Startup Issue with Application Deployment - LIM - Failure to make API call to "**********"
Hello,
i have a Problem to start my Minecraft Instance.
Thanks in advance you are a great help :slight_smile:
The Logs are posted below:
Operating System Linux - Ubuntu 20.04.6 on x86_64
Virtualization OpenVZ
Application State: Services Running
:jillenamp11:00:30
Protected setting ADSModule.NewInstanceDefaults.NewInstanceKey changed.
11:00:33
8613d8f6ad849a54d0e175def85e735beca1aa77d96d26ef19e3aac387962e52
11:09:17
Upgrading instance FriendlyWorld
11:09:20
java: Pulling from cubecoders/ampbase
Digest: sha256:340a48f8a78f72c77f7508af3e1b4f46cca6cc856465b7af8d1a6546cfa552e6
Status: Image is up to date for cubecoders/ampbase:java
docker.io/cubecoders/ampbase:java
11:09:53
72210ea23358d23a2b1f77170c3681fc3c709edda749564c00f1ba0b6025f64c
11:09:54
Managed remote instance FriendlyWorld at http***************
Authentication token for jillenamp requested by ManageInstance on behalf of jillenamp
11:09:55
LIM - Failure to make API call to FriendlyWorld: Connection refused
:jillenamp11:10:51
11:10:51
  • Restart AMP
  • Restart Instance
  • Add License Key
The instance isn’t actually running. Check its log (right click → view logs)
Thanks for the quick Help. After my Problem with the License my instance started.
