindowsServer/PalWorldSettings.ini (Template) using Unicode (UTF-8) encoding.
[03:47:05] [Generic Info] : Merging config file ./palworld/2394010/Pal/Saved/Config/WindowsServer/PalWorldSettings.ini (Template) using Unicode (UTF-8) encoding.
[03:47:06] [Generic Warning] : The application stopped unexpectedly. Exit code 53
[03:47:09] [Generic Info] : Merging config file ./palworld/2394010/Pal/Saved/Config/WindowsServer/PalWorldSettings.ini (Template) using Unicode (UTF-8) encoding.
[03:47:12] [Generic Warning] : The application stopped unexpectedly. Exit code 53
[03:47:12] [Generic Warning] : Application failed to start 2 times, not restarting.
[03:47:24] [RCON Error] : Source RCON failed to connect: Connection refused. Reconnecting…
[03:47:24] [RCON Info] : Source RCON reconnecting…
[03:47:24] [RCON Info] : Source RCON disconnecting…
[03:47:26] [Core:admin Info] : Stop requested: AMP update requested via API
[03:47:26] [Core Notice] : AMP shutdown requested.
[03:47:26] [Core Notice] : Stopping Application…
[03:47:26] [Core Error] : NullReferenceException
[03:47:26] [Core Error] : [0] (NullReferenceException) : Object reference not set to an instance of an object
[03:47:26] [Core Error] : at GenericModule.GenericApp.SendSignal (GenericModule.GenericModuleConfig+ExitMethod method)
[03:47:26] [RCON Info] : Source RCON disconnecting…
[03:47:30] [RCON Error] : Source RCON failed to connect: Connection refused. Reconnecting…
[03:47:30] [RCON Info] : Source RCON reconnecting…
[03:47:32] [RCON Info] : Source RCON disconnecting…
[03:47:33] [Core Error] : NullReferenceException
[03:47:33] [Core Error] : [0] (NullReferenceException) : Object reference not set to an instance of an object
[03:47:33] [Core Error] : at GenericModule.GenericApp.SendSignal (GenericModule.GenericModuleConfig+ExitMethod method)
[03:47:33] [Core Notice] : Stopping Web Server…
[03:47:33] [Webserver Info] : Web server shutdown.
[03:47:33] [Core Notice] : Goodbye!
I miss you Casper. <3
