Startup Issue with Application Deployment - minecraft bedrock server not starting
Virtualization QEMU_KVM
I have not been able to get a minecraft bedrock server instance to start up. the console just shows the following message:
[22:22:56] /AMP/./Minecraft/bedrock_server: error while loading shared libraries: libssl.so.1.1: cannot open shared object file: No such file or directory
that folder does appear to exist so I’m not sure what is wrong.
I managed to get a java editing server working OK which I could connect to, but bedrock just won’t start up.
  • create server instance for minecraft bedrock
  • select the instance and manage
  • accept terms and click start
  • check console and see the error in the description
I had the same issue. I ended up downloading Bedrock Server manually, and extracting it to ./instances/bedrockservername/Minecraft/
It appears that AMP is failing to fetch the bedrock server file.
Yes it is an open issue for quite a while. I am not sure if cubecoders actually plan to fix it, though. There have been a couple of updates to the amp server but non fixed this issue.
This was fixed in 2.4.7, make sure you’re up to date.
