| Product | AMP ‘Decadeus’ v2.4.6.8 (Mainline) |
| Virtualization | QEMU_KVM |
| Module | ADSModule |
| Running in Container | No |
There seems to be an issue with the first launch of the LocalAdmin server binary being held back by what appears to be an interactive EULA acceptance prompt. I wonder if echo -n "yes" | ./LocalAdmin in the template would solve this.
[07:44:24] [Core Info] : AMP is up to date.
[07:44:24] [steamcmdplugin Info] : SteamCMD Update successful
[07:44:24] [Logger Info] : Merging config file ./scp-secret-laboratory/996560/AppData/config/7777/config_gameplay.txt (KVP format) using Unicode (UTF-8) encoding.
[07:44:24] [Logger Info] : Merging config file ./scp-secret-laboratory/996560/AppData/config/7777/config_remoteadmin.txt (KVP format) using Unicode (UTF-8) encoding.
[07:44:25] [Logger Info] : Merging config file ./scp-secret-laboratory/996560/AppData/config/7777/config_gameplay.txt (KVP format) using Unicode (UTF-8) encoding.
[07:44:25] [Logger Info] : Merging config file ./scp-secret-laboratory/996560/AppData/config/7777/config_remoteadmin.txt (KVP format) using Unicode (UTF-8) encoding.
[2023-11-25 07:44:25.054 +00:00] Applied policy: gamedir_for_configs: true
[2023-11-25 07:44:25.071 +00:00] Welcome to LocalAdmin version 2.5.12!
[2023-11-25 07:44:25.071 +00:00] Before starting please read and accept the SCP:SL EULA.
[2023-11-25 07:44:25.071 +00:00] You can find it on the following website: https://link.scpslgame.com/eula
[2023-11-25 07:44:25.071 +00:00] Do you accept the EULA? [yes/no]
┃ Key ┃ Value ┃
┃ Operating System ┃ Linux - Debian GNU/Linux 12 on x86_64 ┃
┃ Product ┃ AMP 'Decadeus' v2.4.6.8 (Mainline) ┃
┃ Virtualization ┃ QEMU_KVM ┃
┃ Application ┃ Application Deployment ┃
┃ Module ┃ ADSModule ┃
┃ Running in Container ┃ No ┃
┃ Current State ┃ Indeterminate ┃
- Create new SCP: Secret Laboratory instance
