Startup Issue with Application Deployment - Notification errors regarding docker instance conflicts
Virtualization HyperV
  1. Startup Errors as listed below with docker
  2. Catastrophic crashing of App Instances at around 45 Instances.
Ubuntu show 40% free space on the drive, 150GB/200GB of ram in use.
AMD EPYC 7262 Server Processor, Intel DC SSD, 200GB Registered ECC Ram
AMP is up to date.
17:26:00
Start for instance Ark2-Aberration was requested, but it is already running.
17:26:05
Start for instance Ark6-LostIsland was requested, but it is already running.
17:26:10
Start for instance Ark20-DK was requested, but it is already running.
17:26:15
docker: Error response from daemon: Conflict. The container name “/AMP_Starbound01” is already in use by container “27ea6c6b6a684da027de92331bb8a1ae90701116cd65aafe88b90beaaaf932d0”. You have to remove (or rename) that container to be able to reuse that name.
See ‘docker run --help’.
17:26:20
docker: Error response from daemon: Conflict. The container name “/AMP_ValheimMistlands01” is already in use by container “87f11997a12931540d1b6b997f255e4a2387b827095f9f015b8b54f965116638”. You have to remove (or rename) that container to be able to reuse that name.
17:26:26
docker: Error response from daemon: Conflict. The container name “/AMP_Terraria01” is already in use by container “8338c493b848413bad3f3ff6c648df0408f4114074dfc51d6c9cc61e378babdd”. You have to remove (or rename) that container to be able to reuse that name.
17:26:31
docker: Error response from daemon: Conflict. The container name “/AMP_DSTCaves01” is already in use by container “eba6f9fc71ba5670e12df7f00ffc6bdef3246f0a289f3ac4bc3190da2bdc0d6e”. You have to remove (or rename) that container to be able to reuse that name.
17:26:36
docker: Error response from daemon: Conflict. The container name “/AMP_Icarus01” is already in use by container “3274c26738b9a6e2bd1befb9a4ec627f4937cc602e3ac2709ddd80b11a9a3297”. You have to remove (or rename) that container to be able to reuse that name.
17:26:41
docker: Error response from daemon: Conflict. The container name “/AMP_MCJava0701” is already in use by container “45d043801ebf1886acff03465ee5c1461194fc08f8103a2ee5ee2c2b6febf2dc”. You have to remove (or rename) that container to be able to reuse that name.
17:26:46
docker: Error response from daemon: Conflict. The container name “/AMP_MinecraftJava601” is already in use by container “5476d3177540fc4d363487f55f7f67193fb58033b254d21a85b6452dc9a0431b”. You have to remove (or rename) that container to be able to reuse that name.
17:26:52
docker: Error response from daemon: Conflict. The container name “/AMP_MinecraftJava501” is already in use by container “9d0c84dbb0cc3da1c20a8c1d3e7a7287dd96d523e316ec2a8c219581e4b3eadf”. You have to remove (or rename) that container to be able to reuse that name.
17:26:58
docker: Error response from daemon: Conflict. The container name “/AMP_MinecraftJava401” is already in use by container “9562c9bf6ae3991af6295ea4179ef30fa91eb5a362d783f4ea058faf16cbc237”. You have to remove (or rename) that container to be able to reuse that name.
17:27:03
Slow method invocation: Login took 2949ms to complete.
Slow response: Core.Login took 2954ms to complete.
docker: Error response from daemon: Conflict. The container name “/AMP_MinecraftJava301” is already in use by container “897caa0f6d7ef91d4ae2be55b31bf318257411824403105c6e397a19b25d90da”. You have to remove (or rename) that container to be able to reuse that name.
17:27:08
docker: Error response from daemon: Conflict. The container name “/AMP_MinecraftJava201” is already in use by container “5cc84e3092e354e66a084b43cc992d13c5dadbcb189cd4acb9c0d9b605e0619d”. You have to remove (or rename) that container to be able to reuse that name.
17:27:13
docker: Error response from daemon: Conflict. The container name “/AMP_MinecraftJava101” is already in use by container “9fba47b348796fe9111f6dfdc6e9f662c300c0c3288e8705e5a529ae91cfe9e9”. You have to remove (or rename) that container to be able to reuse that name.
17:27:19
docker: Error response from daemon: Conflict. The container name “/AMP_FrozenFlame0101” is already in use by container “6430e238442cf8b49fb7d0d158b748f6ce2b4e0602098591f47f16a4f40c6660”. You have to remove (or rename) that container to be able to reuse that name.
17:27:24
docker: Error response from daemon: Conflict. The container name “/AMP_TMLCalamity01” is already in use by container “be672a054915f3dbda99cf3a4a75221b3b0c8812a1dfc55ce3c76c59d7db9932”. You have to remove (or rename) that container to be able to reuse that name.
17:27:34
Start for instance TML1401 was requested, but it is already running.
17:27:39
Start for instance Satisfactory01 was requested, but it is already running.
17:27:44
Start for instance SpaceEngineers01 was requested, but it is already running.
17:27:49
Start for instance Empyrion01 was requested, but it is already running.
17:27:54
Start for instance AmongUs01 was requested, but it is already running.
  • upgraded to latest release
  • reboot the os
  • wait for system to fully boot
Is ampinstmgr itself up to date?
