Minecraft instance will not start - I didn’t do any manual configuration, actually, i didn’t do any change at all - just my nephew for who I am running this called me and told that the server is down. I found it in “waiting for data” stage… so i updated AMP to the last version and tried to start again. No difference. How should I proceed (ideally without loosing instance data)? Thank you in advance
Just press play button to start the instance
no other step needed
no other step needed - just ticket creation requires it
sure, that is not possible - if i click Manage while the instance is trying to start, just the background of the tile flickers few times white and it continues with being frozen …
Right click the instance and hit View Logs
If it’s talking about license reactivation, and you’re with Hostinger, you’ll need to contact their support.
Otherwise if you have the license key you can reactivate it.
[17:24:22] [Core Info/1] : Starting AMP version 2.5.0.10 (Callisto), built 21/05/2024 01:29
[17:24:22] [Core Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[17:24:22] [Core Info/1] : Running in a QEMU KVM environment.
[17:24:22] [Core Info/1] : OS: Linux / x86_64
[17:24:22] [Core Info/1] : CPU: AMD EPYC 7543P 32-Core Processor (1C/1T)
[17:24:22] [Core Info/1] : RAM: 3934MB
[17:24:22] [Core Info/1] : AMP Instance ID: 93bfe968-7a60-4f8d-b3ee-ae09114437f1
[17:24:22] [Loader Info/1] : Loaded MinecraftModule version 1.0.0.3 by CubeCoders Limited
[17:24:22] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[17:24:22] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[17:24:22] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[17:24:22] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[17:24:22] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[17:24:22] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[17:24:22] [Core Warning/1] : Branding is enabled but the CustomBranding feature is not available on your current licence.
[17:24:23] [FileManager Notice/1] : Using keypair with fingerprint 2aKszYLdkEKkBNw0Vb8uEZgPe6DS751V08ulXsES9Bo=
[17:24:23] [FileManager Info/1] : SFTP Server started on 89.116.52.230:2224
[17:24:23] [Core Warning/1] : Expected licence feature RunAMP is not present.
[17:24:23] [Core Error/1] : No valid AMP licence was found. Please open a shell as the ‘amp’ user and run ampinstmgr reactivate Minecraft01 to reactivate this instance.
